max77840 dont see CHGIN
Product Number: max77840
hi all,
after a mockup phase using evalkit bonded to our custom board every thing was fine
wee get first batch of max77840 embdedded IC and I get strange results
it doesent charge ( even with default config)
heres's an extract of current registers config and statuts (I'm not exporting everything but if you need to see something else feel free to ask )
MAX77840 Batt config POR = 1
NomCap : 0
IchgTerm : 0
VEmpty : 0
MAX77840 Charger Registers
Interrupts : bypI 0 bat2socI 0 batPI 0 batI 0 chgI 0 topoffI 0 chginI 0 aiclchginI 0
Masks : bypM 1 bat2socM 1 batPM 1 batM 1 chgM 0 topoffM 0 chginM 1 aiclchginM 1
STatus : bypOk 1 bat2socOk 0 batPOk 1 batOk 1 chgOk 1 topoffOk 0 chgOknOk 0 aiclchginOk 1
DTLS00 : batpDtls 0 ovpDrvDtls 0 VBusDetDtls 1 chgInDtls 0
DTLS01 : chgDtls 8 batDtls 4 TReg 0
DTLS02 : bypDtls 0 aiclDtls 0 chgInDtls 0
Conf00 : mode 5 wdten 0 spread 0 disibs 0 disCdCtrl 0
Conf01 : fchgTime 0 fsw 0 chgRstrt 1 lSel 0 pqEn 1
Conf02 : chgCc 9 otgIlim 0
Conf03 : toIth 2 toTime 3 ilim 3
Conf04 : chgCvPrm 22 minVSys 2
Conf06 : wdtclr 0 chgprot 0 maxotgEn 0 otgDc 0 enThm 0 ledEn 1
Conf07 : disQbatoff 0 regtemp 6 wdQbatoff 0
Conf09 : chginIlim 15 ovpdrvCtl 0
Conf10 : disskip 0 todebEn 0 wdQbatoff 0
Conf11 : vbypset 0
Conf12 : b2sovrc 4 vchginReg 0 chginsel 1 chglpm 0
MAX77840 ChargeDetection Registers
INT : VDNMon 0 DxOvp 0 DcdTmr 0 ChgDetRun 0 ChgTyp 0
STS : VDNMon 0 DxOvp 0 DcdTmr 0 ChgDetRun 0 ChgTyp 0
MSK : VDNMon 1 DxOvp 1 DcdTmr 0 ChgDetRun 0 ChgTyp 0
ChginIlim : chginIlim 0
CTRL1 : CdpDet 0 DcdCpl 1 CdDelay 1 Dcd2sCt 0 Rfu 1 ChgTypMan 0
CTRL2 : DisEnu 1 noAutoIBus 0 noBcComp 1 DxOvpEn 0 DpdnVdEn 0 SFOutOrd 0 SFOutAsrt 0
CTRL3 : Apple1A 0 DcpInMax 0 cdp500mA 0 UsbLowSp 0
QCTRL : EnuCtrlEn 0 EnuEn 0 DpdVdEn 0 DpVd DnVd 0
MAX77840 System Registers
pmicId : id_h 0 id_l 4
intSrc : b2sovrcInt 0 SYSInt 0 fgInt 0 sysInt 0 chgrInt 0
intSrcMsk : b2sovrcInt 1 SYSInt 1 fgInt 1 sysInt 1 chgrInt 1
SysIntSrc : tShdnInt 0 sysOvLoInt 0 sysUvLoInt 0 lowSysInt 0 t140CInt 0 t120CInt 0
SysIntSrcMsk : tShdnInt 1 sysOvLoInt 1 sysUvLoInt 1 lowSysInt 1 t140CInt 1 t120CInt 1
topSysStat : tShdnStat 0 sysOvStat 0 sysUvStat 0 lowSysStat 0 t140CStat 0 t120CStat 0
lsCnfg : lsen 0 lshyst 3 lsdac 3 biasEn 0
safeoutctrl : ensafeout 0 actdissafeo 0 safeout 1
softRst : softRst 0
MAX77840 M5 fuel gauge
jeita
TAlrtTh : MaxTempAlrt 0 MinTempAlrt 0
TAlrtTh2 : TempWarm 0 TempCool 0
JeitaVolt : ColdChargeV 0 HotChargeV 0 RoomChargeV 0
JeitaCurr : ColdCoeff 0 HotCoeff 0 RoomCoeff 0
CHargeState 0: DomainSoc 15 ChargeCUrrent 0x10
CHargeState 1: DomainSoc 14 ChargeCUrrent 0x0C
CHargeState 2: DomainSoc 13 ChargeCUrrent 0x0C
CHargeState 3: DomainSoc 12 ChargeCUrrent 0x0C
CHargeState 4: DomainSoc 11 ChargeCUrrent 0x0C
CHargeState 5: DomainSoc 10 ChargeCUrrent 0x0C
CHargeState 6: DomainSoc 9 ChargeCUrrent 0x0C
CHargeState 7: DomainSoc 8 ChargeCUrrent 0x0C
SmartChgCfg : DisJeita 0 UseVF 0 EnSC 0 EnSF 0
config & status
Status : Br 0 Smx 0 Tmx 0 Vmx 0 Bi 0 Smn 0 Tmn 0 Vmn 1 dSOCi 0 ThmHot 0 lsysmx 0 Bst 1 POR 1 lmn 0 FullDet 0
VAlrtTh : MaxVoltageAlrt 0 MinVoltageAlrt 0
SAlrtTh : MaxSocAlrt 0 MinSocAlrt 0
ATrate : 0
Config : FCFE 0 Ss 0 Ts 0 Vs 0 FGCC 0 AINSH 0 Ten 0 Tex 0 SHDN 0 I2CSH 0 ICFE 0 ETHRM 0 FTHRM 0 Aen 0 Bei 0 Ber 0
Config2 : dSOCen 0 TAlrtEn 0 LdMdl 0 OCVQen 0
Mesurements
Current : 21.000000 AVg 3.437500
Batt : 3588 AVg 3589
it looks that It didnt see CHGIN correctly (ChgDtls=0x08 & mode=0x05)
Hw schematics is based on eval kit and datasheet basic design
my concern is that VUSBDET and OVPENB are floating
can this be a cause of CHGIN detection error
if yes Is there a solution to disable VUSBDET and CHGIN-UVLO
it look also that current reading is not good
general current draw should be about 300 to 400 ma when no suply is connected and I read between -1700 and  -2700 with or without supply
on this subject avgCurrent decoding format is well defined in datasheet but for current itself there is no details on how to decode it not even a unit definition
(when using max 17303 or others the units and decoding are defined for all registers with equivalents unit but there is no similar chapter in datatsheet for the 77840)
Edit Notes
adding hello
[edited by: gasol at 4:15 PM (GMT -4) on 27 Mar 2023]
