Hi Team,
One quick question, which metering solution is function-wise most closed to STPM34, customer wants to replace it out, thanks for any ideas!
Andrew
ADE9000
Production
The ADE9000 is a highly accurate, fully integrated, multiphase energy and power quality monitoring device. Superior analog performance and a digital signal...
Datasheet
ADE9000 on Analog.com
ADE9078
Production
The ADE9078 is a highly accurate, fully integrated energy metering device. Interfacing with both current transformer (CT) and Rogowski coil sensors, the...
Datasheet
ADE9078 on Analog.com
Hi Team,
Andrew
Sorry, forgot to mention, automotive grade is needed, do we have solution today? Thanks!
Andrew
For energy ICs ADE9078 is best https://www.analog.com/media/en/technical-documentation/data-sheets/ADE9078.pdf ADE9000 my also be a possibility.
These part has not been tested to automotive standards. Do…
Andrew
These part has not been tested to automotive standards. Do you really need automotive grade?
Dave
Thanks for the quick feedback, Dave!
Yes, so far customer is asking for auto grade, if not, I will promote the device you provided, thanks!!
Andrew
