ADE9153A event interrupts
Product Number: ADE9153A
I am interested in the ADE9153A for the autocalibration feature. I also need a fast signal to the host processor that either a voltage dip or an over-current event has occured. Can the IRQ interrupt pin be used to signal both of these events, or can it only be used for 1 event?
thank you.
Parents
    The IRQ pin behavior can be configured in the mask register (address: 0x405) by setting the appropriate bits. ISR servicing should include reading first the Tier1 status (address: 0x402) register then if a bit set (in your case is event_stat bit), reading Tier2 register (which in your case is event_status register (address: 0x04c1)) will to identify the source of the trigger. Please note that Tier1 register can be cleared by writing 1 to its appropriate bit while Tier2 is cleared once read.
  • Thank you for your prompt reply. I think this is making sense.
    It appears that I can have multiple events that trigger the IQR pin. When the IQR pin goes off, I immediately read data sent from UART or SPI, which contains the source of the trigger. To identify the source of the trigger, you find which bit has been switched from 0 to 1. The Arduino library should help with the rest. Thanks.
Reply
Children
No Data
