As you suggest earlier for 440V RMS for the voltage divider circuit resistors of 2M ohm. Please let us know the Voltage divider circuit for the 600V RMS what will be the resistors that we need to choose.
Thanks & Regards
Muralidharan
Thanks & Regards
Muralidharan
dave.smith dlath, can you please help answer this question?
At 440V RMS with a 2MOhm : 1KOhm voltage divider brings the voltage at the adc input to 0.22Vrms which is within range. For 600V RMS a 2MOhm : 1kOhm voltage divider results in 0.3 V RMS at the ADC input which is still in range. In order to have the output be at the same level as 440V RMS you would change your voltage divider to 2.7MOhm : 1kOhm.
When picking the voltage divider resistor values you want to ensure that the voltage after the divider will not exceed +- 500mV at the ADC input. With a a 2MOhm :1 KOhm divider you meet this requirement for both 440VRMS and 600V RMS.
