issue in HSDC connection between ADE7880 and STM32F407
Hi all,
i am working on waveform sampling mode of ADE7880 .I have established i2c connection and done code for HSDC enabling and configuring,
But the issue is in for collecting HSDC data i have enabled  SPI port in STM, But its not communicating properly
MY code for SPI is
    static void MX_SPI1_Init(void)
  /* SPI1 parameter configuration*/
  hspi1.Instance = SPI1;
  hspi1.Init.Mode = SPI_MODE_SLAVE;
  hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi1.Init.NSS = SPI_NSS_SOFT;
  hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi1.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI1_Init 2 */
  /* USER CODE END SPI1_Init 2 */
and in main
uint8_t tx_data[2];
uint8_t rx_data[2];
tx_data[0] = 0xE5; //addr | 0x80; // read operation
tx_data[1] = 0x0C; // dummy byte for response
hal_status = HAL_SPI_TransmitReceive(&hspi1, tx_data, rx_data, 2, 1000);
it return error
Where is the problem how to correct it.
help plz
Thanks in Regards,
  • Can you provide scope captures of your hsdc signals?
    I am not sure how your test code is supposed to work.  Are you doing a loop back sending data out and reading back? Your spi is in slave mode, so I don't think you will get a chip select in this mode. If this is the case if you set spi to master is should loop back correctly.
    Dave
