Issues obtaining the correct MS_ACAL_AICC for the given configuration of our system using the ADE9153A.
We’re currently trying to implement a power sensor using your ADE9153A chip, but we’re having issues getting the MS_ACAL_AICC calibration constant right after calibration.
We've taken a look into the Application notes, the Datasheet, and the Arduino code examples but no luck so far on getting our system properly calibrated for the current.
Below I attach the calibration sequence.
- //set channel A current gain
   address: AIPGAGain
   value:   0xA
- //set data path to default
   address: Config0
   value:   0 //enable burst and enable interrupt of Zero crossing pin
-  address: Config1
   value:   0x0300
- //High-pass filter corner, fc=0.625Hz
   address: Config2
   value:   0x0C00
- //peak current disabled
   address: Config3
   value:   0x0000
- //ZX low-pass filter select
   address: ZxCfg
   value:   0x0000
-  //Enable DREADY interrupt
   address: Mask,
   value:   0x00000100
-  address: ActNlLvl
   value:   0x000033C8
-  address: ReactNlLvl
   value:   0x000033C8
- address: AppNlLvl
   value:   0x000033C8
- address: CompMode
   value:   0x0005
- address: VDivRSmall
   value:   0x03E8
- address: EpCfg
   value:   0x0009
- address: EgyTime
   value:   0x0F9F
- //enable burst and enable interrupt of Zero crossing pin
   address: Zxthrsh
   value:   1
- address: Wthr
   value:   0x00100000
- address: Varthr
   value:   uint32(0x00100000),
- address: Vathr
   value:   0x00100000
- address: Cfmode
   value:   0x0000
- address: Cf1den
   value:   0xFFFF
- address: Cf2den
   value:   0xFFFF
- address: CtPhaseDelay
   value:   0
-  address: CtCorner
   value:   0
-  address: APhaseCal
   value:   0
We also configure the voltage level and AC mode, but that is a parameter of our system. It could be 230V and 50Hz or 60Hz, or 120V and 60Hz.
With that configuration in our 120V and 60Hz system we have the following values: MS_ACAL_AICC 32287.574 | Target_ICC: 838.190308
Top Replies
