Dear Sir I am using ADE7763/7753 I want to know how to calculate the power factor as this ic don't give power factor directly
If I do the ratio of LAENERGY AND LVAENERGY than I got value more than 1, which is not correct
Please help
Regards Kuldeep
ADE7763
Production
The ADE7763 features proprietary ADCs and fixed function DSP for high accuracy over large variations in environmental conditions and time. The ADE7763...
Datasheet
ADE7763 on Analog.com
ADE7753
Production
The ADE7753 features proprietary ADCs and DSP for high
time. The ADE7753 incorporates two...
Datasheet
ADE7753 on Analog.com
Please help
Regards Kuldeep
pg 35 of the ade7763 datasheet shows the scaling of active to va. www.analog.com/.../ADE7763.pdf
pg 38 on the ade7753 datasheet www.analog.com/.../ADE7753.pdf
pf = Lactive / (LVA / .848)
Dave Smith
"2. Yes I am getting some offset ate VRMS and IRMS both which i am unable to remove by CH2OS or CH1OS so i just left it and calibrate Voltage and current with my meter and at all points it is shown OK"
Use IRMSOS and VRMSOS for RMS offset calibration. Not CH2OS AND CH1OS
Current channel as a HPF to remove DC offsets for the RMS calculation. dc offset correction is not needed unless you are not using highpass filter
The voltage channel does not. You can improve performance sometimes for active power by adjusting the voltage channel offset CH2OS.
Set CH1OS and CH2OS to 0x0 adj channel 2 offset register can cause active energy problems.
Are you using the temp sensor? If you are try not doing this does the active energy improve?
See if you energies are now linear. If better the errors were caused by the CHOS registers. Use IRMSOS and VRMSOS to calibrate RMS values.
You could have a cross talk issue on the PCB.
Dave
Hi
I am unable to read waveform register properly
It's too much fluctuating even i did not apply any signal
Please help
Hi
Please help
