ADE7854 VCP and VN Pins
I have a question on the ADE7854,   I have a
design that’s currently using the VCP and VN pins as an additional current
sensing transformer input, basically I am using it in the same way as the IA
and IN pins, is there any issue with this?
I am about to resuse the part in the same configuration and
want to confirm that this is okay, its not clear in the data sheet.
    on May 11, 2016 1:34 AM
    Hi Amboyle,
    Are you using any of the voltage inputs (VAP or VBP) for a voltage measurement?
    What current sensor are you using in your application? Is it a CT?
    I could recommend the ADE7816, this is very similar to the ADE7854 except that it has one voltage input and 6 current inputs which allows you to retain all the metrology functionality like energies.
    Dlath
    on Aug 2, 2018 3:27 PM
    Thank you,
    EZ Admin
