ADE7933/ADE7932 input circuit
Hi there,
We have designed an energy metering device based on the ADE7978/ADE7933/ADE7932 family, following the datasheet guidelines. We have also managed to calibrate the measurement with the precision required. However, we have found that sometimes when we disconnect the device and connect it again with the same setup configuration, the measurement prior to the calibration varies, which causes the calibration to be incorrect. In this sense, we have the feeling that the problem is related to the configuration of the ADE7932 input circuitry. Even though we have followed the schematics provided in the datasheet:
We have separated the input circuitry between two boards (PCB A and B) as you can see in the following picture:
Signal N is the neutral and signals L1_P and L1 are both ends of the shunt resistor placed on L1 phase, the three of them marked in yellow (PCB A).
Signals IP, IN, V1P and AGND are marked in green (PCB A) and blue (PCB B), and they are connected between the two boards using through-hole 1.27mm-pitch pins. This means that the GND planes layout guidelines (datasheet page 88) are not followed on PCB A, but we believe that, in principle, this would only affect EMI issues.
Are the IP, IN, V1P signals too sensible to be routed through these pins? Is it critical to not have the input circuitry in the same board?
Thanks for your help and let me know if you need more information.
  • Hi ASanchez,
       What variables do you test? Like the voltage or current rms value or energy value? You said the value is changed, can you tell us what's your input range and what's the range of change in your test? You can confirm if you signal source is steady by this way, test the signal before ADC like the voltage signal on R7 in your circuit by oscilloscope every time you disconnect the device and connect it again, you can see what's the signal change range. Thank you very much.
    Gary
  • Hi Gary,
    Thanks for your response. We test voltage and current rms. Our input source is a a programmable AC power source, and we measure the signal with two multimeters to register the voltage and current value entered. For example, we apply an AC signal of 2A and we obtain a measurement of 2.02A. We calibrate the ADC and afterwards we are able to measure 2.00A, which is great. After disconnecting and connecting the device, we apply the same signal and obtain 1.92A, and the value remains steady. The disconcerting thing about it is that it does not happen every time the device is disconnected, and we have only observed this effect on the current measurement.
    We have tried to monitor the IP-IN differential signal to see the signal change range, but it has a very low amplitude (~3mA rms) and we do not achieve enough precision with the oscilloscope.
    Best regards.
  • Hi ASancez,
       What's your shunt resistant value? Let's see how small your signal is. Thank you very much.
    Gary
  • Hi Gary,
    My shunt resistant value is 250uOhm.
    Thanks and bests.
  • Hi ASanchez,
       The ADE7933/ADE7932 are isolated, 3-channel sigma-delta analog-to-digital converters (Σ-Δ ADCs) for polyphase energy metering applications that use shunt current sensors. How do you test RMS code? Do you use ADE7978? Thank you very much.
    Gary
  • Hi Gary,
    Yes, we use the ADE7978 as central device, and we read the ADE7978's registers via SPI using a microcontroller (MSP430FR2433).
    What do you mean by "RMS code"?
    Bests
  • Hi ASanchez,
       I mean RMS code is the RMS registers value, can you test the shunt resistance value when you get the right value and wrong value? Let's see if the sensor value have been changed. What signal frequency do you put into the system?
    Gary
  • Hi Gary,
    I'm afraid we do not have instrumentation capable of measuring such low resistance values... We were wondering whether the components on the isolated side of the ADE7932 could have been degraded. There aren't much guidelines to be followed on the datasheet related to the selection of those components.
    The frequency of the AC signals applied is always 50Hz.
    Best regards
  • Hi ASanche,
       If you don't read RMS code value, how do you do the calibration? Please show me the way.
    Gary
  • Hi Gary,
    If I understood correctly, the RMS code is the RMS values on the ADE7978 registers. Yes, we do read the registers, and we compare the values to the voltage and current measurements obtained using two external multimeters. After that, we we modify the corresponding gain registers to calibrate the device. I was saying that we cannot directly measure the shunt resistance value (~ uOhm).
    Bests
