EV-ADE9153ASHIELDZ ESP8266 COMMUNICATION
I am currently unable to use the ESP8266 with the ADE9153A SHIELDZ.
I made the required changes in terms of R14, R49, R51, R67 and R68.
I also changed the CS_PIN to 16, it was defined as 15 in the sample code but GPIO16 is used on the board as CS.
The error message received is attached below.
Is there something I am forgetting?
Thanks for your answer in advance!
#define ARM_MATH_CM0PLUS
#include <SPI.h>
#include  <ADE9153A.h>
#include <ADE9153AAPI.h>
/*Basic initializations*/
ADE9153AClass ade9153A;
#define SPI_SPEED 1000000     //SPI Speed
#define CS_PIN 16              //8-->Arduino Zero. 15-->ESP8266
#define ADE9153A_RESET_PIN 2  //On-board Reset Pin 4
#define USER_INPUT 0          //On-board User Input Button Pin 5 ESP8266---> 0
#define LED 6                 //On-board LED pin 6
//#define ADE9153A_RUN_ON 0x0001      /*DSP On*/
//#define REG_RUN      0x0480    /* Write this register to 1 to start the measurements. */
//#define REG_VERSION      0x04FE    /* Version of the ADE9153 IC. */
EnergyRegs energyVals;  //Energy register values are read and stored in EnergyRegs structure
PowerRegs powerVals;    //Metrology data can be accessed from these structures
RMSRegs rmsVals;
PQRegs pqVals;
AcalRegs acalVals;
Temperature tempVal;
void readandwrite(void);
void resetADE9153A(void);
int ledState = LOW;
int inputState = LOW;
unsigned long lastReport = 0;
const long reportInterval = 2000;
const long blinkInterval = 500;
void setup() {
   /*Pin and serial monitor setup*/
  pinMode(USER_INPUT, INPUT);
  pinMode(ADE9153A_RESET_PIN, OUTPUT);
  digitalWrite(ADE9153A_RESET_PIN, HIGH);
  Serial.begin(115200);
  digitalWrite(CS_PIN, HIGH);    //Set Chip select pin high
  pinMode(CS_PIN, OUTPUT);    //Set Chip select pin as output
  SPI.begin();    //Initiate SPI port
  SPI.beginTransaction(SPISettings(SPI_SPEED,MSBFIRST,SPI_MODE0));    //Setup SPI parameters
  resetADE9153A();            //Reset ADE9153A for clean startup
   delay(1000);
//   digitalWrite(CS_PIN, LOW);
//   SPI.transfer16(REG_RUN);
//   SPI.transfer16(ADE9153A_RUN_ON);
//   digitalWrite(CS_PIN, HIGH);
//    SPI.transfer16(REG_VERSION );
//    int returnData = SPI.transfer16(0);
//Serial.println(returnData);
     /*SPI initialization and test*/
  bool commscheck = ade9153A.SPI_Init(SPI_SPEED,CS_PIN); //Initialize SPI
  if (!commscheck) {
    Serial.println("ADE9153A Shield not detected. Plug in Shield and reset the Arduino");
    while (!commscheck) {     //Hold until arduino is reset
      delay(1000);
   ade9153A.SetupADE9153A(); //Setup ADE9153A according to ADE9153AAPI.h
   delay(500);
void loop(){
  //Serial.println("HERE");
   /*Returns metrology to the serial monitor and waits for USER_INPUT button press to run autocal*/
unsigned long currentReport = millis();
  if ((currentReport - lastReport) >= reportInterval){
    lastReport = currentReport;
    readandwrite();
  inputState = digitalRead(USER_INPUT);
  if (inputState == LOW) {
    Serial.println("Autocalibrating Current Channel");
    ade9153A.StartAcal_AINormal();
    runLength(20);
    ade9153A.StopAcal();
    Serial.println("Autocalibrating Voltage Channel");
    ade9153A.StartAcal_AV();
    runLength(40);
    delay(100);
    ade9153A.ReadAcalRegs(&acalVals);
    ade9153A.ApplyAcal(acalVals.AICC, acalVals.AVCC);
    Serial.println("Autocalibration Complete");
    delay(2000);
 digitalWrite(ADE9153A_RESET_PIN, LOW);
 delay(100);
 delay(1000);
 Serial.println("Reset Done");
void readandwrite()
 /*Read and Print Specific Register using ADE9153A SPI Library */
  //Serial.println(ade9153A.SPI_Read_32(REG_AIRMS),HEX); // AIRMS
 /*Read and Print WATT Register using ADE9153A Read Library*/
  ade9153A.ReadPowerRegs(&powerVals);    //Template to read Power registers from ADE9000 and store data in Arduino MCU
  ade9153A.ReadRMSRegs(&rmsVals);
  ade9153A.ReadPQRegs(&pqVals);
  ade9153A.ReadTemperature(&tempVal);
  Serial.print("RMS Current:\t");
  Serial.print(rmsVals.CurrentRMSValue/1000);
  Serial.println(" A");
  Serial.print("RMS Voltage:\t");
  Serial.print(rmsVals.VoltageRMSValue/1000);
  Serial.println(" V");
  Serial.print("Active Power:\t");
  Serial.print(powerVals.ActivePowerValue/1000);
  Serial.println(" W");
  Serial.print("Reactive Power:\t");
  Serial.print(powerVals.FundReactivePowerValue/1000);
  Serial.println(" VAR");
  Serial.print("Apparent Power:\t");
  Serial.print(powerVals.ApparentPowerValue/1000);
  Serial.println(" VA");
  Serial.print("Power Factor:\t");
  Serial.println(pqVals.PowerFactorValue);
  Serial.print("Frequency:\t");
  Serial.print(pqVals.FrequencyValue);
  Serial.println(" Hz");
  Serial.print("Temperature:\t");
  Serial.print(tempVal.TemperatureVal);
  Serial.println(" degC");
  Serial.println("");
  Serial.println("");
void runLength(int seconds)
  unsigned long startTime = millis();
  while (millis() - startTime < (seconds*1000)){
    digitalWrite(LED, HIGH);
    delay(blinkInterval);
    digitalWrite(LED, LOW);
