ADE9000 THDvalue is not working
I want to get the THD value from the ADE9000.
If voltage or current is applied, 400% will be printed; if not, 0% will be displayed.
I used Arduino's register settings and I would like to know if there are any that need to be changed.
I would like to know a register setting example that can check the THD value.
/*Configuration registers*/
#define ADE9000_PGA_GAIN 0x0000 /*PGA@0x0000. Gain of all channels=1*/
#define ADE9000_CONFIG0 0x00000000 /*Integrator disabled*/
#define ADE9000_CONFIG1 0x0002 /*CF3/ZX pin outputs Zero crossing */
#define ADE9000_CONFIG2 0x0C00 /*Default High pass corner frequency of 1.25Hz*/
#define ADE9000_CONFIG3 0x0000 /*Peak and overcurrent detection disabled*/
#define ADE9000_ACCMODE 0x0000 /*60Hz operation, 3P4W Wye configuration, signed accumulation*/
/*Clear bit 8 i.e. ACCMODE=0x00xx for 50Hz operation*/
/*ACCMODE=0x0x9x for 3Wire delta when phase B is used as reference*/
#define ADE9000_TEMP_CFG 0x000C /*Temperature sensor enabled*/
#define ADE9000_ZX_LP_SEL 0x001E /*Line period and zero crossing obtained from combined signals VA,VB and VC*/
#define ADE9000_MASK0 0x00000001 /*Enable EGYRDY interrupt*/
#define ADE9000_MASK1 0x00000000 /*MASK1 interrupts disabled*/
#define ADE9000_EVENT_MASK 0x00000000 /*Events disabled */
#define ADE9000_VLEVEL 0x0022EA28 /*Assuming Vnom=1/2 of full scale.
/*Refer Technical reference manual for detailed calculations.*/
#define ADE9000_DICOEFF 0x00000000 /* Set DICOEFF= 0xFFFFE000 when integrator is enabled*/
/*Constant Definitions***/
#define ADE90xx_FDSP 8000 /*ADE9000 FDSP: 8000sps, ADE9078 FDSP: 4000sps*/
#define ADE9000_RUN_ON 0x0001 /*DSP ON*/
/*Energy Accumulation Settings*/
#define ADE9000_EP_CFG 0x0011 /*Enable energy accumulation, accumulate samples at 8ksps*/
/*latch energy accumulation after EGYRDY*/
/*If accumulation is changed to half line cycle mode, change EGY_TIME*/
#define ADE9000_EGY_TIME 0x1F3F /*Accumulate 8000 samples*/
ADE9K_Write16(ADDR_PGA_GAIN,ADE9000_PGA_GAIN);
ADE9K_Write32(ADDR_CONFIG0,ADE9000_CONFIG0);
ADE9K_Write16(ADDR_CONFIG1,ADE9000_CONFIG1);
ADE9K_Write16(ADDR_CONFIG2,ADE9000_CONFIG2);
ADE9K_Write16(ADDR_CONFIG3,ADE9000_CONFIG3);
ADE9K_Write16(ADDR_ACCMODE,ADE9000_ACCMODE);
ADE9K_Write16(ADDR_TEMP_CFG,ADE9000_TEMP_CFG);
ADE9K_Write16(ADDR_ZX_LP_SEL,ADE9000_ZX_LP_SEL);
ADE9K_Write32(ADDR_MASK0,ADE9000_MASK0);
ADE9K_Write32(ADDR_MASK1,ADE9000_MASK1);
ADE9K_Write32(ADDR_EVENT_MASK,ADE9000_EVENT_MASK);
ADE9K_Write16(ADDR_WFB_CFG,ADE9000_WFB_CFG);
ADE9K_Write32(ADDR_VLEVEL,ADE9000_VLEVEL);
ADE9K_Write32(ADDR_DICOEFF,ADE9000_DICOEFF);
ADE9K_Write16(ADDR_EGY_TIME,ADE9000_EGY_TIME);
ADE9K_Write16(ADDR_EP_CFG,ADE9000_EP_CFG); //Energy accumulation ON
ADE9K_Write16(ADDR_RUN,ADE9000_RUN_ON); //DSP ON
    on Feb 3, 2020 8:45 PM
    this register is updated every sec.
    Can you record multiple readings from THD register in HEX with 1/2 full-scale on the voltage channel at 50 HZ frequency?
    Dave
    on Feb 10, 2020 8:34 PM in reply to huronlab
    I sourced  800mv RMS to the VA and VN pins (0x4212EF4 VARMS register) to the VA channel with distortion causing a 2.8% error in my THD.
    I am attaching the register setting for all register 50 and 60 hz .
    Please try to use there settings.
    search for AVTHD for my readings
    ade9000_60.txt
    Window name:The below data is the result of reading all registers
    Tab name:Read all registers
    Description:Register_read_write_main
    2/10/2020  3:23:21 PM
    File name:ade9000_60.txt
    Notes:These are the notes
    Name	Address	Length (bytes)	Hex Data	Decimal Data
    AIGAIN	0x0	4	0x0	0
    AIGAIN0	0x1	4	0x0	0
    AIGAIN1	0x2	4	0x0	0
    AIGAIN2	0x3	4	0x0	0
    AIGAIN3	0x4	4	0x0	0
    AIGAIN4	0x5	4	0x0	0
    APHCAL0	0x6	4	0x0	0
    APHCAL1	0x7	4	0x0	0
    APHCAL2	0x8	4	0x0	0
    APHCAL3	0x9	4	0x0	0
    APHCAL4	0xA	4	0x0	0
    AVGAIN	0xB	4	0x0	0
    AIRMSOS	0xC	4	0x0	0
    AVRMSOS	0xD	4	0x0	0
    APGAIN	0xE	4	0x0	0
    AWATTOS	0xF	4	0x0	0
    AVAROS	0x10	4	0x0	0
    AFWATTOS	0x11	4	0x0	0
    AFVAROS	0x12	4	0x0	0
    AIFRMSOS	0x13	4	0x0	0
    AVFRMSOS	0x14	4	0x0	0
    AVRMSONEOS	0x15	4	0x0	0
    AIRMSONEOS	0x16	4	0x0	0
    AVRMS1012OS	0x17	4	0x0	0
    AIRMS1012OS	0x18	4	0x0	0
    BIGAIN	0x20	4	0x0	0
    BIGAIN0	0x21	4	0x0	0
    BIGAIN1	0x22	4	0x0	0
    BIGAIN2	0x23	4	0x0	0
    BIGAIN3	0x24	4	0x0	0
    BIGAIN4	0x25	4	0x0	0
    BPHCAL0	0x26	4	0x0	0
    BPHCAL1	0x27	4	0x0	0
    BPHCAL2	0x28	4	0x0	0
    BPHCAL3	0x29	4	0x0	0
    BPHCAL4	0x2A	4	0x0	0
    BVGAIN	0x2B	4	0x0	0
    BIRMSOS	0x2C	4	0x0	0
    BVRMSOS	0x2D	4	0x0	0
    BPGAIN	0x2E	4	0x0	0
    BWATTOS	0x2F	4	0x0	0
    BVAROS	0x30	4	0x0	0
    BFWATTOS	0x31	4	0x0	0
    BFVAROS	0x32	4	0x0	0
    BIFRMSOS	0x33	4	0x0	0
    BVFRMSOS	0x34	4	0x0	0
    BVRMSONEOS	0x35	4	0x0	0
    BIRMSONEOS	0x36	4	0x0	0
    BVRMS1012OS	0x37	4	0x0	0
    BIRMS1012OS	0x38	4	0x0	0
    CIGAIN	0x40	4	0x0	0
    CIGAIN0	0x41	4	0x0	0
    CIGAIN1	0x42	4	0x0	0
    CIGAIN2	0x43	4	0x0	0
    CIGAIN3	0x44	4	0x0	0
    CIGAIN4	0x45	4	0x0	0
    CPHCAL0	0x46	4	0x0	0
    CPHCAL1	0x47	4	0x0	0
    CPHCAL2	0x48	4	0x0	0
    CPHCAL3	0x49	4	0x0	0
    CPHCAL4	0x4A	4	0x0	0
    CVGAIN	0x4B	4	0x0	0
    CIRMSOS	0x4C	4	0x0	0
    CVRMSOS	0x4D	4	0x0	0
    CPGAIN	0x4E	4	0x0	0
    CWATTOS	0x4F	4	0x0	0
    CVAROS	0x50	4	0x0	0
    CFWATTOS	0x51	4	0x0	0
    CFVAROS	0x52	4	0x0	0
    CIFRMSOS	0x53	4	0x0	0
    CVFRMSOS	0x54	4	0x0	0
    CVRMSONEOS	0x55	4	0x0	0
    CIRMSONEOS	0x56	4	0x0	0
    CVRMS1012OS	0x57	4	0x0	0
    CIRMS1012OS	0x58	4	0x0	0
    CONFIG0	0x60	4	0x0	0
    MTTHR_L0	0x61	4	0x0	0
    MTTHR_L1	0x62	4	0x0	0
    MTTHR_L2	0x63	4	0x0	0
    MTTHR_L3	0x64	4	0x0	0
    MTTHR_L4	0x65	4	0x0	0
    MTTHR_H0	0x66	4	0x0	0
    MTTHR_H1	0x67	4	0x0	0
    MTTHR_H2	0x68	4	0x0	0
    MTTHR_H3	0x69	4	0x0	0
    MTTHR_H4	0x6A	4	0x0	0
    NIRMSOS	0x6B	4	0x0	0
    ISUMRMSOS	0x6C	4	0x0	0
    NIGAIN	0x6D	4	0x0	0
    NPHCAL	0x6E	4	0x0	0
    NIRMSONEOS	0x6F	4	0x0	0
    NIRMS1012OS	0x70	4	0x0	0
    VNOM	0x71	4	0x0	0
    DICOEFF	0x72	4	0x0	0
    ISUMLVL	0x73	4	0x0	0
    AI_PCF	0x20A	4	0x2E0	736
    AV_PCF	0x20B	4	0x13CF50B	20772107
    AIRMS	0x20C	4	0x0	0
    AVRMS	0x20D	4	0x4211BC5	69278661
    AIFRMS	0x20E	4	0x20	32
    AVFRMS	0x20F	4	0x420B25B	69251675
    AWATT	0x210	4	0x9	9
    AVAR	0x211	4	0xB	11
    AVA	0x212	4	0x0	0
    AFWATT	0x213	4	0xA	10
    AFVAR	0x214	4	0xD	13
    AFVA	0x215	4	0x11	17
    APF	0x216	4	0x8000000	134217728
    AVTHD	0x217	4	0x393A45	3750469
    AITHD	0x218	4	0x0	0
    AIRMSONE	0x219	4	0x1D1	465
    AVRMSONE	0x21A	4	0x4212465	69280869
    AIRMS1012	0x21B	4	0x164	356
    AVRMS1012	0x21C	4	0x4211C39	69278777
    AMTREGION	0x21D	4	0xF	15
    BI_PCF	0x22A	4	0x170	368
    BV_PCF	0x22B	4	0x2A9	681
    BIRMS	0x22C	4	0x0	0
    BVRMS	0x22D	4	0x0	0
    BIFRMS	0x22E	4	0x33	51
    BVFRMS	0x22F	4	0x17	23
    BWATT	0x230	4	0x0	0
    BVAR	0x231	4	0x0	0
    BVA	0x232	4	0x0	0
    BFWATT	0x233	4	0x0	0
    BFVAR	0x234	4	0x0	0
    BFVA	0x235	4	0x0	0
    BPF	0x236	4	0x8000000	134217728
    BVTHD	0x237	4	0x0	0
    BITHD	0x238	4	0x0	0
    BIRMSONE	0x239	4	0x14D	333
    BVRMSONE	0x23A	4	0x144	324
    BIRMS1012	0x23B	4	0x153	339
    BVRMS1012	0x23C	4	0x145	325
    BMTREGION	0x23D	4	0xF	15
    CI_PCF	0x24A	4	0x1A0	416
    CV_PCF	0x24B	4	0xFFFFFF89	-119
    CIRMS	0x24C	4	0x0	0
    CVRMS	0x24D	4	0x0	0
    CIFRMS	0x24E	4	0x10	16
    CVFRMS	0x24F	4	0x17	23
    CWATT	0x250	4	0x0	0
    CVAR	0x251	4	0x0	0
    CVA	0x252	4	0x0	0
    CFWATT	0x253	4	0x0	0
    CFVAR	0x254	4	0x0	0
    CFVA	0x255	4	0x0	0
    CPF	0x256	4	0x8000000	134217728
    CVTHD	0x257	4	0x0	0
    CITHD	0x258	4	0x0	0
    CIRMSONE	0x259	4	0x148	328
    CVRMSONE	0x25A	4	0x13C	316
    CIRMS1012	0x25B	4	0x16D	365
    CVRMS1012	0x25C	4	0x142	322
    CMTREGION	0x25D	4	0xF	15
    NI_PCF	0x265	4	0x40	64
    NIRMS	0x266	4	0x0	0
    NIRMSONE	0x267	4	0x152	338
    NIRMS1012	0x268	4	0x14F	335
    ISUMRMS	0x269	4	0x16A	362
    VERSION2	0x26A	4	0xC	12
    AWATT_ACC	0x2E5	4	0x0	0
    AWATTHR_LO	0x2E6	4	0x299	665
    AWATTHR_HI	0x2E7	4	0x60D5	24789
    AVAR_ACC	0x2EF	4	0x0	0
    AVARHR_LO	0x2F0	4	0x1C02	7170
    AVARHR_HI	0x2F1	4	0x9383	37763
    AVA_ACC	0x2F9	4	0x0	0
    AVAHR_LO	0x2FA	4	0x1DDC	7644
    AVAHR_HI	0x2FB	4	0x154FE5	1396709
    AFWATT_ACC	0x303	4	0x0	0
    AFWATTHR_LO	0x304	4	0x914	2324
    AFWATTHR_HI	0x305	4	0x60D1	24785
    AFVAR_ACC	0x30D	4	0x0	0
    AFVARHR_LO	0x30E	4	0xCC	204
    AFVARHR_HI	0x30F	4	0x9350	37712
    AFVA_ACC	0x317	4	0x0	0
    AFVAHR_LO	0x318	4	0x13B5	5045
    AFVAHR_HI	0x319	4	0x1554C	87372
    BWATT_ACC	0x321	4	0x0	0
    BWATTHR_LO	0x322	4	0x1EA9	7849
    BWATTHR_HI	0x323	4	0xFFFFFDC3	-573
    BVAR_ACC	0x32B	4	0x0	0
    BVARHR_LO	0x32C	4	0x0	0
    BVARHR_HI	0x32D	4	0x0	0
    BVA_ACC	0x335	4	0x0	0
    BVAHR_LO	0x336	4	0x989	2441
    BVAHR_HI	0x337	4	0x344	836
    BFWATT_ACC	0x33F	4	0x0	0
    BFWATTHR_LO	0x340	4	0x0	0
    BFWATTHR_HI	0x341	4	0x0	0
    BFVAR_ACC	0x349	4	0x0	0
    BFVARHR_LO	0x34A	4	0x0	0
    BFVARHR_HI	0x34B	4	0x0	0
    BFVA_ACC	0x353	4	0x0	0
    BFVAHR_LO	0x354	4	0x0	0
    BFVAHR_HI	0x355	4	0x0	0
    CWATT_ACC	0x35D	4	0x0	0
    CWATTHR_LO	0x35E	4	0x0	0
    CWATTHR_HI	0x35F	4	0x0	0
    CVAR_ACC	0x367	4	0x0	0
    CVARHR_LO	0x368	4	0x0	0
    CVARHR_HI	0x369	4	0x0	0
    CVA_ACC	0x371	4	0x0	0
    CVAHR_LO	0x372	4	0x0	0
    CVAHR_HI	0x373	4	0x0	0
    CFWATT_ACC	0x37B	4	0x0	0
    CFWATTHR_LO	0x37C	4	0x0	0
    CFWATTHR_HI	0x37D	4	0x0	0
    CFVAR_ACC	0x385	4	0x0	0
    CFVARHR_LO	0x386	4	0x0	0
    CFVARHR_HI	0x387	4	0x0	0
    CFVA_ACC	0x38F	4	0x0	0
    CFVAHR_LO	0x390	4	0x0	0
    CFVAHR_HI	0x391	4	0x0	0
    PWATT_ACC	0x397	4	0x0	0
    NWATT_ACC	0x39B	4	0x0	0
    PVAR_ACC	0x39F	4	0x0	0
    NVAR_ACC	0x3A3	4	0x0	0
    IPEAK	0x400	4	0x0	0
    VPEAK	0x401	4	0x0	0
    STATUS0	0x402	4	0x13E807F	20873343
    STATUS1	0x403	4	0x404F7FF	67434495
    EVENT_STATUS	0x404	4	0xFC00	64512
    MASK0	0x405	4	0x20000	131072
    MASK1	0x406	4	0x0	0
    EVENT_MASK	0x407	4	0x0	0
    OILVL	0x409	4	0xFFFFFF	16777215
    OIA	0x40A	4	0x0	0
    OIB	0x40B	4	0x0	0
    OIC	0x40C	4	0x0	0
    OIN	0x40D	4	0x0	0
    USER_PERIOD	0x40E	4	0x500000	5242880
    VLEVEL	0x40F	4	0x117514	1144084
    DIP_LVL	0x410	4	0x0	0
    DIPA	0x411	4	0x7FFFFF	8388607
    DIPB	0x412	4	0x7FFFFF	8388607
    DIPC	0x413	4	0x7FFFFF	8388607
    SWELL_LVL	0x414	4	0xFFFFFF	16777215
    SWELLA	0x415	4	0x0	0
    SWELLB	0x416	4	0x0	0
    SWELLC	0x417	4	0x0	0
    APERIOD	0x418	4	0x854FDB	8736731
    BPERIOD	0x419	4	0x855555	8738133
    CPERIOD	0x41A	4	0x855555	8738133
    COM_PERIOD	0x41B	4	0x854FDF	8736735
    ACT_NL_LVL	0x41C	4	0xFFFF	65535
    REACT_NL_LVL	0x41D	4	0xFFFF	65535
    APP_NL_LVL	0x41E	4	0xFFFF	65535
    PHNOLOAD	0x41F	4	0x3FFFF	262143
    WTHR	0x420	4	0xFFFF	65535
    VARTHR	0x421	4	0xFFFF	65535
    VATHR	0x422	4	0xFFFF	65535
    LAST_DATA_32	0x423	4	0xFFFF	65535
    ADC_REDIRECT	0x424	4	0x1FFFFF	2097151
    CF_LCFG	0x425	4	0x0	0
    PART_ID	0x472	4	0xE0100A97	3759147671
    TEMP_TRIM	0x474	4	0x824F497E	2186234238
    RUN	0x480	2	0x1	1
    CONFIG1	0x481	2	0x0	0
    ANGL_VA_VB	0x482	2	0x50E	1294
    ANGL_VB_VC	0x483	2	0x0	0
    ANGL_VA_VC	0x484	2	0x0	0
    ANGL_VA_IA	0x485	2	0x16D3	5843
    ANGL_VB_IB	0x486	2	0xAFD2	45010
    ANGL_VC_IC	0x487	2	0x0	0
    ANGL_IA_IB	0x488	2	0xB00	2816
    ANGL_IB_IC	0x489	2	0x18C1	6337
    ANGL_IA_IC	0x48A	2	0x4D80	19840
    DIP_CYC	0x48B	2	0xFFFF	65535
    SWELL_CYC	0x48C	2	0xFFFF	65535
    OISTATUS	0x48F	2	0x0	0
    CFMODE	0x490	2	0xF000	61440
    COMPMODE	0x491	2	0x0	0
    ACCMODE	0x492	2	0x100	256
    CONFIG3	0x493	2	0xF000	61440
    CF1DEN	0x494	2	0xFFFF	65535
    CF2DEN	0x495	2	0xFFFF	65535
    CF3DEN	0x496	2	0xFFFF	65535
    CF4DEN	0x497	2	0xFFFF	65535
    ZXTOUT	0x498	2	0xFFFF	65535
    ZXTHRSH	0x499	2	0x9	9
    ZX_LP_SEL	0x49A	2	0x1E	30
    SEQ_CYC	0x49C	2	0xFF	255
    PHSIGN	0x49D	2	0x0	0
    WFB_CFG	0x4A0	2	0x2F0	752
    WFB_PG_IRQEN	0x4A1	2	0x8080	32896
    WFB_TRG_CFG	0x4A2	2	0x0	0
    WFB_TRG_STAT	0x4A3	2	0xD000	53248
    CONFIG5	0x4A4	2	0x63	99
    CRC_RSLT	0x4A8	2	0x6686	26246
    CRC_SPI	0x4A9	2	0x4DCD	19917
    LAST_DATA_16	0x4AC	2	0x4DCD	19917
    LAST_CMD	0x4AE	2	0x4A98	19096
    CONFIG2	0x4AF	2	0xC00	3072
    EP_CFG	0x4B0	2	0x1	1
    PWR_TIME	0x4B1	2	0xFF	255
    EGY_TIME	0x4B2	2	0xFF	255
    CRC_FORCE	0x4B4	2	0x0	0
    CRC_OPTEN	0x4B5	2	0x0	0
    TEMP_CFG	0x4B6	2	0x0	0
    TEMP_RSLT	0x4B7	2	0x0	0
    PSM2_CFG	0x4B8	2	0x1F	31
    PGA_GAIN	0x4B9	2	0x0	0
    CHNL_DIS	0x4BA	2	0x0	0
    WR_LOCK	0x4BF	2	0x0	0
    VAR_DIS	0x4E0	2	0x0	0
    RESERVED1	0x4F0	2	0x874	2164
    VERSION	0x4FE	2	0xFE	254
    AI_SINC_DAT	0x500	4	0xDD80	56704
    AV_SINC_DAT	0x501	4	0x416C7A0	68601760
    BI_SINC_DAT	0x502	4	0xFFFF6AB0	-38224
    BV_SINC_DAT	0x503	4	0xFFFFB7D0	-18480
    CI_SINC_DAT	0x504	4	0xFFFEBF30	-82128
    CV_SINC_DAT	0x505	4	0xFFFFCE30	-12752
    NI_SINC_DAT	0x506	4	0xFFFFC430	-15312
    AI_LPF_DAT	0x510	4	0xF230	62000
    AV_LPF_DAT	0x511	4	0x682B10	6826768
    BI_LPF_DAT	0x512	4	0xFFFF58E0	-42784
    BV_LPF_DAT	0x513	4	0xFFFFAFD0	-20528
    CI_LPF_DAT	0x514	4	0xFFFE9840	-92096
    CV_LPF_DAT	0x515	4	0xFFFFC710	-14576
    NI_LPF_DAT	0x516	4	0xFFFFB9F0	-17936
    AV_PCF_1	0x600	4	0xFBEABA98	-68502888
    BV_PCF_1	0x601	4	0xFFFFFE29	-471
    CV_PCF_1	0x602	4	0xA2	162
    NI_PCF_1	0x603	4	0x210	528
    AI_PCF_1	0x604	4	0x60	96
    BI_PCF_1	0x605	4	0x110	272
    CI_PCF_1	0x606	4	0x2F0	752
    AIRMS_1	0x607	4	0x0	0
    BIRMS_1	0x608	4	0x0	0
    CIRMS_1	0x609	4	0x0	0
    AVRMS_1	0x60A	4	0x4211A1E	69278238
    BVRMS_1	0x60B	4	0x0	0
    CVRMS_1	0x60C	4	0x0	0
    NIRMS_1	0x60D	4	0x0	0
    AWATT_1	0x60E	4	0x9	9
    BWATT_1	0x60F	4	0x0	0
    CWATT_1	0x610	4	0x0	0
    AVA_1	0x611	4	0x0	0
    BVA_1	0x612	4	0x0	0
    CVA_1	0x613	4	0x0	0
    AVAR_1	0x614	4	0x19	25
    BVAR_1	0x615	4	0x0	0
    CVAR_1	0x616	4	0x0	0
    AFVAR_1	0x617	4	0xD	13
    BFVAR_1	0x618	4	0x0	0
    CFVAR_1	0x619	4	0x0	0
    APF_1	0x61A	4	0x8000000	134217728
    BPF_1	0x61B	4	0x8000000	134217728
    CPF_1	0x61C	4	0x8000000	134217728
    AVTHD_1	0x61D	4	0x393A45	3750469
    BVTHD_1	0x61E	4	0x0	0
    CVTHD_1	0x61F	4	0x0	0
    AITHD_1	0x620	4	0x0	0
    BITHD_1	0x621	4	0x0	0
    CITHD_1	0x622	4	0x0	0
    AFWATT_1	0x623	4	0xA	10
    BFWATT_1	0x624	4	0x0	0
    CFWATT_1	0x625	4	0x0	0
    AFVA_1	0x626	4	0x11	17
    BFVA_1	0x627	4	0x0	0
    CFVA_1	0x628	4	0x0	0
    AFIRMS_1	0x629	4	0x20	32
    BFIRMS_1	0x62A	4	0x33	51
    CFIRMS_1	0x62B	4	0x24	36
    AFVRMS_1	0x62C	4	0x420B1A7	69251495
    BFVRMS_1	0x62D	4	0x17	23
    CFVRMS_1	0x62E	4	0x17	23
    AIRMSONE_1	0x62F	4	0x14E	334
    BIRMSONE_1	0x630	4	0x167	359
    CIRMSONE_1	0x631	4	0x17F	383
    AVRMSONE_1	0x632	4	0x4211DFC	69279228
    BVRMSONE_1	0x633	4	0x14D	333
    CVRMSONE_1	0x634	4	0x15E	350
    NIRMSONE_1	0x635	4	0x14A	330
    AIRMS1012_1	0x636	4	0x164	356
    BIRMS1012_1	0x637	4	0x153	339
    CIRMS1012_1	0x638	4	0x16D	365
    AVRMS1012_1	0x639	4	0x4211C39	69278777
    BVRMS1012_1	0x63A	4	0x145	325
    CVRMS1012_1	0x63B	4	0x142	322
    NIRMS1012_1	0x63C	4	0x14F	335
    AV_PCF_2	0x680	4	0x4B1F7A	4923258
    AI_PCF_2	0x681	4	0x270	624
    AIRMS_2	0x682	4	0x0	0
    AVRMS_2	0x683	4	0x4211C63	69278819
    AWATT_2	0x684	4	0x8	8
    AVA_2	0x685	4	0x0	0
    AVAR_2	0x686	4	0x1B	27
    AFVAR_2	0x687	4	0xD	13
    APF_2	0x688	4	0x8000000	134217728
    AVTHD_2	0x689	4	0x393A45	3750469
    AITHD_2	0x68A	4	0x0	0
    AFWATT_2	0x68B	4	0xF	15
    AFVA_2	0x68C	4	0x19	25
    AFIRMS_2	0x68D	4	0x30	48
    AFVRMS_2	0x68E	4	0x420B14F	69251407
    AIRMSONE_2	0x68F	4	0x138	312
    AVRMSONE_2	0x690	4	0x42116FC	69277436
    AIRMS1012_2	0x691	4	0x164	356
    AVRMS1012_2	0x692	4	0x4211C39	69278777
    BV_PCF_2	0x693	4	0x269	617
    BI_PCF_2	0x694	4	0x1D0	464
    BIRMS_2	0x695	4	0x0	0
    BVRMS_2	0x696	4	0x0	0
    BWATT_2	0x697	4	0x0	0
    BVA_2	0x698	4	0x0	0
    BVAR_2	0x699	4	0x0	0
    BFVAR_2	0x69A	4	0x0	0
    BPF_2	0x69B	4	0x8000000	134217728
    BVTHD_2	0x69C	4	0x0	0
    BITHD_2	0x69D	4	0x0	0
    BFWATT_2	0x69E	4	0x0	0
    BFVA_2	0x69F	4	0x0	0
    BFIRMS_2	0x6A0	4	0x33	51
    BFVRMS_2	0x6A1	4	0x17	23
    BIRMSONE_2	0x6A2	4	0x16D	365
    BVRMSONE_2	0x6A3	4	0x152	338
    BIRMS1012_2	0x6A4	4	0x153	339
    BVRMS1012_2	0x6A5	4	0x145	325
    CV_PCF_2	0x6A6	4	0x17C	380
    CI_PCF_2	0x6A7	4	0xFFFFFF30	-208
    CIRMS_2	0x6A8	4	0x0	0
    CVRMS_2	0x6A9	4	0x0	0
    CWATT_2	0x6AA	4	0x0	0
    CVA_2	0x6AB	4	0x0	0
    CVAR_2	0x6AC	4	0x0	0
    CFVAR_2	0x6AD	4	0x0	0
    CPF_2	0x6AE	4	0x8000000	134217728
    CVTHD_2	0x6AF	4	0x0	0
    CITHD_2	0x6B0	4	0x0	0
    CFWATT_2	0x6B1	4	0x0	0
    CFVA_2	0x6B2	4	0x0	0
    CFIRMS_2	0x6B3	4	0x24	36
    CFVRMS_2	0x6B4	4	0x17	23
    CIRMSONE_2	0x6B5	4	0x143	323
    CVRMSONE_2	0x6B6	4	0x182	386
    CIRMS1012_2	0x6B7	4	0x16D	365
    CVRMS1012_2	0x6B8	4	0x142	322
    NI_PCF_2	0x6B9	4	0x180	384
    NIRMS_2	0x6BA	4	0x0	0
    NIRMSONE_2	0x6BB	4	0x15B	347
    NIRMS1012_2	0x6BC	4	0x14F	335
    ade9000_50.txt
    2/10/2020  3:21:40 PM
    File name:ade9000.txt
    AIGAIN	0x0	4	0x0	0
    AIGAIN0	0x1	4	0x0	0
    AIGAIN1	0x2	4	0x0	0
    AIGAIN2	0x3	4	0x0	0
    AIGAIN3	0x4	4	0x0	0
    AIGAIN4	0x5	4	0x0	0
    APHCAL0	0x6	4	0x0	0
    APHCAL1	0x7	4	0x0	0
    APHCAL2	0x8	4	0x0	0
    APHCAL3	0x9	4	0x0	0
    APHCAL4	0xA	4	0x0	0
    AVGAIN	0xB	4	0x0	0
    AIRMSOS	0xC	4	0x0	0
    AVRMSOS	0xD	4	0x0	0
    APGAIN	0xE	4	0x0	0
    AWATTOS	0xF	4	0x0	0
    AVAROS	0x10	4	0x0	0
    BIGAIN	0x20	4	0x0	0
    BVGAIN	0x2B	4	0x0	0
    BPGAIN	0x2E	4	0x0	0
    BVAROS	0x30	4	0x0	0
    CIGAIN	0x40	4	0x0	0
    CVGAIN	0x4B	4	0x0	0
    CPGAIN	0x4E	4	0x0	0
    CVAROS	0x50	4	0x0	0
    NIGAIN	0x6D	4	0x0	0
    NPHCAL	0x6E	4	0x0	0
    VNOM	0x71	4	0x0	0
    AI_PCF	0x20A	4	0x270	624
    AV_PCF	0x20B	4	0x2FF251A	50275610
    AIRMS	0x20C	4	0x0	0
    AVRMS	0x20D	4	0x420B36B	69251947
    AIFRMS	0x20E	4	0x10	16
    AVFRMS	0x20F	4	0x420486B	69224555
    AWATT	0x210	4	0xD	13
    AVAR	0x211	4	0xFFFFFFFD	-3
    AVA	0x212	4	0x0	0
    AFWATT	0x213	4	0x6	6
    AFVAR	0x214	4	0xFFFFFFFA	-6
    AFVA	0x215	4	0x8	8
    AVTHD	0x217	4	0x38D0C4	3723460
    AITHD	0x218	4	0x0	0
    AIRMSONE	0x219	4	0x157	343
    AVRMSONE	0x21A	4	0x420B0AE	69251246
    AIRMS1012	0x21B	4	0x15E	350
    AVRMS1012	0x21C	4	0x420B18B	69251467
    BI_PCF	0x22A	4	0x210	528
    BV_PCF	0x22B	4	0x201	513
    BIRMS	0x22C	4	0x0	0
    BVRMS	0x22D	4	0x0	0
    BIFRMS	0x22E	4	0x20	32
    BVFRMS	0x22F	4	0x0	0
    BWATT	0x230	4	0x0	0
    BVAR	0x231	4	0x0	0
    BVA	0x232	4	0x0	0
    BFVAR	0x234	4	0x0	0
    BFVA	0x235	4	0x0	0
    BVTHD	0x237	4	0x0	0
    BITHD	0x238	4	0x0	0
    BIRMSONE	0x239	4	0x15D	349
    BVRMSONE	0x23A	4	0x115	277
    BIRMS1012	0x23B	4	0x160	352
    BVRMS1012	0x23C	4	0x14C	332
    CI_PCF	0x24A	4	0x3B0	944
    CV_PCF	0x24B	4	0x1EA	490
    CIRMS	0x24C	4	0x0	0
    CVRMS	0x24D	4	0x0	0
    CVFRMS	0x24F	4	0x24	36
    CWATT	0x250	4	0x0	0
    CVAR	0x251	4	0x0	0
    CVA	0x252	4	0x0	0
    CFVAR	0x254	4	0x0	0
    CFVA	0x255	4	0x0	0
    CVTHD	0x257	4	0x0	0
    CITHD	0x258	4	0x0	0
    CIRMSONE	0x259	4	0x1EB	491
    CVRMSONE	0x25A	4	0x117	279
    CIRMS1012	0x25B	4	0x165	357
    CVRMS1012	0x25C	4	0x151	337
    NI_PCF	0x265	4	0xFFFFFF80	-128
    NIRMS	0x266	4	0x0	0
    NIRMSONE	0x267	4	0x165	357
    NIRMS1012	0x268	4	0x16E	366
    ISUMRMS	0x269	4	0x200	512
    AVAR_ACC	0x2EF	4	0xFFFFFFFF	-1
    AFVAR_ACC	0x30D	4	0xFFFFFFFF	-1
    IPEAK	0x400	4	0x0	0
    VPEAK	0x401	4	0x0	0
    MASK1	0x406	4	0x0	0
    OIA	0x40A	4	0x0	0
    OIB	0x40B	4	0x0	0
    OIC	0x40C	4	0x0	0
    OIN	0x40D	4	0x0	0
    VLEVEL	0x40F	4	0x45D45	286021
    APERIOD	0x418	4	0x9FF684	10483332
    BPERIOD	0x419	4	0xA00000	10485760
    CPERIOD	0x41A	4	0xA00000	10485760
    COM_PERIOD	0x41B	4	0x9FF67D	10483325
    RUN	0x480	2	0x1	1
    ANGL_VA_IA	0x485	2	0x293	659
    ANGL_IA_IB	0x488	2	0x15BF	5567
    ANGL_IB_IC	0x489	2	0x2F80	12160
    ANGL_IA_IC	0x48A	2	0x6ABF	27327
    ACCMODE	0x492	2	0x0	0
    PHSIGN	0x49D	2	0x2	2
    WFB_TRG_STAT	0x4A3	2	0xE000	57344
    CRC_RSLT	0x4A8	2	0xD6B5	54965
    CRC_SPI	0x4A9	2	0x55F0	22000
    LAST_DATA_16	0x4AC	2	0x55F0	22000
    RESERVED1	0x4F0	2	0x22D	557
    AI_SINC_DAT	0x500	4	0xDBC0	56256
    AV_SINC_DAT	0x501	4	0x4B134D0	78722256
    BI_SINC_DAT	0x502	4	0xFFFF6710	-39152
    BV_SINC_DAT	0x503	4	0xFFFFB980	-18048
    CI_SINC_DAT	0x504	4	0xFFFEBDD0	-82480
    CV_SINC_DAT	0x505	4	0xFFFFCA40	-13760
    NI_SINC_DAT	0x506	4	0xFFFFC7F0	-14352
    AI_LPF_DAT	0x510	4	0xF5E0	62944
    AV_LPF_DAT	0x511	4	0x58D52D0	93147856
    BI_LPF_DAT	0x512	4	0xFFFF56C0	-43328
    BV_LPF_DAT	0x513	4	0xFFFFB0C0	-20288
    CI_LPF_DAT	0x514	4	0xFFFE9940	-91840
    CV_LPF_DAT	0x515	4	0xFFFFCAB0	-13648
    NI_LPF_DAT	0x516	4	0xFFFFC200	-15872
    AV_PCF_1	0x600	4	0x3F3A097	66298007
    BV_PCF_1	0x601	4	0xE8	232
    CV_PCF_1	0x602	4	0xFFFFFE93	-365
    NI_PCF_1	0x603	4	0xA0	160
    AI_PCF_1	0x604	4	0x150	336
    BI_PCF_1	0x605	4	0xFFFFFFA0	-96
    CI_PCF_1	0x606	4	0x1D0	464
    AVRMS_1	0x60A	4	0x420B3A7	69252007
    AWATT_1	0x60E	4	0xB	11
    AVA_1	0x611	4	0x0	0
    BVA_1	0x612	4	0x0	0
    CVA_1	0x613	4	0x0	0
    AVAR_1	0x614	4	0xFFFFFFFE	-2
    AFVAR_1	0x617	4	0xFFFFFFFA	-6
    AVTHD_1	0x61D	4	0x38D0C4	3723460
    AFWATT_1	0x623	4	0x6	6
    AFVA_1	0x626	4	0x8	8
    AFIRMS_1	0x629	4	0x10	16
    BFIRMS_1	0x62A	4	0x10	16
    CFIRMS_1	0x62B	4	0x10	16
    AFVRMS_1	0x62C	4	0x4204861	69224545
    BFVRMS_1	0x62D	4	0x10	16
    CFVRMS_1	0x62E	4	0x24	36
    AIRMSONE_1	0x62F	4	0x172	370
    BIRMSONE_1	0x630	4	0x18D	397
    CIRMSONE_1	0x631	4	0x15F	351
    AVRMSONE_1	0x632	4	0x420B190	69251472
    BVRMSONE_1	0x633	4	0x19B	411
    CVRMSONE_1	0x634	4	0x122	290
    NIRMSONE_1	0x635	4	0x122	290
    AIRMS1012_1	0x636	4	0x15E	350
    BIRMS1012_1	0x637	4	0x160	352
    CIRMS1012_1	0x638	4	0x165	357
    AVRMS1012_1	0x639	4	0x420B18B	69251467
    BVRMS1012_1	0x63A	4	0x14C	332
    CVRMS1012_1	0x63B	4	0x151	337
    NIRMS1012_1	0x63C	4	0x16E	366
    AV_PCF_2	0x680	4	0xFEB306C8	-21821752
    AI_PCF_2	0x681	4	0xFFFFFFE0	-32
    AVRMS_2	0x683	4	0x420B3D9	69252057
    AWATT_2	0x684	4	0xC	12
    AVA_2	0x685	4	0x0	0
    AVAR_2	0x686	4	0xFFFFFFFF	-1
    AFVAR_2	0x687	4	0xFFFFFFFA	-6
    AVTHD_2	0x689	4	0x38D0C4	3723460
    AFWATT_2	0x68B	4	0x6	6
    AFVA_2	0x68C	4	0x8	8
    AFIRMS_2	0x68D	4	0x10	16
    AFVRMS_2	0x68E	4	0x42048D0	69224656
    AIRMSONE_2	0x68F	4	0x159	345
    AVRMSONE_2	0x690	4	0x420B272	69251698
    AIRMS1012_2	0x691	4	0x15E	350
    AVRMS1012_2	0x692	4	0x420B18B	69251467
    BV_PCF_2	0x693	4	0x13	19
    BI_PCF_2	0x694	4	0x290	656
    BVA_2	0x698	4	0x0	0
    BFIRMS_2	0x6A0	4	0x10	16
    BIRMSONE_2	0x6A2	4	0x161	353
    BVRMSONE_2	0x6A3	4	0x146	326
    BIRMS1012_2	0x6A4	4	0x168	360
    BVRMS1012_2	0x6A5	4	0x164	356
    CV_PCF_2	0x6A6	4	0x136	310
    CI_PCF_2	0x6A7	4	0xFFFFFE00	-512
    CVA_2	0x6AB	4	0x0	0
    CFIRMS_2	0x6B3	4	0x10	16
    CIRMSONE_2	0x6B5	4	0x177	375
    CVRMSONE_2	0x6B6	4	0x133	307
    CIRMS1012_2	0x6B7	4	0x17A	378
    CVRMS1012_2	0x6B8	4	0x13F	319
    NI_PCF_2	0x6B9	4	0xFFFFFB00	-1280
    NIRMSONE_2	0x6BB	4	0x12F	303
    NIRMS1012_2	0x6BC	4	0x14E	334
    Dave
