ADE7880 low accuracy in the line cycle accumulation mode while harmonic voltage is in the AC source
   I use ADE7880 to measure AC power energy by using line cycle accumulation mode, and get the good accuracy of xWATTHR in measuring resistance load (PF=1) and motor (PF=0.26).
  While I give the standard 110 AC source with 3-order harmonic voltage of 50% THD on the resistance load, the voltage wave is distorted to  two-peak wave and I get almost
  20% error on the xWATTHR compare with Fluke 434 meter.  Because the resistance load only, the PF is still 1 even the giving distortion voltage.
  I have no idea about what is going on in my measurement and how to explain the situation. May I have any suggestion for this issue? Thank you very much
    on Jan 17, 2020 12:38 PM
    Can you provide more information:
    what is voltage divider values used for voltage channel.
    Are you writing xVgain register?
    Do you get this on all channels?
    There is a good possibility you are railing the modulator. If at 110v the input signal is somewhere near full scale of the ADC then you add on 50% thd you might be railing the input. If you can't do waveform sampling try Vpeak register to capture your peak value.
    Dave
