ADE7878 alternate
Hey guys. I need to replace one IC that has been used in one of the projects. The IC is ADE7878 Energy metering IC that can be used to supply 3 phase active power to the controller for processing.
However, I am looking for its alternate, and I find in the product page for other similar parts and I found ADE9000 to be suitable. Since I am new to analog devices products and energy metering systems, it would be good if you guys give me some suggestions.
I appreciate your suggestions.
Top Replies
  • Hi ,
    The ADE9000 is our advanced multi-phase energy metering solution. The ADE7878A is the enhanced version of ADE7878.
    What kind of application that you want to develop?
    What current sensor that…
  • Hi ,
    What current sensor that you want to use?
    One of the ADE9000 features that is not available in ADE7878 is a power quality measurements, do you need it?
    • Enables implementation of IEC 61000-4-30 Class S
    • VRMS ½, IRMS ½ rms voltage refreshed each half cycle
    • 10 cycle rms/12 cycle rms
    • Dip and swell monitors
    • Line frequency—one per phase
    • Zero crossing, zero-crossing timeout
    • Phase angle measurements
    What do you need to know?
    Best source of documentation would be the datasheet and technical reference manual.
    Kind Regards,
    Nanda
  • Hi Nanda, thanks for you reply.
    Yes I am interested in power quality measurements, but that's an added feature, And I want to know that the features that ADE7878 provides, can those features/specs be achieved by using ADE9000. If that is the case, I can go for ADE9000 with added feature of power quality measurement, but if that is not the case, I will go for ADE7878A.
    I want to have the experts advice.
    Thanks
  • And one more thing I would like to add, actually I need to add a rogowski coil in the project, and as per my knowledge, I just did an overview of the datasheet, and it says that we can integrate rogowski coil with ADE9000. This is in fact the deciding factor.
  • Yes ADE9000 supports Rogowski coil like the ADE7878A. The biggest difference is whether you need the power quality measurements or not in your application.
