Communication problem between ADE 9153A and ESP 8266
Hi;
I am working on ADE-9153A dev board.
I have successfully measured all parameters using Arduino. I have used same code  which is provided by you ( with ADE 9153 lib).
As per your reference manual, we can also use ESP8266 (NODEMCU) board for same purpose.
I have used same Arduino IDE (with ESP8266 board added into board manager).
I populated resistor as per your indication in documentation to make SPI connection , also disconnect 5V SPI jumper. I also changed CS pin as per in program (for ESP) ,But when used Same ADE DEV Board with NODEMCU , There are lots of problems.
- First I faced WDT -Watch Dog Timer error, but finaally I fix it
- But My NODEMCU not communicate with ADE on SPI bus , any other changes require for it ???
I want to use NODEMCU 1.0 with ADE 9153A ?
What are the changes require in Code as well in hardware level ?
Pin you indicated in manual is for HSPI not for SPI, Is it valid ?
Any extra library require ?
Please reply as soon as possible.
If you have any reference design with NODEMCU and ADE 9153A then please also provide it (with code & library).
Require detail explanation....
Thanks
Jaydeep shah
Ahmedabad -India
