Does ADE9000 Arduino Shield has CF1 and CF2 output LEDs? If not, are these pins brought out on the PCB pads are elsewhere?
Thanks
S.Bachhotia
ADE9000
Production
The ADE9000 is a highly accurate, fully integrated, multiphase energy and power quality monitoring device. Superior analog performance and a digital signal...
Datasheet
ADE9000 on Analog.com
Thanks
S.Bachhotia
Hi Sbachhotia, the CFs are not connected thru an LED in the SHIELD.
The Pins with allocated LEDs are as follows:
The Evaluation board for ADE9000 is the one that has CFs connected thru LEDs.
Reference: https://www.analog.com/media/en/technical-documentation/user-guides/EVAL-ADE9000EBZ-UG-1082.pdf
Thank you very much.
Thanks for your answer. Are these pins (CF1 & CF2) are brought out on the PCB in case of shield? If so, i may connect external LEDs.
What are the ASIC configuration you did to enable CF Pulse? Can you please share about register values with details.
Also please tell me that the pulse will be cleared by ASIC itself or we need to clear by MCU by putting GPIO pin High/Low.
There are needed to enable CF output
See datasheet and user guide for an explanation of the registers
CFMODE
CFxDEN
COMPMODE
WTHR There is also a threshold for VAR and VA
EP_CFG needed to enable energy
Dave
