Hi Sirs,
I would like to ask how to calculate the F1 and F2 in case the meter constant to 1600 imp/ kWh ? The calculation in the datasheet is given for 100 imp /kWh but it is not shown how to adapt to other
meter constant value.
Thank you.
f1 and f2 drive a counter typically. There is a fixed division from cf output to f1 and f2. 128,64,32,16,2048
so for example if cf max is:
scf =1 22.4Hz and s1=s0=0 the max freq on f1 and f2 is 22.4/128=0.175hz
scf = 0 11.2hz and s0=s1 the max freq on f1 and f2 is 11.2/64 = 0.175hz
You need to know the counter you are going to use to determine the imp/KWH needed for F1 and F2. Not sure why you would need 1600 ipm/kwh on f1 and f2. The example is for cf output 1600 imp/kwh and f1 f2 100 imp/kwh.
If you are using a micro to count pulses. I would use the cf pin instead if F1 and F2.
https://www.analog.com/media/en/technical-documentation/application-notes/AN-679.pdf
Dave
Thank you for your reply. It helps me to clear the issue.
