Support of C99 in VisualDSP++
Is VisualDSP++ natively supoort for ANSI C99 ?
Im using the types int8_t, uint16_t etc by including <stdint.h> still the compiler showing undifined ..
is any settings or configuration have to do in visualdsp++ ?
Parents
    on Dec 17, 2010 10:18 PM
    I'm afraid the stdint.h header won't change in this regard with the upcoming C99 compiler support. The reason those types are not defined on SHARC is that SHARC is 32-bit word addressed. Therefore the smallest type available is 32 bits wide. The C99 standard requires the intN_t types to be exactly N bits wide though, hence they cannot be defined to wider types. Types that are available in stdint.h include int_leastN_t and int_fastN_t, for which the standard only requires a minimum width.
    If you don't want to replace uses of int8_t and other missing types, you might want to define them to 32-bit integer types yourself. Do keep in mind though that they will not have the same overflow behavior as implied by the standard.
Reply
Children
No Data
