Unstable JTAG connection to target board
Hi
I have the analog devices ADZS-USB-ICE and trying to connect it to the ADSP BF504 on my DSP board.  May be 1 out of 10 times I can establish a connection but most of the time I can't.  Every time it failed to establish a connection I ran ICE test and all the tests passed (i.e.
Openning Emulator Interface -Pass
Resetting ICEPAC module -Pass
Testing ICEPAC memory -Pass
Determinging scan path length - (detects 1 device)
Performing scan test -Continous scan up to 10 Mbytes (Pass)
Even after ICE test passed, I still can not establish a sesstion in VDSP++.  I have checked all the power supply/ground pins, input clock to DSP, reset pin of DSP, PG pin (pull low), and Wake_up pin (high) and they all checked out.  Here are what I have checked:
ADSP BF504 (88pins):
VDDC (core voltate) = 1.2V
VDDIO (I/O voltage) = 2.5V
Reset Pin = Pull up high (10K to 2.5V)
PGn = Ground
clock in (pin 68): 12MHz
XTAL pin = no connection
Visual DSP/Emulator Setup:
Visual DSP++5.0 Update 10 (Product Version 5.0.10.0, IDDE version 8.0.7.15, Build Date: July 5, 2011)
Visual DSP++5.0 License:  Blackfin Demo-Full (Expiring in 37 days)
Visual DSP++5.0 Configuration (Type: USB-ICE, Emulator Settings Device ID: 0, Emulator Settings JTAG I/O Voltage: 2.5, Device 0 Type: ADSP-BF504, initial connection option:  Halt and reset.)
Deleted and installed the driver for the ADSP BF504 and still no help.  Deleted and re-create session and still no help.
Like I said, ICE test always passed but then unable to establish a conection (most of the time) to target board in Visual DSP++5.0 (always getting error code 0x80044005)
Loc
  • Hi Loc,
    we have an FAQ that covers the things we recommend checking on your target, here:
    FAQ:  Why does the ICE Test pass but IDDE cannot connect to target?
    If that does not help, you would need to contact private support so we can take a look at the JTAG portion of your schematics, and help figure out why it will not connect.
    Craig.
    sounds very familiar...but I'm somewhat amazed that the recent VDSP releases still shows the same verbosity like in v3.0 when it comes to JTAG errors...
    There are a few things on my typical JTAG checklist:
    • traces to CPU from JTAG pod less than 7cm
    • no other clock signals (SCLK, SDRAM) near the TCK trace, check for good shielding
    • inserting a clock buffer (schmitt trigger) on TCK improves the HP-ICEs signal and avoids double clocking in noisy environments
    The JTAG pins go directly into the core silicon as far as I remember. So they need extremely sharp edges, means you have to do the typical high speed design even if you only clock TCK with a few MHz.
    Hope those hints help.
    Greetings
    - Martin
    Thank you,
    EZ Admin
