How to use rfft2d_fr16 or rfft2d_fr32 on grayscale images
Product Number: BF-609
Software Version: CCES 2.12.1
I am trying to use rfft2d_fr16 function for FFT, but unaware of what size of images should i use for input buffers and output buffers and temp buffers. If you tell me it will be so helpful and i need sample input and output images to verify my result as per image viewer or array data if it is complex data.
Santhosh
  • Hi Santhosh,
    Thank you for your inquiry.
    You can get the detailed information about this library function and sample code from the below CCES help path
    CrossCore® Embedded Studio 2.12.0 > Blackfin® Development Tools Documentation > C/C++ Compiler and Library Manual for Blackfin® Processors > DSP Run-Time Library > DSP Run-Time Library Reference
    Hope this helps.
    Best Regards,
    Santhakumari.V
  • Hi Santhakumari,
    I worked on rfft2d_fr16() , to validate this I used it's FFT output as input to ifft2d_fr16(), for FFT size 64 , twiddle stride 1, block exponent 12, scale 1 , but I am getting 12 bits scaled while compared input see below
    1) My input is img[64*64 ]={0x7fff,0x7fff,0x7fff,0x7fff,0x7fff,.......0x7fff}
    ifft2d_fr16 output is ={0x7,0x7,0x7,0x7,.......0x7};
    2) My input is img[64*64 ]={0x4000,0x4000,0x4000,0x4000,........0x4000}
    Ifft2d_fr16 output is ={0x4,0x4,0x4,0x4,.......0x4};
    I changed my scaling values in both functions many times as well block exponent values also, but there is no change in ifft out.
    If changed FFT_SIZE to 32 or 16 then output occuring like 8, 6 bit scaling respectively, my question is while I am taking 64*64 input image, should i use only 64 FFT size or other FFT size.
    Another question is can i change my scaling factor .
    Thanks and regards,
    Santhosh
