How to modify for compiling in visual dsp 3.5++
I am trying to build the old project in visual dsp 3.5++ , which was built in development tool 6.1.  In this project there is .dsp file which as following code
MODULE/ABS=0 Driver_Runtime_Header;
.GLOBAL ___lib_prog_term;
.EXTERN ___lib_setup_everything;
.EXTERN _main;
.extern _USBReceiveISR;
.extern _USBTransmitISR;
.extern _FlashISR;
.extern _TimerISR;
.extern _SerialComISR;
__Reset_vector: CALL ___lib_setup_everything;
CALL _main; //{Begin C program}
___lib_prog_term: JUMP ___lib_prog_term; rti;
__Interrupt2: jump _FlashISR; rti;rti;rti;
__InterruptL1: rti; rti;rti;rti;
__InterruptL0: rti; rti;rti;rti;
__Sport0_trans: rti; rti;rti;rti;
__Sport0_recv: rti; rti;rti;rti;
__InterruptE: jump _USBReceiveISR; rti;rti;rti;
__BDMA_interrupt: rti; rti;rti;rti;
__Interrupt1: jump _SerialComISR; rti;rti;rti;
__Interrupt0: jump _USBTransmitISR; rti;rti;rti;
__Timer_interrupt: jump _TimerISR; rti;rti;rti;
__Powerdown_interrupt: rti; rti;rti;rti;
end.mod
Would you please give some suggestion so I can modify and build this code.
How can change .Module/ABS to section ?
I am not able to understand __lib_SetupEverythig?
Please help me to resolve this issues.
