how to add another output sport 5A in example LibIntegrationExample_Core1 of ADSP-21569
Product Number: ADSP-21569
Software Version: 3.0.2
hi , guys
I re-write the code of LibIntegrationExample_Core1 of adsp21569 to fit my customer board , which want to implement sport 0B as receiver and sport 4A ,5A as transmiter,
the code is almost working as I can hear the music when it run, but the music have some noise , can you help check the memory copy in my code to find if there is any issue ?
Copyright (c) 2019-2023 Analog Devices Inc. All rights reserved
This software is proprietary & confidential to Analog Devices, Inc.
and its licensors.
#include <stdio.h>
#include <stdlib.h>
#include <sys/platform.h>
#include <sys/adi_core.h>
#include "adi_initialize.h"
#include <services/int/adi_int.h>
#include <drivers/sport/adi_sport.h>
#include <services/spu/adi_spu.h>
#include <drivers/twi/adi_twi_2156x.h>
#include "ADAU_1962Common.h"
#include "ADAU_1979Common.h"
#include <cdef21569.h>
#include "math.h"
#include <string.h>
#include <sru21569.h>
#include "LibIntegrationExample_Core1.h"
#include <adi_ss_smap.h>
#include "adi_ss_ssn_export_export_DiffDXESchematic_IC_1.h"
#include "adi_ss_utility.h"
#include <services/pcg/adi_pcg.h>
#ifdef DO_CYCLE_COUNTS
#include "cycles.h"
#endif
/******* SigmaStudio Integration ***************/
#define ADI_SS_APP_DELAY_100_MSEC (100 * 10000)
/*Defining Backchannel info structure. Will be populated by the framework */
typedef struct ADI_SS_BACKCH_INFO
    float32_t    nPeakMIPS[ADI_SS_FW_MAX_PROC_BLOCKS]; /*!< Peak MIPS for all process blocks */
    float32_t    nAvgMIPS[ADI_SS_FW_MAX_PROC_BLOCKS];  /*!< Average MIPS for all process blocks */
    uint32_t     nVersionInfo;                  	   /*!< Target library API version */
    uint32_t     nSSnDownloadStatus;            	   /*!< Current download status of SSns within all process blocks*/
}ADI_SS_BACKCH_INFO;
#include "adi_ss_connection.h"
#include "adi_ss_communication.h"
#include "adi_ss_ssn.h"
/* Memory for SigmaStudio for Griffin libraries */
/* Connection and Communication Instance Mem */
#pragma align(4)
#pragma section("ss_app_data0_fast")
uint8_t adi_ss_commn_mem[ADI_SS_COMM_MEMSIZE];
#pragma align(4)
uint8_t adi_ss_connection_mem[ADI_SS_CONNECTION_MEMSIZE];
bool bSportCallback;
volatile uint32_t nSMAPReceived=0;
/* SMAP */
ADI_SS_MEM_SMAP oSMAPSharc0;
ADI_SS_MEM_MAP oSSnMemMap;
/* SSn Config structure */
ADI_SS_CONFIG  *pSSnConfig,oSSnConfig;
/* SSnProperties structure */
ADI_SS_SSNPROPERTIES *pSSnProperties,oSSnProperties;
/* Defining SSn Handle */
ADI_SS_SSN_HANDLE hSSnHandle;
/* Backchannel info */
ADI_SS_BACKCH_INFO 	oBkChannelInfoSharc0;
/* I/O buffer and pointers for SSn instance */
float32_t aSSInOutBuff[BLOCK_SIZE*(NUM_CHANNELS+NUM_CHANNELS2)];
float32_t *pSSInBuff[NUM_CHANNELS+NUM_CHANNELS2];
float32_t *pSSOutBuff[NUM_CHANNELS+NUM_CHANNELS2];
void adi_ss_comm_callback_cmd4(uint32_t  *pCommPayloadBuff,
                               int32_t   nPayloadCount,
                               ADI_SS_SSN_HANDLE hSSn);
void adi_SMAP_Application_Callback(ADI_SS_PROC_ID eCoreID);
/* Convert the audio samples generated by ADC into float format */
void    CopyFix2Float( volatile        uint32_t  *pInBuffer,
                                        uint32_t nInStride,
                       volatile        float    *pOutBuffer,
                                        uint32_t nOutStride,
                                        uint32_t nBlockSize,
                                        uint32_t nShiftFlag);
/* Convert the audio samples from float to fixed point (which can be consumed by DAC) */
uint32_t CopyFloat2Fix(volatile   float *pInBuffer,
                                        uint32_t nInStride,
                               volatile uint32_t *pOutBuffer,
/******* SigmaStudio Integration END  ***************/
/* SPORT buffers */
int32_t int_SP0ABuffer1[BLOCK_SIZE*NUM_CHANNELS];
int32_t int_SP0ABuffer2[BLOCK_SIZE*NUM_CHANNELS];
int32_t int_SP0ABuffer4[BLOCK_SIZE*NUM_CHANNELS];
int32_t int_SP0ABuffer5[BLOCK_SIZE*NUM_CHANNELS];
int32_t int_SP0ABuffer6[BLOCK_SIZE*NUM_CHANNELS2];
int32_t int_SP0ABuffer7[BLOCK_SIZE*NUM_CHANNELS2];
struct Config_Table
	short Reg_Add;
	char  Value;
char Config_read_DAC[28];
char Config_read_ADC[16];
/* Dev buffer for configuring ADC-DAC through TWI*/
static uint8_t devBuffer[BUFFER_SIZE];
extern void ConfigSoftSwitches_ADC_DAC(void);
extern void ConfigSoftSwitches_ADAU_Reset(void);
#if 0
struct Config_Table Config_array_DAC[28] = {
		   	    {     ADAU1962_PDN_CTRL_1,		0x00},
		   	    {     ADAU1962_PDN_CTRL_2,	    0xff},
		   	    {     ADAU1962_PDN_CTRL_3,	    0x0f},
		   	    {     ADAU1962_DAC_CTRL0,		0x01},
		   	    {     ADAU1962_DAC_CTRL1,		0x41},
		   	    {     ADAU1962_DAC_CTRL2,		0x00},
		   	    {     ADAU1962_DAC_MUTE1,	    0x0},
		   	    {     ADAU1962_DAC_MUTE2,	    0x00},
		   	    {     ADAU1962_MSTR_VOL,		0x00},
			    {     ADAU1962_DAC1_VOL,	    0x00},
			    {     ADAU1962_DAC2_VOL,		0x00},
				{     ADAU1962_DAC3_VOL,		0x00},
				{     ADAU1962_DAC4_VOL,		0x00},
				{     ADAU1962_DAC5_VOL,		0x00},
				{     ADAU1962_DAC6_VOL,		0x00},
				{     ADAU1962_DAC7_VOL,		0x00},
				{     ADAU1962_DAC8_VOL,	    0x00},
				{     ADAU1962_DAC9_VOL,		0x00},
				{     ADAU1962_DAC10_VOL,		0x00},
				{     ADAU1962_DAC11_VOL,		0x00},
				{     ADAU1962_DAC12_VOL,		0x00},
				{     ADAU1962_PAD_STRGTH,		0x00},
				{     ADAU1962_DAC_PWR1,		0xaa},
				{     ADAU1962_DAC_PWR2,		0xaa},
				{     ADAU1962_DAC_PWR3,		0xaa},
				{     ADAU1962_PDN_CTRL_2,	    0x00},
				{     ADAU1962_PDN_CTRL_3,	    0x00},
				{     ADAU1962_DAC_CTRL0,		0x18}
#else
		   	    {     ADAU1962_PDN_CTRL_1,		0xa4 },
		   	    {     ADAU1962_PDN_CTRL_2,	    0xff },  //Power down DAC
		   	    {     ADAU1962_PDN_CTRL_3,	    0x0f }, //Power down DAC
		   	    {     ADAU1962_DAC_CTRL0,		0x19 },
		   	    {     ADAU1962_DAC_CTRL1,		0x63 }, // pulse mode LRCLK, MSB first //orginal value =42
		   	    {     ADAU1962_DAC_CTRL2,		0x04 },  // TDM Configuration
		   	    {     ADAU1962_DAC_MUTE1,	    0x00 },
		   	    {     ADAU1962_DAC_MUTE2,	    0x00 },
		   	    {     ADAU1962_MSTR_VOL,		0x00 },
			    {     ADAU1962_DAC1_VOL,	    0x00 } ,
			    {     ADAU1962_DAC2_VOL,		0x00 },
				{     ADAU1962_DAC3_VOL,		0x00 },
				{     ADAU1962_DAC4_VOL,		0x00 },
				{     ADAU1962_DAC5_VOL,		0x00 },
				{     ADAU1962_DAC6_VOL,		0x00 },
				{     ADAU1962_DAC7_VOL,		0x00 },
				{     ADAU1962_DAC8_VOL,	    0x00 },
				{     ADAU1962_DAC9_VOL,		0x00 },
				{     ADAU1962_DAC10_VOL,		0x00 },
				{     ADAU1962_DAC11_VOL,		0x00 },
				{     ADAU1962_DAC12_VOL,		0x00 },
				{     ADAU1962_PAD_STRGTH,		0x00 },
				{     ADAU1962_DAC_PWR1,		0xaa },
				{     ADAU1962_DAC_PWR2,		0xaa },
				{     ADAU1962_DAC_PWR3,		0xaa },
				{     ADAU1962_PDN_CTRL_2,	    0x00 },
				{     ADAU1962_PDN_CTRL_3,	    0x00 },
		   	    {     ADAU1962_DAC_CTRL0,		0x18 },
#endif
#if 0
struct Config_Table Config_array_ADC[16] = {
		 {ADAU1979_REG_BOOST			,	0x00},
		 {ADAU1979_REG_MICBIAS			,	0x00},
		 {ADAU1979_REG_BLOCK_POWER_SAI	,	0x30},
		 /*{ADAU1979_REG_SAI_CTRL0		,	0x1B}, */
		 {ADAU1979_REG_SAI_CTRL0		,	0x1A},/*I2S format*/
		 {ADAU1979_REG_SAI_CTRL1		,	0x08},
		 {ADAU1979_REG_CMAP12			,	0x10},
		 {ADAU1979_REG_CMAP34			,	0x32},
		 {ADAU1979_REG_SAI_OVERTEMP		,	0xf0},
		 {ADAU1979_REG_POST_ADC_GAIN1 	,	0xA0},
		 {ADAU1979_REG_POST_ADC_GAIN2 	,	0xA0},
		 {ADAU1979_REG_POST_ADC_GAIN3 	,	0xA0},
		 {ADAU1979_REG_POST_ADC_GAIN4 	,	0xA0},
		 {ADAU1979_REG_ADC_CLIP			,	0x00},
		 {ADAU1979_REG_DC_HPF_CAL		,	0x00},
		 {ADAU1979_REG_BLOCK_POWER_SAI	,	0x3f},
		 {ADAU1979_REG_MISC_CONTROL		,	0x02}
#else
 		 {ADAU1979_REG_BLOCK_POWER_SAI	,	0xb0},//power down ADC LDO enabel
		 {ADAU1979_REG_SAI_CTRL0		,	0x5a},//TDM 48kHz
		 {ADAU1979_REG_SAI_CTRL1		,	0x08},//LRCLK pulse mode //original value =08
		 {ADAU1979_REG_DC_HPF_CAL		,	0x00},// filter off
		 {ADAU1979_REG_BLOCK_POWER_SAI	,	0xbf},//power on  ADC LDO enable
		 {ADAU1979_REG_MISC_CONTROL		,	0x02},//mute all channels
#endif
/* Destination PDMA lists */
ADI_PDMA_DESC_LIST iDESC_LIST_1_SP4A;
ADI_PDMA_DESC_LIST iDESC_LIST_2_SP4A ;
/* Source PDMA lists */
ADI_PDMA_DESC_LIST iSRC_LIST_1_SP0B ;
ADI_PDMA_DESC_LIST iSRC_LIST_2_SP0B ;
ADI_PDMA_DESC_LIST iDESC_LIST_1_SP5A;
ADI_PDMA_DESC_LIST iDESC_LIST_2_SP5A ;
/* Prepares descriptors for SPORT DMA */
static void PrepareDescriptors (void);
/* Count to track the number of callBacks for SPORT transfer */
volatile uint8_t CallbackCount = 0;
volatile uint32_t TestCallbackCount = 0;
volatile uint32_t nDataAvail=0;
volatile uint8_t CallbackCount2 = 0;
volatile uint32_t TestCallbackCount2 = 0;
volatile uint32_t nDataAvail2=0;
/* Memory required for SPORT */
static uint8_t SPORTMemory4A[ADI_SPORT_MEMORY_SIZE];
static uint8_t SPORTMemory0B[ADI_SPORT_MEMORY_SIZE];
static uint8_t SPORTMemory5A[ADI_SPORT_MEMORY_SIZE];
/* SPORT Handle */
static ADI_SPORT_HANDLE hSPORTDev4ATx;//TX
static ADI_SPORT_HANDLE hSPORTDev0BRx;//RX
static ADI_SPORT_HANDLE hSPORTDev5ATx;//TX
/* Memory required for TWI */
uint8_t TwideviceMemory[ADI_TWI_MEMORY_SIZE];
/* TWI driver handle */
static ADI_TWI_HANDLE hTwiDevice;
/* SPU handle */
static ADI_SPU_HANDLE      ghSpu;
static ADI_SPU_HANDLE      ghSpu2;
/* Memory required for the SPU operation */
uint8_t             SpuMemory[ADI_SPU_MEMORY_SIZE];
uint8_t             SpuMemory2[ADI_SPU_MEMORY_SIZE];
int32_t delay;
static int32_t ADAU_1962_Pllinit(void);
static int32_t ADAU_1979_Pllinit(void);
void Switch_Configurator(void);
static int32_t ADAU_1962_init(void);
static int32_t ADAU_1979_init(void);
void SRU_Init(void);
static int32_t Sport_Init(void);
static int32_t Sport_Stop(void);
static int32_t SPU_init(void);
static int32_t Init_TWI(void);
static int32_t Stop_TWI(void);
static void PCG_init(void);
	//SPORT 4A PCG Configuration
	ADI_PCG_CLK_INFO gClkInfoC;
			gClkInfoC.eClkInput = ADI_PCG_CLK_CLKIN0;               /* Clock Source */
			gClkInfoC.nDiv = 1;                 /* Clock Divisor */
			gClkInfoC.bExternalTrigger = false;                    /* External Trigger */
	ADI_PCG_FS_INFO gFsInfoC;
			gFsInfoC.eClkInput = ADI_PCG_FS_CLKIN0;                               /* Clock Source */
			gFsInfoC.nDiv = (gClkInfoC.nDiv)*(ADI_SPORT0A_CTL_SLEN + 1)*(NUM_CHANNELS);     /* Frame Sync Divisor */
			gFsInfoC.nPulseWidth = 1;                            /* Pulse Width */
			gFsInfoC.nPhase = 2;                                /* Phase */
			gFsInfoC.bExternalTrigger = false;                                   /* External Trigger */
			gFsInfoC.eFsBypassMode = ADI_PCG_FSBYPASS_MODE_NORMAL;               /* Bypass Mode */
	adi_pcg_Init(ADI_PCG_DEV_C,&gClkInfoC,&gFsInfoC);
	//SPORT 5A PCG Configuration
	ADI_PCG_CLK_INFO gClkInfoD;
			gClkInfoD.eClkInput = ADI_PCG_CLK_EXT;               /* Clock Source */
			gClkInfoD.nDiv = 2;                 					/* Clock Divisor */
			gClkInfoD.bExternalTrigger = false;                     /* External Trigger */
	ADI_PCG_FS_INFO gFsInfoD;
			gFsInfoD.eClkInput = ADI_PCG_FS_EXT;                               /* Clock Source */
			gFsInfoD.nDiv = (gClkInfoD.nDiv)*(ADI_SPORT5A_CTL_SLEN + 1)*(NUM_CHANNELS2);     /* Frame Sync Divisor */
			gFsInfoD.nPulseWidth = 2;                            /* Pulse Width */
			gFsInfoD.nPhase = 0;                                /* Phase */
			gFsInfoD.bExternalTrigger = false;                                   /* External Trigger */
			gFsInfoD.eFsBypassMode = ADI_PCG_FSBYPASS_MODE_NORMAL;               /* Bypass Mode */
	adi_pcg_Init(ADI_PCG_DEV_D,&gClkInfoD,&gFsInfoD);
static void SPORTCallback(void        *pAppHandle,
						  uint32_t     nEvent,
						  void        *pArg
	int32_t i;
	int32_t j;
	ADI_SPORT_RESULT eResult;
    /* CASEOF (event type) */
    switch (nEvent)
        /* CASE (buffer processed) */
        case ADI_SPORT_EVENT_RX_BUFFER_PROCESSED:
        		TestCallbackCount += 1;
        		CallbackCount += 1;
        		nDataAvail += 1;
        		break;
        default:
        	 break;
    /* return */
static void SPORTCallback2(void        *pAppHandle,
						  uint32_t     nEvent,
						  void        *pArg
	int32_t i;
	int32_t j;
    switch (nEvent)
        		TestCallbackCount2 += 1;
        		nDataAvail2 += 1;
        		break;
        default:
        	 break;
    /* return */
 * Prepares descriptors for Memory DMA copy.
 * Parameters
 *  None
 * Returns
 *  None
	iDESC_LIST_1_SP4A.pStartAddr	= (int32_t *)int_SP0ABuffer1;
	iDESC_LIST_1_SP4A.Config		= ENUM_DMA_CFG_XCNT_INT ;
	iDESC_LIST_1_SP4A.XCount		= BLOCK_SIZE*NUM_CHANNELS;
	iDESC_LIST_1_SP4A.XModify		= 4;
	iDESC_LIST_1_SP4A.YCount		= 0;
	iDESC_LIST_1_SP4A.YModify		= 0;
	iDESC_LIST_1_SP4A.pNxtDscp		= &iDESC_LIST_2_SP4A;
	iDESC_LIST_2_SP4A.pStartAddr	= (int32_t *)int_SP0ABuffer2;
	iDESC_LIST_2_SP4A.Config		= ENUM_DMA_CFG_XCNT_INT ;
	iDESC_LIST_2_SP4A.XCount		= BLOCK_SIZE*NUM_CHANNELS;
	iDESC_LIST_2_SP4A.XModify		= 4;
	iDESC_LIST_2_SP4A.YCount		= 0;
	iDESC_LIST_2_SP4A.YModify		= 0;
	iDESC_LIST_2_SP4A.pNxtDscp		= &iDESC_LIST_1_SP4A;
	iSRC_LIST_1_SP0B.pStartAddr		=(int32_t *)int_SP0ABuffer4;
	iSRC_LIST_1_SP0B.Config			= ENUM_DMA_CFG_XCNT_INT ;
	iSRC_LIST_1_SP0B.XCount			= BLOCK_SIZE*NUM_CHANNELS;
	iSRC_LIST_1_SP0B.XModify		= 4;
	iSRC_LIST_1_SP0B.YCount			= 0;
	iSRC_LIST_1_SP0B.YModify		= 0;
	iSRC_LIST_1_SP0B.pNxtDscp		= &iSRC_LIST_2_SP0B;
	iSRC_LIST_2_SP0B.pStartAddr		=(int32_t *)int_SP0ABuffer5;
	iSRC_LIST_2_SP0B.Config			= ENUM_DMA_CFG_XCNT_INT;
	iSRC_LIST_2_SP0B.XCount			= BLOCK_SIZE*NUM_CHANNELS;
	iSRC_LIST_2_SP0B.XModify		= 4;
	iSRC_LIST_2_SP0B.YCount			= 0;
	iSRC_LIST_2_SP0B.YModify		= 0;
	iSRC_LIST_2_SP0B.pNxtDscp		= &iSRC_LIST_1_SP0B;
	iDESC_LIST_1_SP5A.pStartAddr	= (int32_t *)int_SP0ABuffer6;
	iDESC_LIST_1_SP5A.Config		= ENUM_DMA_CFG_XCNT_INT ;
	iDESC_LIST_1_SP5A.XCount		= BLOCK_SIZE*NUM_CHANNELS2;
	iDESC_LIST_1_SP5A.XModify		= 4;
	iDESC_LIST_1_SP5A.YCount		= 0;
	iDESC_LIST_1_SP5A.YModify		= 0;
	iDESC_LIST_1_SP5A.pNxtDscp		= &iDESC_LIST_2_SP5A;
	iDESC_LIST_2_SP5A.pStartAddr	= (int32_t *)int_SP0ABuffer7;
	iDESC_LIST_2_SP5A.Config		= ENUM_DMA_CFG_XCNT_INT ;
	iDESC_LIST_2_SP5A.XCount		= BLOCK_SIZE*NUM_CHANNELS2;
	iDESC_LIST_2_SP5A.XModify		= 4;
	iDESC_LIST_2_SP5A.YCount		= 0;
	iDESC_LIST_2_SP5A.YModify		= 0;
	iDESC_LIST_2_SP5A.pNxtDscp		= &iDESC_LIST_1_SP5A;
static int32_t Sport_Init()
    /* SPORT return code */
	/* Open the SPORT Device 4A */
	eResult = adi_sport_Open(SPORT_DEVICE_4A,ADI_HALF_SPORT_A,ADI_SPORT_DIR_TX, ADI_SPORT_MC_MODE, SPORTMemory4A,ADI_SPORT_MEMORY_SIZE,&hSPORTDev4ATx);
	CHECK_RESULT(eResult);
	/* Open the SPORT Device 0B*/
	eResult = adi_sport_Open(SPORT_DEVICE_0B,ADI_HALF_SPORT_B,ADI_SPORT_DIR_RX, ADI_SPORT_MC_MODE, SPORTMemory0B,ADI_SPORT_MEMORY_SIZE,&hSPORTDev0BRx);
	/* Open the SPORT Device 5A */
	eResult = adi_sport_Open(SPORT_DEVICE_5A,ADI_HALF_SPORT_A,ADI_SPORT_DIR_TX, ADI_SPORT_MC_MODE, SPORTMemory5A,ADI_SPORT_MEMORY_SIZE,&hSPORTDev5ATx);
	/* Configure the data,clock,frame sync and MCTL of SPORT Device 4A*/
	eResult = adi_sport_ConfigData(hSPORTDev4ATx,ADI_SPORT_DTYPE_ZERO_FILL,31,false,false,false);
	eResult = adi_sport_ConfigClock(hSPORTDev4ATx,32,false,/*false*/ true,false);
	eResult = adi_sport_ConfigFrameSync(hSPORTDev4ATx,31,false,false,false,/*true*/ false,false,false);
	eResult = adi_sport_ConfigMC(hSPORTDev4ATx,0u,15u,0u,true);
	eResult = adi_sport_SelectChannel(hSPORTDev4ATx,0u,15u);
	/* Configure the data,clock,frame sync and MCTL of SPORT Device 0B*/
	eResult = adi_sport_ConfigData(hSPORTDev0BRx,ADI_SPORT_DTYPE_ZERO_FILL,31,false,false,false);
	eResult = adi_sport_ConfigClock(hSPORTDev0BRx,32,false,/*false*/ true,false);
	eResult = adi_sport_ConfigFrameSync(hSPORTDev0BRx,31,false,false,false,/*true*/ false,false,false);
	eResult = adi_sport_ConfigMC(hSPORTDev0BRx,0u,15u,0u,false);
	eResult = adi_sport_SelectChannel(hSPORTDev0BRx,0u,15u);
	/* Configure the data,clock,frame sync and MCTL of SPORT Device 5A*/
	eResult = adi_sport_ConfigData(hSPORTDev5ATx,ADI_SPORT_DTYPE_ZERO_FILL,31,false,false,false);
	eResult = adi_sport_ConfigClock(hSPORTDev5ATx,9,false,/*false*/ true,false);
	eResult = adi_sport_ConfigFrameSync(hSPORTDev5ATx,255,false,false,false,false,false,false);
	eResult = adi_sport_ConfigMC(hSPORTDev5ATx,0u,7u,0u,true);
	eResult = adi_sport_SelectChannel(hSPORTDev5ATx,0u,7u);
	/* Register SPORT Callback function */
	eResult = adi_sport_RegisterCallback(hSPORTDev0BRx,SPORTCallback,NULL);
	/* Prepare descriptors */
	PrepareDescriptors();
	/* Submit the first buffer for Rx.  */
	eResult = adi_sport_DMATransfer(hSPORTDev0BRx,&iSRC_LIST_1_SP0B,(DMA_NUM_DESC),ADI_PDMA_DESCRIPTOR_LIST, ADI_SPORT_CHANNEL_PRIM);
	/* Submit the first buffer for Tx.  */
	eResult = adi_sport_DMATransfer(hSPORTDev4ATx,&iDESC_LIST_1_SP4A,(DMA_NUM_DESC),ADI_PDMA_DESCRIPTOR_LIST, ADI_SPORT_CHANNEL_PRIM);
	eResult = adi_sport_DMATransfer(hSPORTDev5ATx,&iDESC_LIST_1_SP5A,(DMA_NUM_DESC),ADI_PDMA_DESCRIPTOR_LIST, ADI_SPORT_CHANNEL_PRIM);
	/*Enable the Sport Device 0B */
	eResult = adi_sport_Enable(hSPORTDev0BRx,true);
	/*Enable the Sport Device 4A */
	eResult = adi_sport_Enable(hSPORTDev4ATx,true);
	/*Enable the Sport Device 5A */
	eResult = adi_sport_Enable(hSPORTDev5ATx,true);
	return eResult;
    /*Stop the DMA transfer of  Sport Device 0B */
	eResult = adi_sport_StopDMATransfer(hSPORTDev0BRx);
	/*Stop the DMA transfer of  Sport Device 4A */
	eResult = adi_sport_StopDMATransfer(hSPORTDev4ATx);
	/*Stop the DMA transfer of  Sport Device 5A */
	eResult = adi_sport_StopDMATransfer(hSPORTDev5ATx);
	/*Close Sport Device 0B */
	eResult = adi_sport_Close(hSPORTDev0BRx);
	/*Close Sport Device 4A */
	eResult = adi_sport_Close(hSPORTDev4ATx);
	/*Close Sport Device 5A */
	eResult = adi_sport_Close(hSPORTDev5ATx);
	return eResult;
 * Prepares Switch configuration.
 * Parameters
 *  None
 * Returns
 *  None
void Switch_Configurator()
	int32_t delay11=0xffff;
	/* Software Switch Configuration for Re-Setting ADC-DAC  */
	ConfigSoftSwitches_ADAU_Reset();
	while(delay11--)
		asm("nop;");
	/* Software Switch Configuration for Enabling ADC-DAC */
	ConfigSoftSwitches_ADC_DAC();
	/* wait for Codec to up */
	delay11=0xffff;
	while(delay11--)
		asm("nop;");
 * Prepares SRU configuration.
 * Parameters
 *  None
 * Returns
 *  None
void SRU_Init()
	*pREG_PADS0_DAI0_IE=0xfffff;
	*pREG_PADS0_DAI1_IE=0xfffff;
	// SPORT 0B configuration
	SRU(LOW,DAI0_PBEN05_I);
	SRU(DAI0_PB05_O,SPT0_BD0_I);
	SRU(LOW,DAI0_PBEN07_I);
	SRU(DAI0_PB07_O,SPT0_BCLK_I);
	SRU(LOW,DAI0_PBEN08_I);
	SRU(DAI0_PB08_O,SPT0_BFS_I);
	// SPORT 4A configuration
	SRU2(HIGH,DAI1_PBEN01_I);
	SRU2(SPT4_AD0_O,DAI1_PB01_I);
	SRU2(HIGH,DAI1_PBEN03_I);
	SRU2(PCG0_CLKC_O,DAI1_PB03_I);
	SRU2(PCG0_FSC_O,DAI1_PB04_I);
	SRU2(HIGH,DAI1_PBEN04_I);
	SRU2(PCG0_CLKC_O,SPT4_ACLK_I);
	SRU2(PCG0_FSC_O,SPT4_AFS_I);
	// SPORT 5A configuration PCG CLOCK
	/*SRU2(HIGH,DAI1_PBEN10_I);
	SRU2(SPT5_AD0_O,DAI1_PB10_I);
	SRU2(HIGH,DAI1_PBEN20_I);
	SRU2(PCG0_CLKD_O,DAI1_PB20_I);
	SRU2(HIGH,DAI1_PBEN11_I);
	SRU2(PCG0_CLKD_O,DAI1_PB11_I);
	SRU2(PCG0_FSD_O,DAI1_PB12_I);
	SRU2(HIGH,DAI1_PBEN12_I);
	SRU2(PCG0_CLKD_O,SPT5_ACLK_I);
	SRU2(PCG0_FSD_O,SPT5_AFS_I);*/
	/*SRU2(HIGH,DAI1_PBEN03_I);
	SRU2(DAI1_CRS_PB03_O,DAI1_PB03_I);
	SRU2(DAI1_CRS_PB04_O,DAI1_PB04_I);
	SRU2(DAI1_CRS_PB03_O,SPT4_ACLK_I);
	SRU2(DAI1_CRS_PB04_O,SPT4_AFS_I);*/
	// SPORT 5A configuration internal CLOCK
	SRU2(SPT5_ACLK_O,DAI1_PB20_I);
	SRU2(SPT5_ACLK_O,DAI1_PB11_I);
	SRU2(SPT5_AFS_O,DAI1_PB12_I);
	SRU2(HIGH,DAI1_PBEN12_I);*/
	// SPORT 5A configuration external pin CLOCK
	SRU(LOW,DAI0_PBEN03_I);
	SRU2(DAI1_CRS_PB03_O,PCG0_EXTCLKD_I);
 * Prepares SPU configuration.
 * Parameters
 *  None
 * Returns
 *  None
    if(adi_spu_Init(0, SpuMemory, NULL, NULL, &ghSpu) != ADI_SPU_SUCCESS)
    	REPORT_ERROR("Failed to initialize SPU service\n");
		return FAILED;
    if(adi_spu_Init(0, SpuMemory2, NULL, NULL, &ghSpu2) != ADI_SPU_SUCCESS)
  		return FAILED;
    /* Make SPORT 4A to generate secure transactions */
    if(adi_spu_EnableMasterSecure(ghSpu, SPORT_4A_SPU, true) != ADI_SPU_SUCCESS)
    	REPORT_ERROR("Failed to enable Master secure for SPORT4A\n");
		return FAILED;
    /* Make SPORT 5A to generate secure transactions */
       if(adi_spu_EnableMasterSecure(ghSpu2, SPORT_5A_SPU, true) != ADI_SPU_SUCCESS)
       	REPORT_ERROR("Failed to enable Master secure for SPORT5A\n");
   		return FAILED;
    /* Make SPORT 0B to generate secure transactions */
    if(adi_spu_EnableMasterSecure(ghSpu, SPORT_0B_SPU, true) != ADI_SPU_SUCCESS)
    	REPORT_ERROR("Failed to enable Master secure for SPORT0B\n");
		return FAILED;
    return SUCCESS;
void Write_TWI_8bit_Reg(unsigned char Reg_ID, unsigned char Tx_Data)
	devBuffer[0] = Reg_ID;
	devBuffer[1] = Tx_Data;
	adi_twi_Write(hTwiDevice, devBuffer, 2u, false);
uint8_t Read_TWI_8bit_Reg(unsigned char Reg_ID)
	ADI_TWI_RESULT eResult;
	uint8_t Rx_Data;
	/* write register address */
	eResult = adi_twi_Write(hTwiDevice, devBuffer, 1u, true);
	if(eResult!=ADI_TWI_SUCCESS)
		REPORT_ERROR("TWI write failed 0x%08X\n", eResult);
	/* read register value */
	eResult = adi_twi_Read(hTwiDevice, &Rx_Data, 1u, false);
		REPORT_ERROR("TWI Read failed 0x%08X\n", eResult);
	return Rx_Data;
	eResult = adi_twi_Open(TWIDEVNUM, ADI_TWI_MASTER, &TwideviceMemory[0],
			   	ADI_TWI_MEMORY_SIZE, &hTwiDevice);
		REPORT_ERROR("TWI Open failed 0x%08X\n", eResult);
	eResult = adi_twi_SetPrescale(hTwiDevice, PRESCALEVALUE);
		REPORT_ERROR("TWI Set Prescale failed 0x%08X\n", eResult);
	eResult = adi_twi_SetBitRate(hTwiDevice, BITRATE);
		REPORT_ERROR("TWI Set Bitrate failed 0x%08X\n", eResult);
	eResult = adi_twi_SetDutyCycle(hTwiDevice, DUTYCYCLE);
		REPORT_ERROR("TWI Set Duty cycle failed 0x%08X\n", eResult);
	eResult = adi_twi_SetHardwareAddress(hTwiDevice, TARGETADDR);
		REPORT_ERROR("TWI Set Hw address failed 0x%08X\n", eResult);
	return eResult;
	eResult = adi_twi_Close(hTwiDevice);
	return eResult;
	int32_t i;
	ADAU_1962_Pllinit();
	for(i=0;i<28;i++)
		/* write value */
		Write_TWI_8bit_Reg(Config_array_DAC[i].Reg_Add,Config_array_DAC[i].Value);
		Config_read_DAC[i]=Read_TWI_8bit_Reg(Config_array_DAC[i].Reg_Add);
		if(Config_array_DAC[i].Value!= Config_read_DAC[i])
			DEBUG_INFORMATION("\n Configuring ADAU_1962 failed");
			return FAILED;
	return SUCCESS;
	int32_t status,delay1=0xffff;
   	eResult = adi_twi_SetHardwareAddress(hTwiDevice, TARGETADDR_1962);
	Write_TWI_8bit_Reg(ADAU1962_PLL_CTL_CTRL0,0x01);
	while(delay1--)
		asm("nop;");
	Write_TWI_8bit_Reg(ADAU1962_PLL_CTL_CTRL0,0x05);
	delay1=0xffff;
	while(delay1--)
		asm("nop;");
	Write_TWI_8bit_Reg(ADAU1962_PLL_CTL_CTRL1,0x22);
	delay1=0xffff;
	while(delay1--)
		asm("nop;");
	status=Read_TWI_8bit_Reg(ADAU1962_PLL_CTL_CTRL1);
	while(!((status & 0x4)>>2)  )
	return eResult;
	int32_t i;
	ADAU_1979_Pllinit();
	for(i=0; i<16; i++)
		Write_TWI_8bit_Reg(Config_array_ADC[i].Reg_Add,Config_array_ADC[i].Value);
		Config_read_ADC[i]=Read_TWI_8bit_Reg(Config_array_ADC[i].Reg_Add);
		if(Config_array_ADC[i].Value!= Config_read_ADC[i])
			DEBUG_INFORMATION("\n Configuring ADAU_1979 failed");
			return FAILED;
	return SUCCESS;
   	eResult = adi_twi_SetHardwareAddress(hTwiDevice, TARGETADDR_1979);
   	Write_TWI_8bit_Reg(ADAU1979_REG_POWER,0x01);
	Write_TWI_8bit_Reg(ADAU1979_REG_PLL,0x03);
	status=Read_TWI_8bit_Reg(ADAU1979_REG_PLL);
	while(delay1--)
		asm("nop;");
	while(!((status & 0x80)>>7)  )
		asm("nop;");
	return eResult;
//#define BYPASS_SS
int32_t nTempBuff[BLOCK_SIZE*(NUM_CHANNELS+NUM_CHANNELS2)];
void main(int32_t argc, char *argv[])
	 * Initialize managed drivers and/or services that have been added to
	 * the project.
	 * @return zero on success
	uint32_t Result=0, i, j;
	ADI_SS_MEM_BLOCK oConnectionMemBlk, *pConnectionMemBlk;
	ADI_SS_CONNECTION_CONFIG oConnConfig, *pConnConfig;
	ADI_SS_CONNECTION_RESULT eConnRet = ADI_SS_CONNECTION_FAILED;
	ADI_SS_CONNECTION_HANDLE hConnHandle;
	ADI_SS_MEM_BLOCK oCommMemBlk, *pCommMemBlk;
	ADI_SS_COMM_CONFIG oCommnConfig, *pCommnConfig;
	ADI_SS_COMM_RESULT eCommRet = ADI_SS_COMM_FAILED;
	ADI_SS_COMM_HANDLE hCommHandle;
	ADI_SS_RESULT eSSRes;
	SS_SMAP_SSN_INFO    *pSSnInfo;
	ADI_SS_COMM_PROPERTIES pCommProp;
	int32_t *pSportIn, *pSportOut, *pSportIn1, *pSportOut1;
	adi_initComponents();
	PCG_init();
   /* SPU initialization */
	if (Result==0u)
		Result=SPU_init();
	/* Switch Configuration */
	//Switch_Configurator();
	/* SRU Configuration */
	SRU_Init();
	/* TWI Initialization */
	if (Result==0u)
		//Result=Init_TWI();
	/* ADAU1962 Initialization */
	if (Result==0u)
		//Result=ADAU_1962_init();
	/* ADAU1979 Initialization */
	if (Result==0u)
		//Result=ADAU_1979_init();
	/* SigmaStudio for SHARC (ADSP-SC5xx/ADSP-215xx) library integration */
	/* Connection component Initialization */
	pConnConfig = &oConnConfig;
	pConnConfig->eConnectionType = ADI_SS_CONNECTION_SPI;
	pConnConfig->nDevId = 1;
    pConnConfig->eProcID = PROCESSOR_SH0;
	pConnectionMemBlk = &oConnectionMemBlk;
	pConnectionMemBlk->nSize = ADI_SS_CONNECTION_MEMSIZE;
	pConnectionMemBlk->pMem = adi_ss_connection_mem;
	eConnRet = adi_ss_connection_Init(pConnectionMemBlk, pConnConfig, &hConnHandle);
	if(eConnRet != ADI_SS_CONNECTION_SUCCESS)
        printf("\nConnection component initialization failed");
        exit(-1);
	/* Communication component initialization*/
	pCommnConfig = &oCommnConfig;
	pCommnConfig->bCRCBypass = false;
	pCommnConfig->bFullPacketCRC = true;
	pCommnConfig->pfCommCmd4CallBack = (ADI_SS_COMM_CMD4_CB) adi_ss_comm_callback_cmd4;
	pCommnConfig->pfCommSMAPCallBack = (ADI_SS_COMM_SMAP_CB) adi_SMAP_Application_Callback;
	pCommnConfig->hConnectionHandle = hConnHandle;
	pCommnConfig->pMemSMap[PROCESSOR_SH0] = &oSMAPSharc0;
	pCommnConfig->pBkChnlInfo[0] = &oBkChannelInfoSharc0;
	pCommMemBlk = &oCommMemBlk;
	pCommMemBlk->nSize = ADI_SS_COMM_MEMSIZE;
	pCommMemBlk->pMem = adi_ss_commn_mem;
	eCommRet = adi_ss_comm_Init(pCommMemBlk, pCommnConfig, &hCommHandle);
	if(eCommRet != ADI_SS_COMM_SUCCESS)
        printf("\nCommunication component initialization failed");
        exit(-1);
	/* Wait for SMAP to be received from host */
	/*while(!nSMAPReceived)
	memcpy(&oSMAPSharc0, adi_ss_smap_IC_1, adi_ss_smap_IC_1_size*4);
	/* Populating Memory addresses of different blocks from SMAP */
	oSSnMemMap.nMemBlocks = 11;
	pSSnInfo = &oSMAPSharc0.oSSnInfo[0];
	for(i=0; i<oSSnMemMap.nMemBlocks; i++)
		oSSnMemMap.pMemBlocks[i] = &pSSnInfo->oSSnBuff[i];
	/* Create an instance of SSn */
	adi_ss_create( &hSSnHandle, &oSSnMemMap);
	if(hSSnHandle == NULL)
		printf("\n SSn instance creation failed");
		exit(-1);
	/* Provide SSn handle to communication component using the adi_ss_comm_SetProperties() API */
	pCommProp.haSSnHandle[PROCESSOR_SH0][0] = hSSnHandle;
	pCommProp.nNumProcBlocks = 1;
	pCommProp.nProcId = PROCESSOR_SH0;
	eCommRet = adi_ss_comm_SetProperties(hCommHandle,ADI_COMM_PROP_SSN_HANDLE,&pCommProp);
		printf("\nError in Communication component");
		exit(-1);
	/* Initialize the SSn instance */
	pSSnConfig = &oSSnConfig;
	pSSnConfig->hSSComm = hCommHandle;
	pSSnConfig->nBlockSize = BLOCK_SIZE ;
	pSSnConfig->nInChannels = NUM_CHANNELS;
	pSSnConfig->nOutChannels = NUM_CHANNELS+NUM_CHANNELS2;
	pSSnConfig->bSkipProcessOnCRCError = 0;
	pSSnConfig->bSkipInitialDownload = 1U;
	pSSnConfig->nInitNoWait = 1;
	pSSnConfig->eProcID = PROCESSOR_SH0;
	pSSnConfig->bClearUnusedOutput = 1;
	/* copy code from schematic source file */
	memcpy(oSSnMemMap.pMemBlocks[1]->pMem, adi_ss_code_IC_1, adi_ss_code_IC_1_size*2);
	/* copy parameter from schematic source file */
	memcpy(oSSnMemMap.pMemBlocks[5]->pMem, adi_ss_param_IC_1, adi_ss_param_IC_1_size*4);
	eSSRes =  adi_ss_init(hSSnHandle, pSSnConfig);
	if(eSSRes != ADI_SS_SUCCESS)
		printf("\nSSn instance initialization failed");
		exit(-1);
	pSSnProperties = &oSSnProperties;
	/* Initialize SigmaStudio I/O pointers */
	for(i=0; i<NUM_CHANNELS+NUM_CHANNELS2; i++)
		pSSInBuff[i] = &aSSInOutBuff[i*BLOCK_SIZE];
		pSSOutBuff[i] = pSSInBuff[i];
	/* Populating hardcoded values for readback */
	for(i=0; i<2; i++)
		oBkChannelInfoSharc0.nAvgMIPS[i]=10.0;
		oBkChannelInfoSharc0.nPeakMIPS[i]=20.0;
		oBkChannelInfoSharc0.nVersionInfo=0x47000000;
	/* SPORT Initialization */
	if (Result==0u)
		Result=Sport_Init();
	/* Close TWI */
	if (Result==0u)
		//Result=Stop_TWI();
	while(1)
		if(nDataAvail >= 1)
			nDataAvail = 0;
			if(CallbackCount == 1)
				pSportIn = &int_SP0ABuffer4[0];
				pSportOut = &int_SP0ABuffer1[0];
				pSportIn1 = &int_SP0ABuffer4[0];
				pSportOut1 = &int_SP0ABuffer6[0];
			else if(CallbackCount == 2)
				pSportIn = &int_SP0ABuffer5[0];
				pSportOut = &int_SP0ABuffer2[0];
				pSportIn1 = &int_SP0ABuffer5[0];
				pSportOut1 = &int_SP0ABuffer7[0];
				CallbackCount=0;
			memcpy(nTempBuff,pSportIn,BLOCK_SIZE*NUM_CHANNELS*sizeof(int));
			memcpy(&nTempBuff[16*BLOCK_SIZE],pSportIn1,BLOCK_SIZE*NUM_CHANNELS2*sizeof(int));
			/* Fixed to float conversion and copy to SS input buffer */
				//CopyFix2Float((volatile uint32_t*)&pSportIn[i], NUM_CHANNELS, pSSInBuff[i], 1, BLOCK_SIZE, 1u);
				CopyFix2Float((volatile uint32_t*)&nTempBuff[i], NUM_CHANNELS+NUM_CHANNELS2, pSSInBuff[i], 1, BLOCK_SIZE, 1u);
			/* Call to the Schematic processing  */
			adi_ss_schematic_process(hSSnHandle,BLOCK_SIZE,(adi_ss_sample_t **)pSSInBuff,(adi_ss_sample_t **)pSSOutBuff,pSSnProperties);
			/* Float to fix conversion and copy back to SPORT buffer */
				if(i<NUM_CHANNELS)
					CopyFloat2Fix(pSSOutBuff[i], 1, (volatile uint32_t * )&pSportOut[i], NUM_CHANNELS, BLOCK_SIZE, 0u);
				else
					CopyFloat2Fix(pSSOutBuff[i], 1, (volatile uint32_t * )&pSportOut1[i-NUM_CHANNELS], NUM_CHANNELS2, BLOCK_SIZE, 0u);
			if(nDataAvail >= 1)
				printf("\n Input buffer overflow detected");
				exit(-1);
	if(eCoreID==PROCESSOR_SH0)
		nSMAPReceived = 1;
void adi_ss_comm_callback_cmd4(uint32_t *pCommPayloadBuff, int32_t  nPayloadCount, ADI_SS_SSN_HANDLE hSSn)
Thread Notes
