SigmaStudio Algorithm disgner custom module
Software Version: SigmaStudio for SHARC 4.7
I want to create a custom sigmastudio module using the SigmaStudio Algorithm desinger. This module should be similar to the 'Audio Signal Router' already available in sigmastudio. However, there does not seem to be a way to create a similar module, as there is no way to create parameters based on the number of inputs/outputs when 2D growth is enabled. I can only have a fixed list of parameters.
When not using 2D growth this is possible, as each stacking parameter is replicated when growing the module. But when using 2D growth, i want to replicate a parameter for each added input and each added output. But this does not work.
Is this not possible?
    We hope you have referred the section "7.6.2.2 Two Dimensional Growth Settings" in following document.
    "C:\Analog Devices\SoftwareModules\SigmaStudioForSHARC-SH-Rel4.7.0\Docs\AE_42_SS4G_AlgorithmDesignerGuide.pdf".
    Could you please share your sample design to check whether we can help on this requirement?
  • Yes, I have read the document front to back and back to front.
    There is not much to share. Basically what I want to make is a module which implements an NxM audio router where each node in the NxM has it's own delay buffer.
    So in the XML I have added following module
    	<module name="GainDelayMatrix" block="TRUE">
    		<dlb name="plugins.dlb" target="ADSP-SC58x" embed="FALSE" path=".\"/>
    		<parameter name="cross_gain" isbuffer="NO" format="FLOAT"/>
    		<parameter name="samples" isbuffer="NO" format="INT"/>
    		<pin type="DATA" direction="INPUT" />
    		<pin type="DATA" direction="OUTPUT" />
    	</module
    So for each input/output that I gro the module, I want  the 2 parameters "cross_gain" and "samples" to be replecated. This does not work, i always get only 2 parameters no matter how much I grow the inputs/outputs.
    If i do it in 1D it works as expected, but is useless in my usecase.
  • Can you check with Multi control vertical option to grow control parameters?
  • Yes. Like I said. This works, but is not usefull to me as i need to be able to grow the inputs and the outputs individually. As i need to be able to dimension M and N of the MxN matrix.
    So I need the 2D growth.
  • Hi, It looks like in SigmaStudio the parameter growth not possible based on 2D pin growth, so I may recommend having multiple modules based on number of I/O pins requirements. The module library can be same for all modules which will process based on number of I/O pins. We will forward this requirement to SigmaStudio+ development team if this requirement can be addressed in future SigmaStudio+ release.
