sigmastudio 4.7 for adsp-21565
Product Number: ADSP-21565
Software Version: Sigmastudio for SHARC 4.7
Hi
I modified the app.ldf (see below) of the LibIntergrationExample_Core1 project to run on 21565 processor, and ran theCCES project on the target, but when i try to run sigmastudio project, it says "Active Downloaded" but does not seem to work. I tried reading the CD register and it did not work. the same code works for the 21569 processor but not the 21565. can someone tell me if i'm missing anything? I'm attaching both CCES project and the SS project
 LibIntegrationExample_Core1.rarVolume_Mute_Block_2156x.rar
** ADSP-21565 linker description file generated on Jul 24, 2023 at 11:44:46.
** Copyright (C) 2000-2022 Analog Devices Inc., All Rights Reserved.
** This file is generated automatically based upon the options selected
** in the System Configuration utility. Changes to the LDF configuration
** should be made by modifying the appropriate options rather than editing
** this file. To access the System Configuration utility, double-click the
** system.svc file from a navigation view.
** Custom additions can be inserted within the user-modifiable sections. These
** sections are bounded by comments that start with "$VDSG". Only changes
** placed within these sections are preserved when this file is re-generated.
** Product : CrossCore Embedded Studio
** Tool Version : 6.2.3.4
ARCHITECTURE(ADSP-21565)
** Define a linked library list. Libraries from the command line are included
** in COMMAND_LINE_OBJECTS.
$LIBRARIES =
/*$VDSG<insert-user-libraries-at-beginning> */
/* Text inserted between these $VDSG comments will be preserved */
libcc.dlb
,libc.dlb
,libio.dlb
,libcpp.dlb
,libosal_noos.dlb
,libprofile.dlb
,libssl.dlb
,libdrv.dlb
,libdsp.dlb
,libldr.dlb
/*$VDSG<insert-user-libraries-at-end> */
** Define a linked objects list.
$OBJECTS =
/*$VDSG<insert-user-objects-at-beginning> */
"app_startup.doj"
,$COMMAND_LINE_OBJECTS
/*$VDSG<insert-user-objects-at-end> */
** List of all objects and libraries.
$OBJS_LIBS = $OBJECTS, $LIBRARIES;
** List of objects and libraries which prefer internal memory as
** specified by prefersMem attribute.
$OBJS_LIBS_INTERNAL =
/*$VDSG<insert-libraries-internal> */
$OBJS_LIBS{prefersMem("internal")}
/*$VDSG<insert-libraries-internal-end> */
** List of objects and libraries which don't have a preference for
** external memory as specified by prefersMem attribute.
$OBJS_LIBS_NOT_EXTERNAL =
/*$VDSG<insert-libraries-not-external> */
$OBJS_LIBS{!prefersMem("external")}
/*$VDSG<insert-libraries-not-external-end> */
/*$VDSG<insert-user-macros> */
MEMORY
// ADSP-21565 MEMORY MAP.
// The ADSP-2156x SHARC+ cores have 5 Mbit L1 RAM split over four blocks.
// This LDF defines memory sections only in byte format. It is no longer
// necessary to partition memory for different widths and different
// input types.
// The output sections that populate the memory are defined to use
// one of the following qualifiers:
// BW - byte sections
// PM - PM data/ISA code
// DM - DM data
// SW - VISA code
// DATA64 - long word data
// The linker filters the inputs for each output section to match
// these output section qualfiers. Each output section uses the same
// byte memory sections which the linker packs correctly for each
// qualifier.
// Notes:
// 1) The interrupt Vector Table (IVT) code is placed in internal memory
// by default and has to use ISA (NW, 48 bit) instructions.
// ----------------------- L1-Block 0 RAM (1.5 MBit) ------------------------
mem_iv_code { TYPE(PM RAM) START(0x00090000) END(0x000900a7) WIDTH(48) }
mem_block0_bw { TYPE(BW RAM) START(0x002403f0) END(0x0026ffff) WIDTH(8) }
// ----------------------- L1-Block 1 RAM (1.5 MBit) ------------------------
// The data cache attached to block 1 caches all the external memory access
// requests for the DM bus. The size of the cache can be adjusted with a
// corresponding reduction of the available non-cache L1 space.
// DM cache is disabled so use the full block
mem_block1_bw { TYPE(BW RAM) START(0x002c0000) END(0x002effff) WIDTH(8) }
// ----------------------- L1-Block 2 RAM (1 MBit) --------------------------
// The data cache attached to block 2 caches all the external memory access
// requests for the PM bus. If the size of the cache is 128KB, the whole
// of block 2 is cache.
// PM cache is disabled so use the full block
mem_block2_bw { TYPE(BW RAM) START(0x00300000) END(0x0031ffff) WIDTH(8) }
// ----------------------- L1-Block 3 RAM (1 MBit) --------------------------
// The instruction cache is attached to block 3.
// Instruction cache is disabled so use the full block
mem_block3_bw { TYPE(BW RAM) START(0x00380000) END(0x0039ffff) WIDTH(8) }
// ----------------------- L2-RAM (8 MBit) ----------------------------------
// The 8Mb/1MB L2 SRAM memory has 8 contiguous 128 KB banks.
// Notes:
// 1. The boot code claims the last 8KB of L2 SRAM, as working space.
// This memory is not bootable, but can be used by the application once
// booting is complete (NO_INIT in CCES). Note that if the application
// makes use of this space and then calls the Boot Code APIs, the
// space may be corrupted.
// 2. All memory except the 16KB before the boot code claimed L2 SRAM
// is cached.
mem_L2_bw { TYPE(BW RAM) START(0x20000000) END(0x200b9fff) WIDTH(8) }
mem_L2UC_bw { TYPE(BW RAM) START(0x200fa000) END(0x200fdfff) WIDTH(8) }
mem_L2BC_bw { TYPE(BW RAM) START(0x200fe000) END(0x200fffff) WIDTH(8) }
#define MY_L2_UNCACHED_MEM mem_L2UC_bw
#define MY_L2_CACHED_MEM mem_L2_bw
#if !defined(MY_SDRAM_SWCODE_MEM)
/* 96 kB reserverd for SS4G code */
mem_L2_bw_SS4G_Code { TYPE(BW RAM) START(0x200C0000) END(0x200D7fff) WIDTH(8) }
#endif
#if !defined(MY_SDRAM_DATA1_MEM)
/* 160 kB reserverd for SS4G data */
mem_L2_bw_SS4G_Data { TYPE(BW RAM) START(0x200D8000) END(0x200f9fff) WIDTH(8) }
#endif
/*$VDSG<insert-new-memory-segments> */
} /* MEMORY */
PROCESSOR 21565_CORE0_SHARC0
LINK_AGAINST( $COMMAND_LINE_LINK_AGAINST )
OUTPUT($COMMAND_LINE_OUTPUT_FILE)
KEEP(___ctor_NULL_marker)
KEEP(__ctor_NULL_marker.)
ENTRY(start)
/*$VDSG<insert-user-ldf-commands> */
KEEP(_GMAP)
SECTIONS
/*$VDSG<insert-new-sections-at-iv_code> */
// Block 0 is primarily used for the interrupt vectors code, stack,
// heap and DM data.
// If the entire block3 is cache (128KB size) it also includes priority
// code section.
/*$VDSG<insert-new-sections-for-l1_block0> */
#define IV_CODE dxe_iv_code
IV_CODE PM
/*$VDSG<insert-new-sections-at-the-start-of-iv_code> */
// Interrupt vector code (4 NW instructions per interrupt)
INPUT_SECTIONS( $OBJECTS(iv_code) )
/*$VDSG<insert-new-sections-at-the-end-of-iv_code> */
} > mem_iv_code
/*$VDSG<insert-new-sections-at-mem_block0_bw> */
// Stack and heap initial memory reserve.
dxe_block0_stack_and_heap_reserve NO_INIT BW
RESERVE(heaps_and_system_stack_in_L1, heaps_and_system_stack_in_L1_length = 6144, 8)
} > mem_block0_bw
// Highest priority (prio0) data and code.
dxe_block0_data_prio0_bw BW
// Highest priority byte data for block0.
INPUT_SECTION_ALIGN(4)
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0 seg_int_data) )
} > mem_block0_bw
dxe_block0_data_prio0 DM
// Highest priority data for block 0.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0 seg_int_data ) )
} > mem_block0_bw
dxe_block0_sw_code_prio0 SW
// Highest priority SW code for block 0.
INPUT_SECTION_ALIGN(2)
/*$VDSG<insert-new-sections-at-the-start-of-dxe_block0_sw_code_prio0> */
FILL(0x1) // fill gaps in memory with NOPs
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0) )
/*$VDSG<insert-new-sections-at-the-end-of-dxe_block0_sw_code_prio0> */
INPUT_SECTIONS( $OBJECTS(ss_sys_code_slow ss_sys_code_fast) )
INPUT_SECTIONS( $OBJECTS(ss_fw_code_slow ss_fw_code_fast) )
INPUT_SECTIONS( $OBJECTS(ss_fw_code_comm ) )
INPUT_SECTIONS( $OBJECTS(ss_fw_code_conn ) )
INPUT_SECTIONS( $OBJS_LIBS(adi_fast_prio0_code) )
INPUT_SECTIONS( $OBJECTS(ss_fw_code_mem) )
INPUT_SECTIONS( $OBJECTS(adi_ssn_code) )
INPUT_SECTIONS( $OBJECTS(adi_ssn_comm_code) )
INPUT_SECTIONS( $OBJECTS(ss_app_code) )
INPUT_SECTIONS( $OBJECTS(ss_app_code_cb) )
} > mem_block0_bw
dxe_block0_nw_code_prio0 PM
// Highest priority code for block 0.
/*$VDSG<insert-new-sections-at-the-start-of-dxe_block0_nw_code_prio0> */
/*$VDSG<insert-new-sections-at-the-end-of-dxe_block0_nw_code_prio0> */
} > mem_block0_bw
dxe_block0_noinit_prio0 NO_INIT DM
// Highest priority uninitialized data.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0_noinit_data seg_int_noinit_data) )
} > mem_block0_bw
dxe_block0_noinit_prio0_bw NO_INIT BW
} > mem_block0_bw
dxe_block0_bsz_prio0 ZERO_INIT DM
// Highest priority zero initialized data.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0_bsz_data seg_int_bsz_data) )
} > mem_block0_bw
dxe_block0_bsz_prio0_bw ZERO_INIT BW
} > mem_block0_bw
// High priority (prio1) data, and code if necessary.
dxe_block0_data_prio1 DM
// High priority data.
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_dmda_nw seg_dmda seg_vtbl) )
} > mem_block0_bw
dxe_block0_data_prio1_bw BW
// High priority byte data for block0.
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_dmda_bw seg_dmda seg_vtbl) )
} > mem_block0_bw
dxe_block0_bsz_prio1 ZERO_INIT DM
// High priority zero initialized data.
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_bsz_data .bss32 .bss bsz) )
} > mem_block0_bw
dxe_block0_bsz_prio1_bw ZERO_INIT BW
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_bsz_data .bss8 .bss) )
} > mem_block0_bw
dxe_block0_noinit_prio1 NO_INIT DM
// High priority uninitialized data.
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_noinit_data) )
} > mem_block0_bw
dxe_block0_noinit_prio1_bw NO_INIT BW
} > mem_block0_bw
// Next map data that's not thought to be low priority.
dxe_block0_data_prio2 DM
// Default priority data.
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_dmda_nw seg_dmda seg_vtbl) )
} > mem_block0_bw
dxe_block0_data_prio2_bw BW
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_dmda_bw seg_dmda seg_vtbl) )
} > mem_block0_bw
dxe_block0_bsz_prio2 ZERO_INIT DM
// Default priority zero initialized data.
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_bsz_data .bss32 .bss bsz) )
} > mem_block0_bw
dxe_block0_bsz_prio2_bw ZERO_INIT BW
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_bsz_data .bss8 .bss) )
} > mem_block0_bw
dxe_block0_noinit_prio2 NO_INIT DM
// Default priority uninitialized data.
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_noinit_data) )
} > mem_block0_bw
dxe_block0_noinit_prio2_bw NO_INIT BW
} > mem_block0_bw
dxe_block0_data_prio3 DM
// Unspecified and lowest priority data for any unused memory.
INPUT_SECTIONS( $OBJS_LIBS(seg_dmda_nw seg_dmda seg_vtbl .rtti .cht .edt) )
} > mem_block0_bw
dxe_block0_data_prio3_bw BW
INPUT_SECTIONS( $OBJS_LIBS(seg_dmda_bw seg_dmda seg_vtbl .rtti .cht .edt) )
} > mem_block0_bw
dxe_block0_bsz_prio3 ZERO_INIT DM
// Unspecified and lowest priority zero init data for any unused memory.
INPUT_SECTIONS( $OBJS_LIBS(seg_bsz_data .bss32 .bss) )
} > mem_block0_bw
dxe_block0_bsz_prio3_bw ZERO_INIT BW
INPUT_SECTIONS( $OBJS_LIBS(seg_bsz_data .bss8 .bss) )
} > mem_block0_bw
dxe_block0_noinit_prio3 NO_INIT DM
// Unspecified and lowest priority no init data for any unused memory.
INPUT_SECTIONS( $OBJS_LIBS(seg_noinit_data) )
} > mem_block0_bw
dxe_block0_noinit_prio3_bw NO_INIT BW
} > mem_block0_bw
// Block 1 is primarily used for the DM data and DM cache.
// Define a DM cache size symbol.
// The values used match the bits in the L1C0_CFG register size bits or
// -1 if cache is off.
___ldf_dmcachesize = 0xffffffff; // DM cache off
/*$VDSG<insert-new-sections-for-l1_block1> */
dxe_block1_data_ss_bw BW
/* SigmaStduio data Byte Width */
/* Add SigmaStudio specific data sections here */
INPUT_SECTIONS( $OBJECTS(ss_fw_constdata_fast) )
INPUT_SECTIONS( $OBJECTS(ss_app_data0_fast) )
INPUT_SECTIONS( $OBJECTS(ss_app_data_ipc_fast) )
INPUT_SECTIONS( $OBJECTS(ss_app_data0_fast_uncached) )
} > mem_block1_bw
dxe_block1_data_prio0_bw BW
// Highest priority byte data for block1.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1 seg_int_data) )
} > mem_block1_bw
dxe_block1_data_prio0 DM
// Highest priority data for block1.
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio0> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio0> */
} > mem_block1_bw
dxe_block1_sw_code_prio0 SW
// Highest priority SW code for block1.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1) )
} > mem_block1_bw
dxe_block1_nw_code_prio0 PM
// Highest priority code for block1.
} > mem_block1_bw
dxe_block1_noinit_prio0 NO_INIT DM
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1_noinit_data seg_int_noinit_data) )
} > mem_block1_bw
dxe_block1_noinit_prio0_bw NO_INIT BW
} > mem_block1_bw
dxe_block1_bsz_prio0 ZERO_INIT DM
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1_bsz_data seg_int_bsz_data) )
} > mem_block1_bw
dxe_block1_bsz_prio0_bw ZERO_INIT BW
} > mem_block1_bw
dxe_block1_data_prio1 DM
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio1> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio1> */
} > mem_block1_bw
dxe_block1_data_prio1_bw BW
// High priority byte data for block1.
} > mem_block1_bw
dxe_block1_bsz_prio1 ZERO_INIT DM
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_bsz_prio1> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_bsz_prio1> */
} > mem_block1_bw
dxe_block1_bsz_prio1_bw ZERO_INIT BW
} > mem_block1_bw
dxe_block1_noinit_prio1 NO_INIT DM
} > mem_block1_bw
dxe_block1_noinit_prio1_bw NO_INIT BW
} > mem_block1_bw
dxe_block1_data_prio2 DM
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio2> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio2> */
} > mem_block1_bw
dxe_block1_data_prio2_bw BW
} > mem_block1_bw
dxe_block1_bsz_prio2 ZERO_INIT DM
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_bsz_prio2> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_bsz_prio2> */
} > mem_block1_bw
dxe_block1_bsz_prio2_bw ZERO_INIT BW
} > mem_block1_bw
dxe_block1_noinit_prio2 NO_INIT DM
} > mem_block1_bw
dxe_block1_noinit_prio2_bw NO_INIT BW
} > mem_block1_bw
dxe_block1_data_prio3 DM
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio3> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio3> */
} > mem_block1_bw
dxe_block1_data_prio3_bw BW
} > mem_block1_bw
dxe_block1_bsz_prio3 ZERO_INIT DM
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_bsz_prio3> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_bsz_prio3> */
} > mem_block1_bw
dxe_block1_bsz_prio3_bw ZERO_INIT BW
} > mem_block1_bw
dxe_block1_noinit_prio3 NO_INIT DM
} > mem_block1_bw
dxe_block1_noinit_prio3_bw NO_INIT BW
} > mem_block1_bw
// Block 2 is primarily used for the PM data and PM cache.
// Define a PM cache size symbol.
___ldf_pmcachesize = 0xffffffff; // PM cache off
/*$VDSG<insert-new-sections-for-l1_block2> */
dxe_block2_data_prio0_bw BW
// Highest priority byte data for block2.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block2) )
} > mem_block2_bw
dxe_block2_data_prio0 DM
// Highest priority data for block2.
} > mem_block2_bw
dxe_block2_sw_code_prio0 SW
// Highest priority SW code for block2.
} > mem_block2_bw
dxe_block2_nw_code_prio0 PM
// Highest priority code for block2.
} > mem_block2_bw
dxe_block2_noinit_prio0 NO_INIT DM
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block2_noinit_data) )
} > mem_block2_bw
dxe_block2_noinit_prio0_bw NO_INIT BW
} > mem_block2_bw
dxe_block2_bsz_prio0 ZERO_INIT DM
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block2_bsz_data) )
} > mem_block2_bw
dxe_block2_bsz_prio0_bw ZERO_INIT BW
} > mem_block2_bw
dxe_block2_pm_data_prio1 PM 32
// High priority pm data.
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block2_pm_data> */
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_pmda_nw seg_pmda) )
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block2_pm_data> */
} > mem_block2_bw
dxe_block2_pm_data_prio1_bw BW
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_pmda_bw seg_pmda) )
} > mem_block2_bw
dxe_block2_pm_data_prio2 PM 32
// Default priority pm data.
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_pmda_nw seg_pmda) )
} > mem_block2_bw
dxe_block2_pm_data_prio2_bw BW
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_pmda_bw seg_pmda) )
} > mem_block2_bw
dxe_block2_pm_data_prio3 PM 32
// Unspecified and lowest priority pm data for any unused memory.
INPUT_SECTIONS( $OBJS_LIBS(seg_pmda_nw seg_pmda) )
} > mem_block2_bw
dxe_block2_pm_data_prio3_bw BW
INPUT_SECTIONS( $OBJS_LIBS(seg_pmda) )
} > mem_block2_bw
// Block 3 is primarily used for code and instruction cache.
// Define an instruction cache size symbol.
___ldf_icachesize = 0xffffffff; // instruction cache off
/*$VDSG<insert-new-sections-for-l1_block3> */
dxe_block3_data_prio0 DM
// Highest priority data for block3.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3) )
} > mem_block3_bw
dxe_block3_data_prio0_bw BW
// Highest priority byte data for block3.
} > mem_block3_bw
dxe_block3_noinit_prio0 NO_INIT DM
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3_noinit_data) )
} > mem_block3_bw
dxe_block3_noinit_prio0_bw NO_INIT BW
} > mem_block3_bw
dxe_block3_bsz_prio0 ZERO_INIT DM
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3_bsz_data) )
} > mem_block3_bw
dxe_block3_bsz_prio0_bw ZERO_INIT BW
} > mem_block3_bw
// Now use the remaining block 3 memory for code sections.
// Starting with inputs sections required to be in internal memory.
dxe_block3_sw_code_prio0 SW
// Highest priority SW code for block3.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3 seg_int_code_sw seg_int_code) )
} > mem_block3_bw
dxe_block3_nw_code_prio0 PM
// Highest priority code for block3.
INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3 seg_int_code) )
// The __lib_setup_memory routine requires seg_init to be placed in L1.
INPUT_SECTIONS( $OBJS_LIBS(seg_init) )
} > mem_block3_bw
// Try and use internal memory for the highest priority code.
// Inputs that are not prioritized can use L2 or L3.
dxe_block3_sw_code_prio1 SW
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_swco seg_pmco) )
} > mem_block3_bw
dxe_block3_nw_code_prio1 PM
INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_pmco) )
} > mem_block3_bw
dxe_block3_sw_code_prio2 SW
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_swco seg_pmco) )
} > mem_block3_bw
dxe_block3_nw_code_prio2 PM
INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_pmco) )
} > mem_block3_bw
#define BLOCK3_SW_CODE dxe_block3_sw_code_prio3
BLOCK3_SW_CODE SW
INPUT_SECTIONS( $OBJS_LIBS(seg_swco seg_pmco) )
} > mem_block3_bw
#define BLOCK3_NW_CODE dxe_block3_nw_code_prio3
BLOCK3_NW_CODE PM
INPUT_SECTIONS( $OBJS_LIBS(seg_pmco) )
} > mem_block3_bw
// Input any unmapped data or code to fill up any unused L1 memory
// available in the blocks. However, we can't put code in blocks 1 and
// 2 when they are used as data caches.
/*$VDSG<insert-new-sections-at-mem_block2_overflow> */
// try code in blocks 0-2
dxe_block0_sw_code SW
// VISA code.
INPUT_SECTIONS( $OBJS_LIBS(seg_int_code_sw seg_int_code seg_swco seg_pmco) )
} > mem_block0_bw
dxe_block0_nw_code PM
// ISA code.
INPUT_SECTIONS( $OBJS_LIBS(seg_int_code) )
} > mem_block0_bw
dxe_block1_sw_code SW
// VISA code.
} > mem_block1_bw
dxe_block1_nw_code PM
// ISA code.
} > mem_block1_bw
dxe_block2_sw_code SW
// VISA code.
} > mem_block2_bw
dxe_block2_nw_code PM
// ISA code.
} > mem_block2_bw
// next try non-PM data in block 2
dxe_block2_data DM
// general data.
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block2_overflow_data> */
INPUT_SECTIONS( $OBJS_LIBS(seg_int_data seg_dmda_nw seg_dmda seg_vtbl .rtti .cht .edt) )
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block2_overflow_data> */
} > mem_block2_bw
dxe_block2_data_bw BW
// General data.
INPUT_SECTIONS( $OBJS_LIBS(seg_int_data seg_dmda_bw seg_dmda seg_vtbl .rtti .cht .edt) )
} > mem_block2_bw
dxe_block2_bsz ZERO_INIT DM
// Zero init data.
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block2_bsz> */
INPUT_SECTIONS( $OBJS_LIBS(seg_int_bsz_data seg_bsz_data .bss32 .bss) )
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block2_bsz> */
} > mem_block2_bw
dxe_block2_bsz_bw ZERO_INIT BW
// Zero init data.
INPUT_SECTIONS( $OBJS_LIBS(seg_int_bsz_data seg_bsz_data .bss8 .bss) )
} > mem_block2_bw
dxe_block2_noinit NO_INIT DM
// No-init data.
INPUT_SECTIONS( $OBJS_LIBS(seg_int_noinit_data seg_noinit_data) )
} > mem_block2_bw
dxe_block2_noinit_bw NO_INIT BW
// No-init data.
} > mem_block2_bw
// next try PM data in block 0 and block 1
dxe_block0_pm_data PM 32
// PM data.
} > mem_block0_bw
dxe_block0_pm_data_bw BW
// PM data.
INPUT_SECTIONS( $OBJS_LIBS(seg_pmda_bw seg_pmda) )
} > mem_block0_bw
dxe_block1_pm_data PM 32
// PM data.
/*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_overflow_data> */
/*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_overflow_data> */
} > mem_block1_bw
dxe_block1_pm_data_bw BW
// PM data.
} > mem_block1_bw
// lastly try DM and PM data in block 3
dxe_block3_data DM
// General data.
} > mem_block3_bw
dxe_block3_data_bw BW
// General data.
} > mem_block3_bw
dxe_block3_pm_data PM 32
// PM data.
} > mem_block3_bw
dxe_block3_pm_data_bw BW
// PM data.
} > mem_block3_bw
dxe_block3_bsz ZERO_INIT DM
// Zero init data.
} > mem_block3_bw
dxe_block3_bsz_bw ZERO_INIT BW
// Zero init data.
} > mem_block3_bw
dxe_block3_noinit NO_INIT DM
// No-init data.
} > mem_block3_bw
dxe_block3_noinit_bw NO_INIT BW
// No-init data.
} > mem_block3_bw
// L2 - core memory
/*$VDSG<insert-new-sections-for-l2> */
// First do inputs for noinit data to the boot code working area memory.
dxe_l2bootcode_noinit NO_INIT DM
// L2 no init data.
INPUT_SECTIONS( $OBJS_LIBS(seg_l2_noinit_data seg_noinit_data) )
} > mem_L2BC_bw
dxe_l2bootcode_noinit_bw NO_INIT BW
// L2 no init data.
} > mem_L2BC_bw
#if defined(MY_L2_CACHED_MEM)
dxe_l2_user_tables_nw DM
FORCE_CONTIGUITY
/*$VDSG<insert-input-sections-at-the-start-of-dxe_l2_user_tables_nw> */
} > MY_L2_CACHED_MEM
dxe_l2_cpp_ctors_nw DM
// C++ global constructors list for word-addressed code.
FORCE_CONTIGUITY
__ctors = .; // __ctors points to the start of the section
INPUT_SECTIONS( $OBJS_LIBS(seg_ctdm) )
INPUT_SECTIONS( $OBJS_LIBS(seg_ctdml) )
dxe_l2_cpp_eh_gdt_nw DM
// C++ exceptions data table.
FORCE_CONTIGUITY
INPUT_SECTIONS( $OBJS_LIBS(.gdt32 .gdt) )
INPUT_SECTIONS( $OBJS_LIBS(.gdtl32 .gdtl) )
dxe_l2_cpp_eh_gdt_bw BW
FORCE_CONTIGUITY
INPUT_SECTIONS( $OBJS_LIBS(.gdt) )
INPUT_SECTIONS( $OBJS_LIBS(.gdtl) )
dxe_l2_cpp_ctors_bw BW
// C++ global constructors list for byte-addressed code.
FORCE_CONTIGUITY
_ctors. = .; // _ctors. points to the start of the section
INPUT_SECTIONS( $OBJS_LIBS(seg_ctdml seg_ctdml_bw) )
dxe_l2_user_tables_bw BW
FORCE_CONTIGUITY
/*$VDSG<insert-input-sections-at-the-start-of-dxe_l2_user_tables_bw> */
dxe_l2_stack_and_heap_reserve NO_INIT BW
dxe_l2_sw_code SW
// VISA code.
INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_swco seg_swco seg_pmco) )
dxe_l2_nw_code PM
// ISA code.
INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_pmco seg_pmco) )
dxe_l2_data DM
// L2 data.
INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_dmda seg_dmda_nw seg_dmda seg_vtbl .rtti .cht .edt) )
dxe_l2_data_bw BW
// L2 data.
INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_dmda_bw seg_dmda_bw seg_dmda seg_vtbl .rtti .cht .edt) )
dxe_l2_bsz ZERO_INIT DM
// L2 zero init data.
INPUT_SECTIONS( $OBJS_LIBS(seg_l2_bsz_data seg_bsz_data .bss32 .bss) )
dxe_l2_bsz_bw ZERO_INIT BW
INPUT_SECTIONS( $OBJS_LIBS(seg_l2_bsz_data seg_bsz_data .bss8 .bss) )
dxe_l2_noinit NO_INIT DM
// L2 no init data.
dxe_l2_noinit_bw NO_INIT BW
// L2 no init data.
dxe_l2_pm_data PM 32
// L2 pm data.
dxe_l2_pm_data_bw BW
// L2 pm data.
#else
#warning L2 cached memory unused
#endif // MY_L2_CACHED_MEM
// L2 - uncached memory
// Define labels used by library cache support functions.
___l2_uncached_start = MEMORY_START(mem_L2UC_bw);
___l2_uncached_end = MEMORY_END (mem_L2UC_bw);
#if defined(MY_L2_UNCACHED_MEM)
dxe_l2_uncached_bw BW
INPUT_SECTIONS( $OBJS_LIBS(seg_l2_uncached seg_uncached) )
} > MY_L2_UNCACHED_MEM
dxe_l2_uncached DM
#else
#warning L2 uncached memory unused
#endif // MY_L2_UNCACHED_MEM
// Complete the stack and heap definitions.
/*$VDSG<before-completing-the-stack-and-heap-definitions> */
#include "adi_ss_app.ldf"
dxe_block0_stack_and_heap_expand NO_INIT BW
RESERVE_EXPAND(heaps_and_system_stack_in_L1, heaps_and_system_stack_in_L1_length, 0, 8)
ldf_stack_space = heaps_and_system_stack_in_L1;
ldf_stack_end = (ldf_stack_space + (((heaps_and_system_stack_in_L1_length * 4096) / 6144) - 8));
ldf_stack_length = ldf_stack_end - ldf_stack_space;
ldf_heap_space = ldf_stack_end + 8;
ldf_heap_end = (ldf_heap_space + (((heaps_and_system_stack_in_L1_length * 2048) / 6144) - 8));
ldf_heap_length = ldf_heap_end - ldf_heap_space;
} > mem_block0_bw
dxe_l2_stack_and_heap_expand NO_INIT BW
/*$VDSG<insert-input-sections-at-the-start-of-dxe_L2_stack_and_heap> */
/*$VDSG<insert-new-sections-at-the-end> */
} /* SECTIONS */
} /* 21565_CORE0_SHARC0 */
    are you using .c and .h of schematic source file?
    Could you please try changing the ldf stack memory to 6K or 8 K and try once?
  • Could you please change this line in ldf and try again.
    // is cached.
    mem_L2_bw { TYPE(BW RAM) START(0x20000000) END(0x200bffff) WIDTH(8) }
