Building the example uC project for ADSP-SC589 EZ in CCES, warnings.
Product Number: CCES
Software Version: 2.10.0
I am trying to build the uC example project for my ADSP-CS589 EZ board, and I get these warnings:
Description Resource Path Location Type
"ADI_MMU_R0_DEVICE" redefined MMUConfig.c /SS_uC_App_Core0/system/MMU line 48 C/C++ Problem
li2074: RESERVE_EXPAND command on line 10 of file "..\..\..\Source\adi_ss_uc_app.ldf" might claim the remainder of 'mem_block0_bw' memory, leaving no space for 'dxe_block0_stack_and_heap_expand' output section. app.ldf /SS_uC_App_Core1/system/startup_ldf line 1780 C/C++ Problem
li2074: RESERVE_EXPAND command on line 10 of file "..\..\..\Source\adi_ss_uc_app.ldf" might claim the remainder of 'mem_block0_bw' memory, leaving no space for 'dxe_block0_stack_and_heap_expand' output section. app.ldf /SS_uC_App_Core2/system/startup_ldf line 1767 C/C++ Problem
li2074: RESERVE_EXPAND command on line 71 of file "..\..\..\Source\adi_ss_uc_app.ldf" might claim the remainder of 'mem_L2B5B6_bw' memory, leaving no space for 'dxe_l2_stack_and_heap_expand' output section. app.ldf /SS_uC_App_Core2/system/startup_ldf line 1779 C/C++ Problem
li2074: RESERVE_EXPAND command on line 71 of file "..\..\..\Source\adi_ss_uc_app.ldf" might claim the remainder of 'mem_L2B7B8_bw' memory, leaving no space for 'dxe_l2_stack_and_heap_expand' output section. app.ldf /SS_uC_App_Core1/system/startup_ldf line 1792 C/C++ Problem
Can or should I do something about it?
Or simply ignore?
    This warning is expected one because the "adi_ss_uc_app.ldf" in "DemoUc\ADSP-SC58x\Source" folder uses RESERVE_EXPAND ldf command for reserving remaining available memory to SigmaStudio processing. If you know the required memory for your schematic, you can remove RESERVE_EXPAND and RESERVE the amount of memory required.
    Thanks.
  • Thank you for the answer.
    I now notice that this message appears only for the debug build. Does this mean there is no such problem in the release build?
    Is there any way to estimate the required memory for the schematic? Can I see it in SigmaStudio?
  • The problem will be there in release build as well, not sure whether warnings are suppressed in CCES project settings.
    Using SigmaStudio schematic compiler output you may find how much memory is required for each block and use the CCES project map file also for reference.
    Please look at the GMAP and SMAP section in "AE_42_SS4G_IntegrationGuide.pdf".
    Otherwise in SAHRC core "app.ldf" files, include the "#include "adi_ss_app.ldf"" at the end and make stack and heap allocation as,
    dxe_block0_stack_and_heap_expand NO_INIT BW
    INPUT_SECTION_ALIGN(4)
    RESERVE(heaps_and_system_stack_in_L1, heaps_and_system_stack_in_L1_length, 0, 8)
    Thanks.
  • Thank you for the answer, although I did not completely understand it.
    Could you please explain in more detail?
    The app.ldf header section suggest changes in system.svc System Configuration.
    I have read the GMAP and SMAP sections integration guide, but but it did not help me.
    If I add the lines you suggest to the end of app.ldf, how can I prevent that it is overwritten?
    Should it be added ant the VERY end, outside/after the last line
    } /*SC_589_Core_2 */
    BN
  • Ok, I realize I misunderstood you completely.
    Please explain in detail how to find out how much memory is needed, by reading the SS compiler output.
    And also which memory entry in System Config (system.svc) to modify, there are many.
  • I am sorry ty say this question tread seems to have "crashed" and needs to be restarted.
    The SigmaStudio compiler output is as follows:
    ###### IC 1  ######
    Memory usage of the modules in the schematic:
     Instance 			Code	Coeff	Data32	Data48	Data32B	Data32C	CodeB
    			(bytes) 	(bytes) 	(bytes) 	(bytes) 	(bytes) 	(bytes) 	(bytes)
     Signal I/P1                   	NA	0	0	0	0	0	NA
     Block Main.Sub3               	NA	0	0	0	0	0	NA
     Block Main.Sub4               	NA	0	0	0	0	0	NA
     HPGain_2                      	NA	4	0	0	0	0	NA
     InputSelector                 	NA	4	24	0	0	0	NA
     Param EQ1                     	NA	24	0	60	0	0	NA
     Gen Filter1                   	NA	40	0	126	0	0	NA
     GDCDelay                      	NA	8	3088	0	0	0	NA
     Block Main.Sub1               	NA	0	0	0	0	0	NA
     Block Main.Sub2               	NA	0	0	0	0	0	NA
     Output1                       	NA	0	0	0	0	0	NA
     Output2                       	NA	0	0	0	0	0	NA
     Output3                       	NA	0	0	0	0	0	NA
     Output4                       	NA	0	0	0	0	0	NA
     Framework                    	NA	128	3592	768	0	0	NA
     Const Tables                 	NA	1116	0	0	0	0	NA
     Total			7014	1328	6704	954	0	0	0
     MEMORY ALLOCATION
     Buffer		Address		Size (bytes)
     FW Buffer 0	0x2C0018   	6512
     FW Buffer 1	0x300000   	0
     FW Buffer 2	0x200B0000   	0
     SS Buffer 0	0x200B0000   	1024
     SS Buffer 1	0x2496CC   	7046
     SS Buffer 2	0x200B0400   	1024
     SS Buffer 3	0x200B0800   	4096
     SS Buffer 4	0x2C1988   	6768
     SS Buffer 5	0x300000   	1904
     SS Buffer 6	0x38264C   	1050
     SS Buffer 7	0x80A00000   	32
     SS Buffer 8	0x382A68   	64
     SS Buffer 9	0x80600010   	64
     SS Buffer 10	0x200B1800   	64
     SSn ID: 0 (override)
    ###### IC 2 ######
     Signal I/P2                   	NA	0	0	0	0	0	NA
     Param EQ1_3                   	NA	24	0	60	0	0	NA
     Param EQ1_2                   	NA	124	0	360	0	0	NA
     LeftLP                        	NA	0	0	0	0	0	NA
     LeftHP                        	NA	0	0	0	0	0	NA
     HPDelay                       	NA	8	3088	0	0	0	NA
     HPGain                        	NA	4	0	0	0	0	NA
     RightHP                       	NA	0	0	0	0	0	NA
     RightLP                       	NA	0	0	0	0	0	NA
     Framework                    	NA	72	2048	384	0	0	NA
     Const Tables                 	NA	716	0	0	0	0	NA
     Total			4706	952	5136	804	0	0	0
     MEMORY ALLOCATION
     FW Buffer 0	0x2C0018   	3424
     FW Buffer 2	0x200A0004   	0
     SS Buffer 0	0x200A0004   	1024
     SS Buffer 1	0x2496CC   	4738
     SS Buffer 2	0x200A0404   	1024
     SS Buffer 3	0x200A0804   	4096
     SS Buffer 4	0x2C0D78   	5200
     SS Buffer 5	0x300000   	1528
     SS Buffer 6	0x382640   	900
     SS Buffer 7	0xC0A00000   	32
     SS Buffer 8	0x3829C4   	64
     SS Buffer 9	0xC0600010   	64
     SS Buffer 10	0x200A1804   	64
    Or maybe simpler, here is the content of the exported system header files for the SS project:
    IC1:
    #include <adi_types.h>
    extern uint32_t adi_ss_smap_IC_1[1110];
    extern uint32_t adi_ss_smap_IC_1_size;
    extern uint16_t adi_ss_code_IC_1[3508];
    extern uint32_t adi_ss_code_IC_1_size;
    extern uint32_t adi_ss_param_IC_1[332];
    extern uint32_t adi_ss_param_IC_1_size;
    IC2:
    extern uint32_t adi_ss_smap_IC_2[1110];
    extern uint32_t adi_ss_smap_IC_2_size;
    extern uint16_t adi_ss_code_IC_2[2354];
    extern uint32_t adi_ss_code_IC_2_size;
    extern uint32_t adi_ss_param_IC_2[238];
    extern uint32_t adi_ss_param_IC_2_size;
    Which information should I extract, and how should I use it in "app.ldf" or "adi_ss_app.ldf"?
  • Could you please try with this file and let me know? The same modifications you can follow for other SHARC core.
    ** ADSP-SC589 core 1 linker description file generated on Dec 19, 2022 at 17:32:25.
    ** Copyright (C) 2000-2022 Analog Devices Inc., All Rights Reserved.
    ** This file is generated automatically based upon the options selected
    ** in the System Configuration utility. Changes to the LDF configuration
    ** should be made by modifying the appropriate options rather than editing
    ** this file. To access the System Configuration utility, double-click the
    ** system.svc file from a navigation view.
    ** Custom additions can be inserted within the user-modifiable sections. These
    ** sections are bounded by comments that start with "$VDSG". Only changes
    ** placed within these sections are preserved when this file is re-generated.
    ** Product : CrossCore Embedded Studio
    ** Tool Version : 6.2.3.3
    ARCHITECTURE(ADSP-SC589)
    ** Define a linked library list. Libraries from the command line are included
    ** in COMMAND_LINE_OBJECTS.
    $LIBRARIES =
    /*$VDSG<insert-user-libraries-at-beginning> */
    /* Text inserted between these $VDSG comments will be preserved */
    libcc.dlb
    ,libc.dlb
    ,libio.dlb
    ,libcpp.dlb
    ,libosal_noos.dlb
    ,libprofile.dlb
    ,libssl.dlb
    ,libdrv.dlb
    ,libdsp.dlb
    ,libfftacc.dlb
    ,libldr.dlb
    /*$VDSG<insert-user-libraries-at-end> */
    ** Define a linked objects list.
    $OBJECTS =
    /*$VDSG<insert-user-objects-at-beginning> */
    "app_startup.doj"
    ,$COMMAND_LINE_OBJECTS
    /*$VDSG<insert-user-objects-at-end> */
    ** List of all objects and libraries.
    $OBJS_LIBS = $OBJECTS, $LIBRARIES;
    ** List of objects and libraries which prefer internal memory as
    ** specified by prefersMem attribute.
    $OBJS_LIBS_INTERNAL =
    /*$VDSG<insert-libraries-internal> */
    $OBJS_LIBS{prefersMem("internal")}
    /*$VDSG<insert-libraries-internal-end> */
    ** List of objects and libraries which don't have a preference for
    ** external memory as specified by prefersMem attribute.
    $OBJS_LIBS_NOT_EXTERNAL =
    /*$VDSG<insert-libraries-not-external> */
    $OBJS_LIBS{!prefersMem("external")}
    /*$VDSG<insert-libraries-not-external-end> */
    /*$VDSG<insert-user-macros> */
    MEMORY
    // ADSP-SC589 MEMORY MAP.
    // The ADSP-SC589 SHARC+ cores have 5 Mbit L1 RAM split over four blocks.
    // This LDF defines memory sections only in byte format. It is no longer
    // necessary to partition memory for different widths and different
    // input types.
    // The output sections that populate the memory are defined to use
    // one of the following qualifiers:
    // BW - byte sections
    // PM - PM data/ISA code
    // DM - DM data
    // SW - VISA code
    // DATA64 - long word data
    // The linker filters the inputs for each output section to match
    // these output section qualfiers. Each output section uses the same
    // byte memory sections which the linker packs correctly for each
    // qualifier.
    // Notes:
    // 1) The interrupt Vector Table (IVT) code is placed in internal memory
    // by default and has to use ISA (NW, 48 bit) instructions.
    // ----------------------- L1-Block 0 RAM (1.5 MBit) ------------------------
    mem_iv_code { TYPE(PM RAM) START(0x00090000) END(0x000900a7) WIDTH(48) }
    mem_block0_bw { TYPE(BW RAM) START(0x002403f0) END(0x0026ffff) WIDTH(8) }
    // ----------------------- L1-Block 1 RAM (1.5 MBit) ------------------------
    // The data cache attached to block 1 caches all the external memory access
    // requests for the DM bus. The size of the cache can be adjusted with a
    // corresponding reduction of the available non-cache L1 space.
    // DM cache is disabled so use the full block
    mem_block1_bw { TYPE(BW RAM) START(0x002c0000) END(0x002effff) WIDTH(8) }
    // ----------------------- L1-Block 2 RAM (1 MBit) --------------------------
    // The data cache attached to block 2 caches all the external memory access
    // requests for the PM bus. If the size of the cache is 128KB, the whole
    // of block 2 is cache.
    // PM cache is disabled so use the full block
    mem_block2_bw { TYPE(BW RAM) START(0x00300000) END(0x0031ffff) WIDTH(8) }
    // ----------------------- L1-Block 3 RAM (1 MBit) --------------------------
    // The instruction cache is attached to block 3.
    // Instruction cache is disabled so use the full block
    mem_block3_bw { TYPE(BW RAM) START(0x00380000) END(0x0039ffff) WIDTH(8) }
    // ----------------------- L2-RAM (2 MBit) -----------------------------------
    // The 256 KB L2 memory has 8 banks partitioned as follows:
    // bank1 2008_0000 2008_7FFF 4KB uncached - ICC
    // 4KB uncached - MCAPI ARM
    // 4KB uncached - MCAPI SHARC1
    // 4KB uncached - MCAPI SHARC0
    // 16KB uncached - ARM
    // bank2 2008_8000 2008_FFFF 32KB cached - ARM
    // bank3 2009_0000 2009_7FFF 32KB cached - ARM
    // bank4 2009_8000 2009_FFFF 32KB cached - ARM
    // bank5 200A_0000 200A_7FFF 32KB cached - SHARC1
    // bank6 200A_8000 200A_FFFF 32KB cached - SHARC1
    // bank7 200B_0000 200B_7FFF 32KB cached - SHARC0
    // bank8 200B_8000 200B_DFFB 24KB cached - SHARC0
    // 200B_DFFC 200B_FFFF 8KB cached boot code working area
    // Notes:
    // 1. The boot code claims the last 8KB+4B of L2 SRAM, as working space.
    // This memory is not bootable, but can be used by the application once
    // booting is complete (NO_INIT in CCES). Note that if the application
    // makes use of this space and then calls the Boot Code APIs, the
    // space may be corrupted. The odd extra 4B is required due to boot
    // rom issue ABK-211.
    mem_L2B1P1_bw { TYPE(BW RAM) START(0x20080000) END(0x20080fff) WIDTH(8) }
    mem_L2B1P2_bw { TYPE(BW RAM) START(0x20081000) END(0x20081fff) WIDTH(8) }
    mem_L2B1P3_bw { TYPE(BW RAM) START(0x20082000) END(0x20082fff) WIDTH(8) }
    mem_L2B1P4_bw { TYPE(BW RAM) START(0x20083000) END(0x20083fff) WIDTH(8) }
    mem_L2B1P5_bw { TYPE(BW RAM) START(0x20084000) END(0x20087fff) WIDTH(8) }
    mem_L2B2toB4_bw { TYPE(BW RAM) START(0x20088000) END(0x2009ffff) WIDTH(8) }
    mem_L2B5B6_bw { TYPE(BW RAM) START(0x200a0000) END(0x200affff) WIDTH(8) }
    mem_L2B7B8_bw { TYPE(BW RAM) START(0x200b0000) END(0x200bdffb) WIDTH(8) }
    mem_L2B8BC_bw { TYPE(BW RAM) START(0x200bdffc) END(0x200bffff) WIDTH(8) }
    #define MY_L2_UNCACHED_MEM mem_L2B1P4_bw
    #define MY_L2_CACHED_MEM mem_L2B7B8_bw
    // ----------------------- L3 ------------------------------------------------
    // DMC0 and DMC1 DDR SDRAM memory is partitioned between the cores.
    // Notes
    // 1. Code execution addresses are restricted for the SHARC cores so
    // the memory allocated cannot be increased or moved.
    // 2. All L3 will be considered cached.
    // 3. MY_SDRAM_DATA1_MEM is defined to be the smaller L3 data section and
    // MY_SDRAM_DATA2_MEM is the larger one.
    // 4. Due to anomaly 20-00-0019 some memory in DDR-A and DDR-B cannot be
    // used for VISA code execution.
    // ----------------------- 256MB DMC0(DDR-A) ---------------------------------
    // 256MB DMC0 DDR SDRAM memory is partitioned as follows:
    // DDR-A part1 : SHARC0 NW code, 6MB
    // DDR-A part2 : SHARC0 data, 4MB
    // DDR-A part3 : SHARC0 VISA code, 6MB (reduced for 20000019 workaround)
    // DDR-A part4 : SHARC0 data, 128MB
    // DDR-A part5 : SHARC1 data, 112MB
    mem_DMC0_SDRAM_A1 { TYPE(BW RAM) START(0x80000000) END(0x805fffff) WIDTH(8) }
    mem_DMC0_SDRAM_A2 { TYPE(BW RAM) START(0x80600000) END(0x809fffff) WIDTH(8) }
    #if defined(__WORKAROUND_20000019)
    mem_DMC0_SDRAM_A3 { TYPE(BW RAM) START(0x80a00000) END(0x80bfffff) WIDTH(8) }
    #else
    mem_DMC0_SDRAM_A3 { TYPE(BW RAM) START(0x80a00000) END(0x80ffffff) WIDTH(8) }
    #endif
    mem_DMC0_SDRAM_A4 { TYPE(BW RAM) START(0x81000000) END(0x88ffffff) WIDTH(8) }
    mem_DMC0_SDRAM_A5 { TYPE(BW RAM) START(0x89000000) END(0x8fffffff) WIDTH(8) }
    // ----------------------- 256MB DMC1(DDR-B) ---------------------------------
    // 256MB DMC1 DDR SDRAM memory is partitioned as follows:
    // DDR-B part1 : SHARC1 NW code, 6MB
    // DDR-B part2 : SHARC1 data, 4MB
    // DDR-B part3 : SHARC1 VISA code, 6MB (reduced for 20000019 workaround)
    // DDR-B part4 : ARM, 240MB
    mem_DMC1_SDRAM_B1 { TYPE(BW RAM) START(0xc0000000) END(0xc05fffff) WIDTH(8) }
    mem_DMC1_SDRAM_B2 { TYPE(BW RAM) START(0xc0600000) END(0xc09fffff) WIDTH(8) }
    mem_DMC1_SDRAM_B3 { TYPE(BW RAM) START(0xc0A00000) END(0xc0bfffff) WIDTH(8) }
    #else
    mem_DMC1_SDRAM_B3 { TYPE(BW RAM) START(0xc0A00000) END(0xc0ffffff) WIDTH(8) }
    #endif
    mem_DMC1_SDRAM_B4 { TYPE(BW RAM) START(0xc1000000) END(0xcfffffff) WIDTH(8) }
    #define MY_SDRAM_NWCODE_MEM mem_DMC0_SDRAM_A1
    #define MY_SDRAM_DATA1_MEM mem_DMC0_SDRAM_A2
    #define MY_SDRAM_SWCODE_MEM mem_DMC0_SDRAM_A3
    #define MY_SDRAM_DATA2_MEM mem_DMC0_SDRAM_A4
    #if !defined(SDRAM_STACK_HEAP_BLOCK)
    #if defined(MY_SDRAM_DATA2_MEM)
    #define SDRAM_STACK_HEAP_BLOCK MY_SDRAM_DATA2_MEM
    #else
    #define SDRAM_STACK_HEAP_BLOCK MY_SDRAM_DATA1_MEM
    #endif
    #endif
    /*$VDSG<insert-new-memory-segments> */
    #if !defined(MY_SDRAM_SWCODE_MEM)
    /* 96 kB reserverd for SS4G code */
    mem_L2_bw_SS4G_Code { TYPE(BW RAM) START(0x200b8000) END(0x200bafff) WIDTH(8) }
    #endif
    #if !defined(MY_SDRAM_DATA1_MEM)
    /* 160 kB reserverd for SS4G data */
    mem_L2_bw_SS4G_Data { TYPE(BW RAM) START(0x200bb000) END(0x200bdffb) WIDTH(8) }
    #endif
    } /* MEMORY */
    PROCESSOR SC589_CORE_1
    LINK_AGAINST( $COMMAND_LINE_LINK_AGAINST )
    OUTPUT($COMMAND_LINE_OUTPUT_FILE)
    KEEP(___ctor_NULL_marker)
    KEEP(__ctor_NULL_marker.)
    ENTRY(start)
    /*$VDSG<insert-user-ldf-commands> */
    KEEP(_GMAP)
    SECTIONS
    /*$VDSG<insert-new-sections-at-iv_code> */
    // Block 0 is primarily used for the interrupt vectors code, stack,
    // heap and DM data.
    // If the entire block3 is cache (128KB size) it also includes priority
    // code section.
    // Note: Only DMA accesses to block 0 (which has no cache) or to block 3
    // (which has instruction cache) are valid because data caches conflict
    // with DMA due to anomaly 20-00-0010.
    /*$VDSG<insert-new-sections-for-l1_block0> */
    #define IV_CODE dxe_iv_code
    IV_CODE PM
    /*$VDSG<insert-new-sections-at-the-start-of-iv_code> */
    // Interrupt vector code (4 NW instructions per interrupt)
    INPUT_SECTIONS( $OBJECTS(iv_code) )
    /*$VDSG<insert-new-sections-at-the-end-of-iv_code> */
    } > mem_iv_code
    /*$VDSG<insert-new-sections-at-mem_block0_bw> */
    // Stack and heap initial memory reserve.
    dxe_block0_stack_and_heap_reserve NO_INIT BW
    RESERVE(heaps_and_system_stack_in_L1, heaps_and_system_stack_in_L1_length = 8192, 8)
    } > mem_block0_bw
    // Highest priority (prio0) data and code.
    dxe_block0_data_prio0_bw BW
    // Highest priority byte data for block0.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0 seg_int_data) )
    } > mem_block0_bw
    dxe_block0_data_prio0 DM
    // Highest priority data for block 0.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0 seg_int_data ) )
    } > mem_block0_bw
    dxe_block0_sw_code_prio0 SW
    // Highest priority SW code for block 0.
    INPUT_SECTION_ALIGN(2)
    /*$VDSG<insert-new-sections-at-the-start-of-dxe_block0_sw_code_prio0> */
    INPUT_SECTIONS( $OBJECTS(ss_sys_code_slow ss_sys_code_fast) )
    INPUT_SECTIONS( $OBJECTS(ss_fw_code_slow ss_fw_code_fast) )
    INPUT_SECTIONS( $OBJECTS(ss_fw_code_comm ) )
    INPUT_SECTIONS( $OBJECTS(ss_fw_code_conn ) )
    INPUT_SECTIONS( $OBJECTS(ss_fw_code_ipc) )
    INPUT_SECTIONS( $OBJECTS(ss_fw_code_mem) )
    INPUT_SECTIONS( $OBJECTS(adi_ssn_code) )
    INPUT_SECTIONS( $OBJECTS(adi_ssn_comm_code) )
    INPUT_SECTIONS( $OBJECTS(ss_app_code) )
    INPUT_SECTIONS( $OBJECTS(ss_app_code_cb) )
    FILL(0x1) // fill gaps in memory with NOPs
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0) )
    /*$VDSG<insert-new-sections-at-the-end-of-dxe_block0_sw_code_prio0> */
    } > mem_block0_bw
    dxe_block0_nw_code_prio0 PM
    // Highest priority code for block 0.
    /*$VDSG<insert-new-sections-at-the-start-of-dxe_block0_nw_code_prio0> */
    /*$VDSG<insert-new-sections-at-the-end-of-dxe_block0_nw_code_prio0> */
    } > mem_block0_bw
    dxe_block0_noinit_prio0 NO_INIT DM
    // Highest priority uninitialized data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0_noinit_data seg_int_noinit_data) )
    } > mem_block0_bw
    dxe_block0_noinit_prio0_bw NO_INIT BW
    } > mem_block0_bw
    dxe_block0_bsz_prio0 ZERO_INIT DM
    // Highest priority zero initialized data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block0_bsz_data seg_int_bsz_data) )
    } > mem_block0_bw
    dxe_block0_bsz_prio0_bw ZERO_INIT BW
    } > mem_block0_bw
    // High priority (prio1) data, and code if necessary.
    dxe_block0_data_prio1 DM
    // High priority data.
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_dmda_nw seg_dmda seg_vtbl) )
    #define ADI_MODULES_INPUT_SECTIONS_DATAA
    #include "modules_sharc.ldf"
    #undef ADI_MODULES_INPUT_SECTIONS_DATAA
    } > mem_block0_bw
    dxe_block0_data_prio1_bw BW
    // High priority byte data for block0.
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_dmda_bw seg_dmda seg_vtbl) )
    } > mem_block0_bw
    dxe_block0_bsz_prio1 ZERO_INIT DM
    // High priority zero initialized data.
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_bsz_data .bss32 .bss bsz) )
    } > mem_block0_bw
    dxe_block0_bsz_prio1_bw ZERO_INIT BW
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_bsz_data .bss8 .bss) )
    } > mem_block0_bw
    dxe_block0_noinit_prio1 NO_INIT DM
    // High priority uninitialized data.
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_noinit_data) )
    } > mem_block0_bw
    dxe_block0_noinit_prio1_bw NO_INIT BW
    } > mem_block0_bw
    // Next map data that's not thought to be low priority.
    dxe_block0_data_prio2 DM
    // Default priority data.
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_dmda_nw seg_dmda seg_vtbl) )
    } > mem_block0_bw
    dxe_block0_data_prio2_bw BW
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_dmda_bw seg_dmda seg_vtbl) )
    } > mem_block0_bw
    dxe_block0_bsz_prio2 ZERO_INIT DM
    // Default priority zero initialized data.
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_bsz_data .bss32 .bss bsz) )
    } > mem_block0_bw
    dxe_block0_bsz_prio2_bw ZERO_INIT BW
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_bsz_data .bss8 .bss) )
    } > mem_block0_bw
    dxe_block0_noinit_prio2 NO_INIT DM
    // Default priority uninitialized data.
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_noinit_data) )
    } > mem_block0_bw
    dxe_block0_noinit_prio2_bw NO_INIT BW
    } > mem_block0_bw
    dxe_block0_data_prio3 DM
    // Unspecified and lowest priority data for any unused memory.
    INPUT_SECTIONS( $OBJS_LIBS(seg_dmda_nw seg_dmda seg_vtbl .rtti .cht .edt) )
    } > mem_block0_bw
    dxe_block0_data_prio3_bw BW
    INPUT_SECTIONS( $OBJS_LIBS(seg_dmda_bw seg_dmda seg_vtbl .rtti .cht .edt) )
    } > mem_block0_bw
    dxe_block0_bsz_prio3 ZERO_INIT DM
    // Unspecified and lowest priority zero init data for any unused memory.
    INPUT_SECTIONS( $OBJS_LIBS(seg_bsz_data .bss32 .bss) )
    } > mem_block0_bw
    dxe_block0_bsz_prio3_bw ZERO_INIT BW
    INPUT_SECTIONS( $OBJS_LIBS(seg_bsz_data .bss8 .bss) )
    } > mem_block0_bw
    dxe_block0_noinit_prio3 NO_INIT DM
    // Unspecified and lowest priority no init data for any unused memory.
    INPUT_SECTIONS( $OBJS_LIBS(seg_noinit_data) )
    } > mem_block0_bw
    dxe_block0_noinit_prio3_bw NO_INIT BW
    } > mem_block0_bw
    // Block 1 is primarily used for the DM data and DM cache.
    // Note: Blocks 1 and 2 should not be used for DMA accesses when
    // they are used as caches, reference anomaly 20-00-0010.
    // Define a DM cache size symbol.
    // The values used match the bits in the L1C0_CFG register size bits or
    // -1 if cache is off.
    ___ldf_dmcachesize = 0xffffffff; // DM cache off
    /*$VDSG<insert-new-sections-for-l1_block1> */
    dxe_block1_data_ss_bw BW
    /* SigmaStduio data Byte Width */
    /* Add SigmaStudio specific data sections here */
    INPUT_SECTIONS( $OBJECTS(ss_fw_constdata_fast) )
    INPUT_SECTIONS( $OBJECTS(ss_app_data0_fast) )
    INPUT_SECTIONS( $OBJECTS(ss_app_data_ipc_fast) )
    } > mem_block1_bw
    dxe_block1_data_prio0_bw BW
    // Highest priority byte data for block1.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1 seg_int_data) )
    } > mem_block1_bw
    dxe_block1_data_prio0 DM
    // Highest priority data for block1.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio0> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio0> */
    } > mem_block1_bw
    dxe_block1_sw_code_prio0 SW
    // Highest priority SW code for block1.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1) )
    } > mem_block1_bw
    dxe_block1_nw_code_prio0 PM
    // Highest priority code for block1.
    } > mem_block1_bw
    dxe_block1_noinit_prio0 NO_INIT DM
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1_noinit_data seg_int_noinit_data) )
    } > mem_block1_bw
    dxe_block1_noinit_prio0_bw NO_INIT BW
    } > mem_block1_bw
    dxe_block1_bsz_prio0 ZERO_INIT DM
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block1_bsz_data seg_int_bsz_data) )
    } > mem_block1_bw
    dxe_block1_bsz_prio0_bw ZERO_INIT BW
    } > mem_block1_bw
    dxe_block1_data_prio1 DM
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio1> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio1> */
    } > mem_block1_bw
    dxe_block1_data_prio1_bw BW
    // High priority byte data for block1.
    } > mem_block1_bw
    dxe_block1_bsz_prio1 ZERO_INIT DM
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_bsz_prio1> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_bsz_prio1> */
    } > mem_block1_bw
    dxe_block1_bsz_prio1_bw ZERO_INIT BW
    } > mem_block1_bw
    dxe_block1_noinit_prio1 NO_INIT DM
    } > mem_block1_bw
    dxe_block1_noinit_prio1_bw NO_INIT BW
    } > mem_block1_bw
    dxe_block1_data_prio2 DM
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio2> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio2> */
    } > mem_block1_bw
    dxe_block1_data_prio2_bw BW
    } > mem_block1_bw
    dxe_block1_bsz_prio2 ZERO_INIT DM
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_bsz_prio2> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_bsz_prio2> */
    } > mem_block1_bw
    dxe_block1_bsz_prio2_bw ZERO_INIT BW
    } > mem_block1_bw
    dxe_block1_noinit_prio2 NO_INIT DM
    } > mem_block1_bw
    dxe_block1_noinit_prio2_bw NO_INIT BW
    } > mem_block1_bw
    dxe_block1_data_prio3 DM
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_dm_data_prio3> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_dm_data_prio3> */
    } > mem_block1_bw
    dxe_block1_data_prio3_bw BW
    } > mem_block1_bw
    dxe_block1_bsz_prio3 ZERO_INIT DM
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_bsz_prio3> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_bsz_prio3> */
    } > mem_block1_bw
    dxe_block1_bsz_prio3_bw ZERO_INIT BW
    } > mem_block1_bw
    dxe_block1_noinit_prio3 NO_INIT DM
    } > mem_block1_bw
    dxe_block1_noinit_prio3_bw NO_INIT BW
    } > mem_block1_bw
    // Block 2 is primarily used for the PM data and PM cache.
    // Note blocks 1 and 2 should not be used for DMA accesses when
    // Define a PM cache size symbol.
    ___ldf_pmcachesize = 0xffffffff; // PM cache off
    /*$VDSG<insert-new-sections-for-l1_block2> */
    dxe_block2_data_prio0_bw BW
    // Highest priority byte data for block2.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block2) )
    } > mem_block2_bw
    dxe_block2_data_prio0 DM
    // Highest priority data for block2.
    } > mem_block2_bw
    dxe_block2_sw_code_prio0 SW
    // Highest priority SW code for block2.
    } > mem_block2_bw
    dxe_block2_nw_code_prio0 PM
    // Highest priority code for block2.
    } > mem_block2_bw
    dxe_block2_noinit_prio0 NO_INIT DM
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block2_noinit_data) )
    } > mem_block2_bw
    dxe_block2_noinit_prio0_bw NO_INIT BW
    } > mem_block2_bw
    dxe_block2_bsz_prio0 ZERO_INIT DM
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block2_bsz_data) )
    } > mem_block2_bw
    dxe_block2_bsz_prio0_bw ZERO_INIT BW
    } > mem_block2_bw
    dxe_block2_pm_data_prio1 PM 32
    // High priority pm data.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block2_pm_data> */
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_pmda_nw seg_pmda) )
    #define ADI_MODULES_INPUT_SECTIONS_DATAB
    #undef ADI_MODULES_INPUT_SECTIONS_DATAB
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block2_pm_data> */
    } > mem_block2_bw
    dxe_block2_pm_data_prio1_bw BW
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_pmda_bw seg_pmda) )
    } > mem_block2_bw
    dxe_block2_pm_data_prio2 PM 32
    // Default priority pm data.
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_pmda_nw seg_pmda) )
    } > mem_block2_bw
    dxe_block2_pm_data_prio2_bw BW
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_pmda_bw seg_pmda) )
    } > mem_block2_bw
    dxe_block2_pm_data_prio3 PM 32
    // Unspecified and lowest priority pm data for any unused memory.
    INPUT_SECTIONS( $OBJS_LIBS(seg_pmda_nw seg_pmda) )
    } > mem_block2_bw
    dxe_block2_pm_data_prio3_bw BW
    INPUT_SECTIONS( $OBJS_LIBS(seg_pmda) )
    } > mem_block2_bw
    // Block 3 is primarily used for code and instruction cache.
    // Only DMA accesses to block 0 (which has no cache) or to block 3
    // Define an instruction cache size symbol.
    ___ldf_icachesize = 0xffffffff; // instruction cache off
    /*$VDSG<insert-new-sections-for-l1_block3> */
    dxe_block3_data_prio0 DM
    // Highest priority data for block3.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3) )
    } > mem_block3_bw
    dxe_block3_data_prio0_bw BW
    // Highest priority byte data for block3.
    } > mem_block3_bw
    dxe_block3_noinit_prio0 NO_INIT DM
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3_noinit_data) )
    } > mem_block3_bw
    dxe_block3_noinit_prio0_bw NO_INIT BW
    } > mem_block3_bw
    dxe_block3_bsz_prio0 ZERO_INIT DM
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3_bsz_data) )
    } > mem_block3_bw
    dxe_block3_bsz_prio0_bw ZERO_INIT BW
    } > mem_block3_bw
    // Now use the remaining block 3 memory for code sections.
    // Starting with inputs sections required to be in internal memory.
    dxe_block3_sw_code_prio0 SW
    // Highest priority SW code for block3.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3 seg_int_code_sw seg_int_code) )
    #define ADI_MODULES_INPUT_SECTIONS_INSTR
    #undef ADI_MODULES_INPUT_SECTIONS_INSTR
    } > mem_block3_bw
    dxe_block3_nw_code_prio0 PM
    // Highest priority code for block3.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l1_block3 seg_int_code) )
    // The __lib_setup_memory routine requires seg_init to be placed in L1.
    INPUT_SECTIONS( $OBJS_LIBS(seg_init) )
    } > mem_block3_bw
    // Try and use internal memory for the highest priority code.
    // Inputs that are not prioritized can use L2 or L3.
    dxe_block3_sw_code_prio1 SW
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_swco seg_pmco) )
    } > mem_block3_bw
    dxe_block3_nw_code_prio1 PM
    INPUT_SECTIONS( $OBJS_LIBS_INTERNAL(seg_pmco) )
    } > mem_block3_bw
    dxe_block3_sw_code_prio2 SW
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_swco seg_pmco) )
    } > mem_block3_bw
    dxe_block3_nw_code_prio2 PM
    INPUT_SECTIONS( $OBJS_LIBS_NOT_EXTERNAL(seg_pmco) )
    } > mem_block3_bw
    #define BLOCK3_SW_CODE dxe_block3_sw_code_prio3
    BLOCK3_SW_CODE SW
    INPUT_SECTIONS( $OBJS_LIBS(seg_swco seg_pmco) )
    } > mem_block3_bw
    #define BLOCK3_NW_CODE dxe_block3_nw_code_prio3
    BLOCK3_NW_CODE PM
    INPUT_SECTIONS( $OBJS_LIBS(seg_pmco) )
    } > mem_block3_bw
    // Input any unmapped data or code to fill up any unused L1 memory
    // available in the blocks. However, we can't put code in blocks 1 and
    // 2 when they are used as data caches.
    /*$VDSG<insert-new-sections-at-mem_block2_overflow> */
    // try code in blocks 0-2
    dxe_block0_sw_code SW
    // VISA code.
    INPUT_SECTIONS( $OBJS_LIBS(seg_int_code_sw seg_int_code seg_swco seg_pmco) )
    } > mem_block0_bw
    dxe_block0_nw_code PM
    // ISA code.
    INPUT_SECTIONS( $OBJS_LIBS(seg_int_code) )
    } > mem_block0_bw
    dxe_block1_sw_code SW
    // VISA code.
    } > mem_block1_bw
    dxe_block1_nw_code PM
    // ISA code.
    } > mem_block1_bw
    dxe_block2_sw_code SW
    // VISA code.
    } > mem_block2_bw
    dxe_block2_nw_code PM
    // ISA code.
    } > mem_block2_bw
    // next try non-PM data in block 2
    dxe_block2_data DM
    // general data.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block2_overflow_data> */
    INPUT_SECTIONS( $OBJS_LIBS(seg_int_data seg_dmda_nw seg_dmda seg_vtbl .rtti .cht .edt) )
    #define ADI_MODULES_INPUT_SECTIONS_DATA_OVERFLOW
    #undef ADI_MODULES_INPUT_SECTIONS_DATA_OVERFLOW
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block2_overflow_data> */
    } > mem_block2_bw
    dxe_block2_data_bw BW
    // General data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_int_data seg_dmda_bw seg_dmda seg_vtbl .rtti .cht .edt) )
    } > mem_block2_bw
    dxe_block2_bsz ZERO_INIT DM
    // Zero init data.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block2_bsz> */
    INPUT_SECTIONS( $OBJS_LIBS(seg_int_bsz_data seg_bsz_data .bss32 .bss) )
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block2_bsz> */
    } > mem_block2_bw
    dxe_block2_bsz_bw ZERO_INIT BW
    // Zero init data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_int_bsz_data seg_bsz_data .bss8 .bss) )
    } > mem_block2_bw
    dxe_block2_noinit NO_INIT DM
    // No-init data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_int_noinit_data seg_noinit_data) )
    } > mem_block2_bw
    dxe_block2_noinit_bw NO_INIT BW
    // No-init data.
    } > mem_block2_bw
    // next try PM data in block 0 and block 1
    dxe_block0_pm_data PM 32
    // PM data.
    } > mem_block0_bw
    dxe_block0_pm_data_bw BW
    // PM data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_pmda_bw seg_pmda) )
    } > mem_block0_bw
    dxe_block1_pm_data PM 32
    // PM data.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_block1_overflow_data> */
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_block1_overflow_data> */
    } > mem_block1_bw
    dxe_block1_pm_data_bw BW
    // PM data.
    } > mem_block1_bw
    // lastly try DM and PM data in block 3
    dxe_block3_data DM
    // General data.
    } > mem_block3_bw
    dxe_block3_data_bw BW
    // General data.
    } > mem_block3_bw
    dxe_block3_pm_data PM 32
    // PM data.
    } > mem_block3_bw
    dxe_block3_pm_data_bw BW
    // PM data.
    } > mem_block3_bw
    dxe_block3_bsz ZERO_INIT DM
    // Zero init data.
    } > mem_block3_bw
    dxe_block3_bsz_bw ZERO_INIT BW
    // Zero init data.
    } > mem_block3_bw
    dxe_block3_noinit NO_INIT DM
    // No-init data.
    } > mem_block3_bw
    dxe_block3_noinit_bw NO_INIT BW
    // No-init data.
    } > mem_block3_bw
    // L2 - core memory
    /*$VDSG<insert-new-sections-for-l2> */
    // First do inputs for noinit data to the boot code working area memory.
    dxe_l2bootcode_noinit NO_INIT DM
    // L2 no init data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2_noinit_data seg_noinit_data) )
    } > mem_L2B8BC_bw
    dxe_l2bootcode_noinit_bw NO_INIT BW
    // L2 no init data.
    } > mem_L2B8BC_bw
    #if defined(MY_L2_CACHED_MEM)
    dxe_l2_user_tables_nw DM
    FORCE_CONTIGUITY
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_l2_user_tables_nw> */
    } > MY_L2_CACHED_MEM
    dxe_l2_user_tables_bw BW
    FORCE_CONTIGUITY
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_l2_user_tables_bw> */
    dxe_l2_stack_and_heap_reserve NO_INIT BW
    dxe_l2_sw_code SW
    // VISA code.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_swco seg_swco seg_pmco) )
    dxe_l2_nw_code PM
    // ISA code.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_pmco seg_pmco) )
    dxe_l2_data DM
    // L2 data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_dmda seg_dmda_nw seg_dmda seg_vtbl .rtti .cht .edt) )
    dxe_l2_data_bw BW
    // L2 data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2 seg_l2_dmda_bw seg_dmda_bw seg_dmda seg_vtbl .rtti .cht .edt) )
    dxe_l2_bsz ZERO_INIT DM
    // L2 zero init data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2_bsz_data seg_bsz_data .bss32 .bss) )
    dxe_l2_bsz_bw ZERO_INIT BW
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2_bsz_data seg_bsz_data .bss8 .bss) )
    dxe_l2_noinit NO_INIT DM
    // L2 no init data.
    dxe_l2_noinit_bw NO_INIT BW
    // L2 no init data.
    dxe_l2_pm_data PM 32
    // L2 pm data.
    dxe_l2_pm_data_bw BW
    // L2 pm data.
    #else
    #warning L2 cached memory unused
    #endif // MY_L2_CACHED_MEM
    // L2 - uncached memory
    // Memory at the very start of L2 is dedicated for MCAPI/ICC support.
    // It is used to define a fixed size structure.
    // The labels defined below are used in runtime support for MCAPI and caches.
    ___MCAPI_common_start = MEMORY_START(mem_L2B1P1_bw);
    ___MCAPI_common_end = MEMORY_END (mem_L2B1P1_bw);
    ___MCAPI_arm_start = MEMORY_START(mem_L2B1P2_bw);
    ___MCAPI_arm_end = MEMORY_END (mem_L2B1P2_bw);
    ___MCAPI_sharc0_start = MEMORY_START(mem_L2B1P4_bw);
    ___MCAPI_sharc0_end = MEMORY_END (mem_L2B1P4_bw);
    ___MCAPI_sharc1_start = MEMORY_START(mem_L2B1P3_bw);
    ___MCAPI_sharc1_end = MEMORY_END (mem_L2B1P3_bw);
    ___l2_start = MEMORY_START(mem_L2B1P1_bw);
    ___l2_end = MEMORY_END (mem_L2B8BC_bw);
    ___l2_uncached_start = MEMORY_START(mem_L2B1P1_bw);
    ___l2_uncached_end = MEMORY_END (mem_L2B1P5_bw);
    ___l2_cached_start = MEMORY_START(mem_L2B2toB4_bw);
    ___l2_cached_end = MEMORY_END (mem_L2B8BC_bw);
    #if defined(MY_L2_UNCACHED_MEM)
    dxe_l2_uncached_bw BW
    INPUT_SECTIONS( $OBJS_LIBS(seg_l2_uncached seg_uncached) )
    } > MY_L2_UNCACHED_MEM
    dxe_l2_uncached DM
    #else
    #warning L2 uncached memory unused
    #endif // MY_L2_UNCACHED_MEM
    // SDRAM
    /*$VDSG<insert-new-sections-for-sdram> */
    // The symbols defined below are used in runtime support for MCAPI and
    // caches.
    ___sdram_start = MEMORY_START(mem_DMC0_SDRAM_A1);
    ___sdram_end = MEMORY_END (mem_DMC1_SDRAM_B4);
    ___sdram_arm_start = MEMORY_START(mem_DMC1_SDRAM_B4);
    ___sdram_arm_end = MEMORY_END (mem_DMC1_SDRAM_B4);
    /*$VDSG<insert-new-sections-at-mem_sdram_code> */
    #if defined(MY_SDRAM_SWCODE_MEM)
    dxe_sdram_sw_code SW
    // VISA code.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_sw_code> */
    INPUT_SECTIONS( $OBJS_LIBS(seg_sdram seg_ext_code seg_swco seg_pmco) )
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_sdram_sw_code> */
    } > MY_SDRAM_SWCODE_MEM
    #endif // defined(MY_SDRAM_SWCODE_MEM)
    dxe_sdram_nw_code PM
    // ISA code.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_nw_code> */
    INPUT_SECTIONS( $OBJS_LIBS(seg_sdram seg_ext_code seg_pmco) )
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_sdram_nw_code> */
    } > MY_SDRAM_NWCODE_MEM
    /*$VDSG<insert-new-sections-at-mem_sdram_dmda> */
    dxe_sdram_user_tables_nw DM
    FORCE_CONTIGUITY
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_user_tables_nw> */
    } > MY_SDRAM_DATA1_MEM
    dxe_sdram_cpp_ctors_nw DM
    // C++ global constructors list for word-addressed code.
    FORCE_CONTIGUITY
    __ctors = .; // __ctors points to the start of the section
    INPUT_SECTIONS( $OBJS_LIBS(seg_ctdm) )
    INPUT_SECTIONS( $OBJS_LIBS(seg_ctdml) )
    dxe_sdram_cpp_eh_gdt_nw DM
    // C++ exceptions data table.
    FORCE_CONTIGUITY
    INPUT_SECTIONS( $OBJS_LIBS(.gdt32 .gdt) )
    INPUT_SECTIONS( $OBJS_LIBS(.gdtl32 .gdtl) )
    dxe_sdram_cpp_eh_gdt_bw BW
    FORCE_CONTIGUITY
    INPUT_SECTIONS( $OBJS_LIBS(.gdt) )
    INPUT_SECTIONS( $OBJS_LIBS(.gdtl) )
    dxe_sdram_cpp_ctors_bw BW
    // C++ global constructors list for byte-addressed code.
    FORCE_CONTIGUITY
    _ctors. = .; // _ctors. points to the start of the section
    INPUT_SECTIONS( $OBJS_LIBS(seg_ctdml seg_ctdml_bw) )
    dxe_sdram_user_tables_bw BW
    FORCE_CONTIGUITY
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_user_tables_bw> */
    dxe_sdram_stack_and_heap_reserve NO_INIT BW
    } > SDRAM_STACK_HEAP_BLOCK
    dxe_sdram_data DM
    // general data.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_data> */
    INPUT_SECTIONS( $OBJS_LIBS(seg_sdram seg_ext_data seg_dmda_nw seg_dmda seg_vtbl .rtti .cht .edt) )
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_sdram_data> */
    dxe_sdram_data_bw BW
    // general data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_sdram seg_ext_data seg_dmda_bw seg_dmda seg_vtbl .rtti .cht .edt) )
    dxe_sdram_bsz ZERO_INIT DM
    // zero init data.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_bsz> */
    INPUT_SECTIONS( $OBJS_LIBS(seg_sdram_bsz_data seg_bsz_data .bss32 .bss) )
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_sdram_bsz> */
    dxe_sdram_bsz_bw ZERO_INIT BW
    // zero init data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_sdram_bsz_data seg_bsz_data .bss8 .bss) )
    dxe_sdram_noinit NO_INIT DM
    // no init data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_sdram_noinit_data seg_noinit_data) )
    dxe_sdram_noinit_bw NO_INIT BW
    // no init data.
    /*$VDSG<insert-new-sections-at-mem_sdram_pmda> */
    dxe_sdram_pm_data PM 32
    // pm data.
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_pm_data> */
    INPUT_SECTIONS( $OBJS_LIBS(seg_ext_pmda seg_pmda_nw seg_pmda) )
    /*$VDSG<insert-input-sections-at-the-end-of-dxe_sdram_pm_data> */
    dxe_sdram_pm_data_bw BW
    // pm data.
    INPUT_SECTIONS( $OBJS_LIBS(seg_ext_pmda seg_pmda) )
    dxe_sdram_data2 DM
    // general data.
    } > MY_SDRAM_DATA2_MEM
    dxe_sdram_data2_bw BW
    // general data.
    dxe_sdram_bsz2 ZERO_INIT DM
    // zero init data.
    dxe_sdram_bsz2_bw ZERO_INIT BW
    // zero init data.
    dxe_sdram_noinit2 NO_INIT DM
    // no init data.
    dxe_sdram_noinit2_bw NO_INIT BW
    // no init data.
    dxe_sdram_pm_data2 PM 32
    // pm data.
    dxe_sdram_pm_data2_bw BW
    // pm data.
    #endif // defined MY_SDRAM_DATA2_MEM
    #if defined(MY_SDRAM_BWONLY_MEM)
    dxe_sdram_data3_bw BW
    // general data.
    } > MY_SDRAM_BWONLY_MEM
    dxe_sdram_bsz3_bw ZERO_INIT BW
    // zero init data.
    dxe_sdram_noinit3_bw NO_INIT BW
    // no init data.
    dxe_sdram_pm_data3_bw BW
    // pm data.
    #endif // defined MY_SDRAM_BWONLY_MEM
    // Complete the stack and heap definitions.
    /*$VDSG<before-completing-the-stack-and-heap-definitions> */
    // #include "adi_ss_uc_app.ldf"
    // RESERVE(heaps_and_system_stack_in_L1, heaps_and_system_stack_in_L1_length, 0, 8)
    ldf_stack_space = heaps_and_system_stack_in_L1;
    ldf_stack_end = (ldf_stack_space + (((heaps_and_system_stack_in_L1_length * 7168) / 8192) - 8));
    ldf_stack_length = ldf_stack_end - ldf_stack_space;
    ldf_heap_space = ldf_stack_end + 8;
    ldf_heap_end = (ldf_heap_space + (((heaps_and_system_stack_in_L1_length * 1024) / 8192) - 8));
    ldf_heap_length = ldf_heap_end - ldf_heap_space;
    } > mem_block0_bw
    dxe_l2_stack_and_heap_expand NO_INIT BW
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_L2_stack_and_heap> */
    dxe_sdram_stack_and_heap_expand NO_INIT BW
    /*$VDSG<insert-input-sections-at-the-start-of-dxe_sdram_stack_and_heap> */
    /*$VDSG<insert-new-sections-at-the-end> */
    } /* SECTIONS */
    } /* SC589_CORE_1 */
  • Thanks, this file was working on Core 1, instead of 4 warnings I got 2, the remaining was for Core 2.
    However, the file was too long for me to safely find all the modifications.
    I found two commented out lines:
    and
    I tried that on Core 2 app.ldf but then it did not link.
    What more did you do?
    I assume it is not possible to use the same file on both Cores?
  • Ok, got it. Found the final modification, '#include #include "adi_ss_uc_app.ldf"' moved to near the end.
    Now the warnings are gone, thanks.
    Was it likely that this problem would invoke any real consequences?
    If so, what could happen?
    My application often crashes (sound stops, replaced by a continuous beep) after a few hours of operation, might it be connected?
  • You may face a problem in stack memory when your application grows more and more but not with simple application. In such a case you can simply increase the stack size to some extend and that solves your problem.
    Thanks.
