I have written a custom sigma studio module, a level detector which I can grow to the desired number of channels. And of which i can read out the levels of the channels programmatically. This module works fine when running in single core mode on the ADSP-SC594 on SHARC 0. But when i run it in dual core mode and execute the module on SHARC1, the output buffers do not seem to be mapped correctly. I get the following mapping CH0 -> CH0, CH1 -> CH2, CH2 -> CH4, CH3 -> CH6, ....
So it seems that the ouptut channel mapping skips a channel for each channel. Why is this the case?
Below is the code of the module. And a screenshot of the sigmastudio file with the 12 channel level detector.
/*============= D E F I N E S =============*/ #define MAX(a,b) (a<b?(b):(a)) typedef struct{ float32_t state01; float32_t state02; }State; /*============= C O D E =============*/ #pragma inline static float32_t max(float32_t a, float32_t b){ return (a>b)?a:b; } #pragma inline static float32_t abs(float32_t a){ return (a>0)?a:-a; } #pragma section("seg_pmco") void BPROCESS_LevelDetector (SSBlockAlgo* pBlkAlgoInfo) { uint32_t nChannel, nSample; uint32_t nBlockSize, nChannels; #if (MIPS_MEASUREMENT) START_CYCLE_COUNT(nCycleStart); #endif nChannels = pBlkAlgoInfo->nGrowth; State* pState = (State*)pBlkAlgoInfo->pState; float32_t* pParam = (float32_t*)(pBlkAlgoInfo->pParam); for (nChannel = 0; nChannel < nChannels; nChannel++) { int32_t nSamplingRate = pBlkAlgoInfo->pInputs[nChannel].pBlockProperties->nSamplingRate; float32_t fAlphaRelease = exp(-1.0 / (nSamplingRate * pParam[0])); /* param in seconds */ float32_t fAlphaAttack = exp(-1.0 / (nSamplingRate * pParam[1])); /* param in seconds */ nBlockSize = pBlkAlgoInfo->pInputs[nChannel].pBlockProperties->nBlockSize; for(nSample = 0; nSample< nBlockSize; nSample++){ float32_t* pInput = pBlkAlgoInfo->pInputs[nChannel].pSamples; float32_t* pOutput = pBlkAlgoInfo->pOutputs[nChannel].pSamples; pOutput[nSample] = pInput[nSample]; pState[nChannel].state02 = max(pInput[nSample], fAlphaRelease * pState[nChannel].state02 + (1 - fAlphaRelease) * pInput[nSample]); pState[nChannel].state01 = fAlphaAttack * pState[nChannel].state01 + (1 - fAlphaAttack) * pState[nChannel].state02; float32_t* pVal = &pParam[2]; float32_t fLevel = abs(pState[nChannel].state01); /* according to compiler docs, log10 returns 0 in case of domain error, so no need to check for 0*/ float32_t fdB = 20*log10(fLevel); if(fLevel == 0 || fdB<-96.0) pVal[nChannel] = -96.0; else if(fdB>32.0) pVal[nChannel] = 32.0; else pVal[nChannel] = fdB; } } #if (MIPS_MEASUREMENT) STOP_CYCLE_COUNT(nCycleEnd, nCycleStart); anCycleDump[nDumpIndex++] = nCycleEnd; if (nDumpIndex == MIPS_DUMP_SIZE) { nDumpIndex = 0; } memcpy((uint32_t *) (pBlkAlgoInfo->pOutputs[0].pSamples), anCycleDump, MIPS_DUMP_SIZE); #endif } void INIT_LevelDetector (SSBlockAlgo* pBlkAlgoInfo) { int i; int *pSymbol = pBlkAlgoInfo->pExtSymbols; }
Typo's
[edited by: Robrechtb at 11:06 AM (GMT -5) on 9 Dec 2022]
