We are curently using the ADSP-SC589 SHARC DSP in combination with SigmaStudio. We have it connected via a USBi interface which uses SPI to communicate and evrything works great.
For our new design we would actually want to use 2 of these DSP's with sigma studio. According to the documentation of the USBi (https://www.analog.com/en/app-notes/an-1006.html) the following is possible:
The USBi can support up to two identical devices on the same SPI latch if the SPI address pins of the target devices are independently set to two different addresses, matching the addresses in the drop-down box in the Hardware Configuration tab of SigmaStudio.
So as i understand it, it should be possible to connect 2 SPI slaves (the DSP's) to the USBi with both using the same CS signal, thus requiring no changes to the USBi connector. I am assuming the addressing then happens on a SPI protocol level? How exactly is the address configured on the DSP? Is this configured in the function call "adi_ss_connection_Init" in the firmware running on the DSP?
According to the documentation it is also possible to address different devices using the additional cs pins on the USBi. However, this requires additional wires to be soldered to the USBi and devboard and i would like to avoid this and prefer the other solution.
Robrecht
