We are using SAM (ADZS-SC589-MINI) evaluation board to confirm Ethernet connection.
We are following the instructions on SAM wiki, but we are unable to switch COM port settings as described on wiki.
wiki.analog.com/.../examples-ethernet-audio
Could you please tell us a few things that concern you?
(1) What CCES sample project should I use to confirm?
Do I need to get the sample project from SRF?
Currently we are trying to start a project in SAM_BareMetal_SDK-Rel2.1.2 framework.
(2) When setting the IP address, it says to execute the syslog command, but I don't know how to confirm this.
Please tell me in detail how to confirm.
(3) When I start Tera Term and check COM port settings, only a normal COM port is visible.
The port labeled SC5xx Communications Port as described on wiki is not displayed.
Please tell me how to set it so that the port labeled SC5xx Communications Port is displayed.
Development environment being checked:
・ADZS-SC589-MINI(Rev1.5)
・CCES 3.0.2
・ICE-1000(1.2)
・SAM_BareMetal_SDK-Rel2.1.2 framework
Best regards.
