I want to operate the SHARC Audio Module as a USB device using the CLD library
Thank you for your help.
I tried to operate the SHARC Audio Module as a USB device by following the steps below.
It didn't work.
Create a SHARC Audio Module Bare Metal Project.
(CCES2.9.4, using Audio Project Fin)
From the CLOSED LOOP DESIGN website
Download CLD CDC USB to Serial example V1.0 and
I copied the required files to the core0 src folder of my project.
Then import the library into my project.
Add USB related processing in the main function of project startup_code_core0.c by referring
to the user guide of the library.
while (1) {
    audioframework_background_loop();
    if (rv == USER_CDC_INIT_ONGOING)
        rv = user_cdc_init();
    else if (rv == USER_CDC_INIT_SUCCESS)
        user_cdc_main();
The user_cdc_init function is successful.
I run the program and connect the P10 on the board to my PC with a USB cable,
but it doesn't work at all.
The USB event handler is only called once at connection time and is not called at all.
Can anyone please tell me how to make USB work?
