U-Boot Watchdog Issue on SC573-EZKIT after reset command
The user encountered an issue where the watchdog timer fails to trigger a reboot after a software reset on the SC573-EZKIT board running U-Boot. The final answer suggests applying a patch from the 'wdt_fix' branch to resolve the problem, which has been confirmed to work by another user. The issue is also noted to be fixed in the upcoming ADSP-Linux Yocto Release version 5.0.0.
Product Number: ADSP-SC573
Problem Description:
We are using U-Boot on an SC573-EZKIT board with the watchdog enabled. We confirmed the watchdog is properly configured by rebuilding U-Boot with watchdog support enabled in the device tree .dtsi file.
Our testing shows an unexpected behavior related to the reset command:
  • Expected Behavior: When we use the panic command from the U-Boot command-line interface (CLI), the watchdog correctly triggers a reboot of the board after a few seconds.
  • Unexpected Behavior: If we first execute the reset command and then, in the subsequent U-Boot session, run the panic command, the system freezes. The watchdog fails to trigger, and a reboot does not occur.
Question:
Could you explain why the reset command appears to disable or interfere with the watchdog functionality in the subsequent U-Boot session? Can you please provide a solution or a workaround to ensure the watchdog remains active after a software reset.
Thanks!
  • We will check with ADSP-Linux Yocto Release version 5.0.0 if we can reproduce on our end.
  • I have reproduced the issue, will check in more details
  • Hi  ,
    Thank you for reporting this issue.
    Could you apply the following patch to your meta layer and try the same again?
    diff --git a/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi.inc b/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi.inc
    index c202195..e8f1a69 100644
    --- a/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi.inc
    +++ b/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi.inc
    @@ -31,7 +31,7 @@ python() {
             d.setVar('UBOOT_SOM', d.getVar('UBOOT_SOM_FILE') + " " + d.getVar('UBOOT_SOM_FALCON_FILE'))
    -UBOOT_BRANCH ?= "main"
    +UBOOT_BRANCH ?= "wdt_fix"
     # On the SC598, we can't boot directly from the eMMC due to default speed configuration issues
     # We can boot the SPL from OSPI or QSPI and then subsequently boot U-Boot Proper from eMMC
    diff --git a/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi_2023.04.bb b/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi_2023.04.bb
    index ccbff7f..22d9fd9 100644
    --- a/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi_2023.04.bb
    +++ b/meta-adi-adsp-sc5xx/recipes-bsp/u-boot/u-boot-adi_2023.04.bb
    @@ -2,7 +2,7 @@ inherit adsp-sc5xx-compatible
     require u-boot-adi.inc
    -SRCREV = "dd19d915e05516b3b4efd2ae03afab8bd29dea0e"
    +SRCREV = "861744a26ef88c33780d831247cd893ab00a7775"
     UBOOT_INITIAL_ENV = ""
    This will be fixed in the upcoming yocto release.
  • Hi  ,
    I tested the single-line change in the source present in the "wdt_fix" branch and it worked, as we are not using Yocto for building. Many thanks for your support.
