Linux won't boot on custom board - how to make changes to linux-adi yocto layer
Product Number: ADSP-SC589
Software Version: Yocto 3.1.1
We have a custom board that uses the SC589 chip.
We are building Yocto/Linux and have successfully managed to boot into UBOOT from flash but the boot sequence hangs on "Starting kernel ...". The logs are shown below.
We are having to make various modifications to both u-boot and linux source code using devtool, which include UART, flash chip, gpio settings and a couple other things.
The steps for making modifications to uboot are:
devtool modify u-boot-adi
// make changes
git commit -m "uboot changes" .
devtool finish u-boot-adi meta-adi-adsp-sc5xx
bitbake adsp-sc5xx-minimal
The steps for making modifications to linux are:
devtool modify linux-adi
// make changes
git commit -m "linux changes" .
devtool finish linux-adi meta-adi-adsp-sc5xx
In both cases, devtool creates git patches which get added to the build. I know for sure that the modifications to u-boot are making their way into the build, otherwise the board wouldn't boot into UBOOT, which it does. I have little confidence that the changes are making their way into linux.
One of the changes we have to make is to route all logging to UART1. This is clearly working on UBOOT. If the changes weren't making their way into linux, this would explain the hanging message "Starting kernel ...".
Another reason why I think the changes aren't working on the linux-adi layer is because of all the git branches.
On the u-boot-adi layer, the branches are:
devtool
devtool-no-overrides
devtool-override-adsp-sc598-som-ezkit
main
Our modifications are made to the "devtool" branch. Everytime we do "devtool modify u-boot-adi" the modifications from previous builds are persistent and the git patch files don't get removed.
On the linux-adi layer, there are MANY branches including:
devtool
devtool-override-adsp-sc589-mini
Every time we make modifications to the linux-adi layer, all the previous git patch files get removed. My theory is that when we make our changes to the devtool branch they get overridden by the devtool-override-adsp-sc589-mini branch.
Which might mean that every time we do a build, it's using the wrong branch and none of our changes get through.
Is that correct?
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Dec 23 2019, 02:06:26.
Port /dev/ttyUSB0, 13:05:04
Press CTRL-A Z for help on special keys
U-Boot SPL 2023.04 (Feb 12 2024 - 09:53:05 +0000)
ADI Boot Mode: 0x1 (QSPI Master)
Trying to boot from BOOTROM
U-Boot 2023.04 (Feb 12 2024 - 09:53:05 +0000)
CPU:   ADSP ADSP-SC589-0.1 (spi flash boot)
Detected Revision: 1.1
Model: ADI sc589-mini
DRAM:  224 MiB
Core:  84 devices, 20 uclasses, devicetree: embed
MMC:   mmc0@31010000: 0
Loading Environment from SPIFlash... SF: Detected w25q01jv with page size 256 Bytes, erase size 4 KiB, total 128 MiB
OK
In:    serial@0x31003400
Out:   serial@0x31003400
Err:   serial@0x31003400
Net:   eth0: eth0
Hit any key to stop autoboot:  0
device 0 offset 0xe0000, size 0x6c519a
SF: 7098778 bytes @ 0xe0000 Read: OK
## Loading kernel from FIT Image at c3000000 ...
   Using 'conf-1' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel-1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0xc30000dc
     Data Size:    4786064 Bytes = 4.6 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x80008000
     Entry Point:  0x80008000
     Hash algo:    sha1
     Hash value:   b7604667488c65d2c61d90664d0a0e18ac8aa23e
     Sign algo:    sha1,rsa2048:
     Sign value:   unavailable
   Verifying Hash Integrity ... sha1+ sha1,rsa2048:- OK
## Loading ramdisk from FIT Image at c3000000 ...
   Trying 'ramdisk-3' ramdisk subimage
     Description:  Initial Ram File System
     Type:         RAMDisk Image
     Data Start:   0xc3495d34
     Data Size:    2289283 Bytes = 2.2 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0xc5000000
     Entry Point:  0xc5000000
     Hash algo:    sha1
     Hash value:   105a336b429f24aef60ea7d251fc0b0875558a9e
   Loading ramdisk from 0xc3495d34 to 0xc5000000
## Loading fdt from FIT Image at c3000000 ...
   Trying 'fdt-2' fdt subimage
     Description:  Flattened Device Tree Blob
     Type:         Flat Device Tree
     Data Start:   0xc34909a0
     Data Size:    21122 Bytes = 20.6 KiB
     Architecture: ARM
     Load Address: 0x80000000
     Hash algo:    sha1
     Hash value:   bf0474216801d4bdc9a917f752a5c6b41c796252
   Loading fdt from 0xc34909a0 to 0x80000000
   Booting using the fdt blob at 0x80000000
Working FDT set to 80000000
   Loading Kernel Image
   Using Device Tree in place at 80000000, end 80008281
Starting kernel ...
  • Forums on other websites say that you have to rebase some of the devtool-override branches. Is that right?
  • I noticed in sc589-mini/build/workspace/sources/linux-adi/.kernel-meta there is a file unused.patch.queue which contains my patch file. So this reaffirms that my changes aren't making their way to the build.
  • Hi only use devtool as to write new features, or investigate issues.
    Few things that I have noted with how devtool works
    If you have patches in linux recipe, then they will not be applied when you do
    if I need those patches I just apply them manually,
    To check with patches are in when bitbake is building recipes I do
    bitbake -e linux-adi | grep "SRC_URI=" as output you will get what's is in sources and with patches will be supplied to recipe when it start building process
    After the patch is completed I delete reset the repo to have clean devtool workspace and submit to main linux repo.
    Other thing to note is to check that conf/bblayers.conf contain the devtool workspace , it will be reset each time you do the
    source setup-environment
     There could be better approaches but that what works for me
  • Weird that this works with the u-boot-adi recipe but not linux-adi. Is it because of all the git branches on the linux-adi recipe ?
    What do you mean by "i just apply them manually" ?
    Is there a better, more canonical way of making changes to support a custom board? Our approach has been to use the MINI as a base line and make changes to that to suit our board. But maybe there is a better, more stable way of doing things.
  • Other approach that we use in team, we have kernel that works with mainline linux, so we have seperate repository where we have just kernel source and we compile those, and then update the Image.gz to fitImage inside tmp/deploy/images directory.
    so smth copy Image.gz to the tmp/deploy/Images(or preferably other directory to not overwrite the content whe bitabke rebuilds the yocto) and do
    mkimage -f fit-image.its fitImage
    this will not trigger rebuild of whole rootfs but allow quickly iterate while developing
    And  after the development is done add those changes as patches to Yocto recipe.
    Have you created custom layer with your changes for SC589-mini? And do you host your versions of linux-adi and u-boot-adi repositories?
  • So I'm happy creating git patches, the problem is bitbake is not picking them up. And I have a feeling it's to do with all the devtool-override git branches, of which there are many on the linux-adi recipe. I don't have this problem on the uboot-adi recipe since there are no devtool-override git branches.
    So I haven't created a custom layer, i'm just doing modifications to the existing sc589-mini layer using "devtool modify" and "devtool finish". Is creating a customer layer the standard way of doing things?
    No we don't host our versions of linux-adi nor u-boot-adi. Hence why the git patch solution seems good but i can't get it to work with linux-adi.
    Whenever you do "devtool modify linux-adi" it even spits out a message
    WARNING: SRC_URI is conditionally overridden in this recipe, thus several devtool-override-* branches have been created, one for each override that makes changes to SRC_URI. It is recommended that you make changes to the devtool branch first, then checkout and rebase each devtool-override-* branch and update any unique patches there (duplicates on those branches will be ignored by devtool finish/update-recipe)
    INFO: Recipe linux-adi now set up to build from /home/pf/sc589-mini/build/workspace/sources/linux-adi
  •   When you say "And  after the development is done add those changes as patches to Yocto recipe."
    What are your exact steps for that? I believe i'm doing exactly that but they're not getting pulled into the build.
  • Hi I think the issue is that when you do the
    bitbake linux-adi
    its builds the linux-adi in workspace, without applying the patches in recipe,
    try to remove the workspace from conf/bblayers.conf and see if it builds with your patches applied
    I haven't found workaround to this issue yet
  • The alternative for me is that I fork every single lnxdsp repository and apply my changes in the relevant forks. But that seems like the wrong ting to do.
  • So my approach is to do:
    // make changes
    // git commit
    rm -rf workspace/sources/linux-adi
    bitbake adsp-sc5xx-tiny
    Is there a way to build the code directly from the workspace, which should still include my changes. Rather than hoping it applies the git patches, which it doesn't.
