Hi, I have a customer board and need to enable more SPORTs in DTS and all run TDM8 format, so I have extended the sc594-som-ezkit.dts and sc59xx.dtsi
So far I can see that registration of the soundcards in Linux work well but when I start audio playback on any device except for the i2s4, I get errors.
Is there anything wrong with my configuration / DTS files or is there any issue that the SPORT drivers just support SPORT4 ?
# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sc5xxasoccard [sc5xx-asoc-card], device 0: TDM8 tdm8-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: sc5xxasoccard_1 [sc5xx-asoc-card], device 0: TDM8 tdm8-hifi-0 []
Subdevices: 1/1
card 2: sc5xxasoccard_2 [sc5xx-asoc-card], device 0: TDM8 tdm8-hifi-0 []
Subdevices: 1/1
card 3: sc5xxasoccard_3 [sc5xx-asoc-card], device 0: TDM8 tdm8-hifi-0 []
Subdevices: 1/1
card 4: sc5xxasoccard_4 [sc5xx-asoc-card], device 0: TDM8 tdm8-hifi-0 []
Subdevices: 1/1
aplay -Ddefault:CARD=sc5xxasoccard_3 -fS32_LE -t raw -c8 -r 48000 /mnt/tdm8_si
ne_silence.raw
Playing raw data '/mnt/tdm8_sine_silence.raw' : Signed 32 bit Little Endian, Rate 48000 Hz, Channels 8
adi-dma 31023000.dma: channel 4: dma with not-done status 0x76200
/* * Device tree for ADI sc594-som-ezkit board * * Copyright 2014 - 2020 Analog Devices Inc. * * Licensed under the GPL-2 or later. * */ /dts-v1/; #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/pinctrl/adi-adsp.h> #include <dt-bindings/pinctrl/adi-adsp-sru.h> #include <dt-bindings/net/ti-dp83867.h> #include "sc59x.dtsi" / { model = "ADI sc594-som-ezkit"; compatible = "adi,sc594-som-ezkit", "adi,sc59x"; aliases { }; memory@C3000000 { device_type = "memory"; reg = <0xC3000000 0xF000000>; }; #ifdef IGNORE_FOR_NOW reserved-memory { #address-cells = <1>; #size-cells = <1>; ranges; vdev0vrings: vdev0vring0@20010000 { reg = <0x20010000 0x4000>; no-map; }; vdev0buffer: vdev0buffer@20014000 { compatible = "shared-dma-pool"; reg = <0x20014000 0x20000>; no-map; }; vdev1vrings: vdev0vring0@20034000 { reg = <0x20034000 0x4000>; no-map; }; vdev1buffer: vdev0buffer@20038000 { compatible = "shared-dma-pool"; reg = <0x20038000 0x20000>; no-map; }; }; reserved-memory { #address-cells = <1>; #size-cells = <1>; ranges; rsc_tbl0: rsc_tbl0@20000000 { reg = <0x20000000 0x400>; /*1KiB*/ no-map; }; rsc_tbl1: rsc_tbl0@20000400 { reg = <0x20000400 0x400>; /*1KiB*/ no-map; }; sram_B1_unused@20000800 { reg = <0x20000800 0x4800>; /*18KiB*/ no-map; }; sharc_internal_icc@20005000 { reg = <0x20005000 0x20000>; /*128KiB*/ no-map; }; }; #endif scb { sharc0: core1-rproc@0x28240000 { compatible = "adi,remoteproc"; reg = <0x28240000 0x160000>, <0x20000000 0x200000>; core-id = <1>; core-irq = <74>; /* SOFT1 */ firmware-name = "adi_adsp_core1_fw.ldr"; interrupts = <GIC_SPI 165 IRQ_TYPE_EDGE_RISING>; /* TRU0_SLV3 */ adi,rcu = <&rcu>; adi,l1-da = <0x240000 0x3a0000>; adi,l2-da = <0x20000000 0x20200000>; /*adi,rsc-table = <&rsc_tbl0>;*/ adi,verify = <1>; adi,tru = <&tru>; adi,tru-master-id = <140>; /* trigger master SOFT4 */ status = "okay"; }; sharc1: core2-rproc@0x28a40000 { compatible = "adi,remoteproc"; reg = <0x28a40000 0x160000>, <0x20000000 0x200000>; core-id = <2>; core-irq = <75>; /* SOFT2 */ firmware-name = "adi_adsp_core2_fw.ldr"; interrupts = <GIC_SPI 165 IRQ_TYPE_EDGE_RISING>; /* TRU0_SLV3 */ adi,rcu = <&rcu>; adi,l1-da = <0x240000 0x3a0000>; adi,l2-da = <0x20000000 0x20200000>; /*adi,rsc-table = <&rsc_tbl1>;*/ adi,verify = <1>; adi,tru = <&tru>; adi,tru-master-id = <141>; /* trigger master SOFT5 */ status = "okay"; }; a2b_slave_codec: a2b_slave_codec { compatible = "sonavox,tdm8"; model = "tdm8"; status = "okay"; }; a2b_master_codec: a2b_master_codec { compatible = "sonavox,tdm8"; model = "tdm8"; status = "okay"; }; adc_amp_codec: adc_amp_codec { compatible = "sonavox,tdm8"; model = "tdm8"; status = "okay"; }; dsp_codec: dsp_codec { compatible = "sonavox,tdm8"; model = "tdm8"; status = "okay"; }; amps_codec: amps_codec { compatible = "sonavox,tdm8"; model = "tdm8"; status = "okay"; }; sound_a2b_slave { compatible = "sc5xx,asoc-card"; adi,cpu-dai = <&i2s4>; adi,codec = <&a2b_slave_codec>; iram = <&sram1>; }; sound_a2b_master { compatible = "sc5xx,asoc-card"; adi,cpu-dai = <&i2s5>; adi,codec = <&a2b_master_codec>; iram = <&sram1>; }; sound_adc_amp { compatible = "sc5xx,asoc-card"; adi,cpu-dai = <&i2s0>; adi,codec = <&adc_amp_codec>; iram = <&sram1>; }; sound_dsp { compatible = "sc5xx,asoc-card"; adi,cpu-dai = <&i2s1>; adi,codec = <&dsp_codec>; iram = <&sram1>; }; sound_amps { compatible = "sc5xx,asoc-card"; adi,cpu-dai = <&i2s2>; adi,codec = <&s_codec>; iram = <&sram1>; }; }; }; &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_default>; status = "okay"; }; &uart2 { pinctrl-names = "default"; pinctrl-0 = <&uart2_hwflow>; status = "okay"; }; &rtc0 { status = "disabled"; }; &spi0 { pinctrl-names = "default"; pinctrl-0 = <&spi0_default>; status = "okay"; cs-gpios = <&gpa 9 GPIO_ACTIVE_LOW>, <&gpa 10 GPIO_ACTIVE_LOW>; spidev@0 { #address-cells = <1>; #size-cells = <1>; compatible = "rohm,dh2228fv"; spi-max-frequency = <5000000>; reg = <0>; }; spidev2@1 { #address-cells = <1>; #size-cells = <1>; compatible = "rohm,dh2228fv"; spi-max-frequency = <5000000>; reg = <1>; }; }; &spi2 { pinctrl-names = "default"; pinctrl-0 = <&spi2_default>; status = "okay"; cs-gpios = <&gpa 5 GPIO_ACTIVE_LOW>, <&gpa 2 GPIO_ACTIVE_LOW>; spidev@0 { #address-cells = <1>; #size-cells = <1>; compatible = "rohm,dh2228fv"; spi-max-frequency = <5000000>; reg = <0>; }; spidev@1 { #address-cells = <1>; #size-cells = <1>; compatible = "rohm,dh2228fv"; spi-max-frequency = <5000000>; reg = <1>; }; }; &spi3 { pinctrl-names = "default"; pinctrl-0 = <&spi3_default>; status = "okay"; cs-gpios = <&gpg 8 GPIO_ACTIVE_LOW>, <&gpg 9 GPIO_ACTIVE_LOW>; spidev@0 { #address-cells = <1>; #size-cells = <1>; compatible = "rohm,dh2228fv"; spi-max-frequency = <5000000>; reg = <0>; }; spidev@1 { #address-cells = <1>; #size-cells = <1>; compatible = "rohm,dh2228fv"; spi-max-frequency = <5000000>; reg = <1>; }; }; &ospi { pinctrl-names = "default"; pinctrl-0 = <&ospi_default>; status = "okay"; flash0: s28hl01gt@0 { #address-cells = <1>; #size-cells = <1>; compatible = "s28hl01gt"; reg = <0>; /* Adjust as needed, depends on board signal integrity -- I was seeing issues with data writes at faster speeds */ spi-max-frequency = <36000000>; /*m25p,fast-read;*/ cdns,page-size = <256>; cdns,block-size = <1024>; cdns,read-delay = <4>; cdns,tshsl-ns = <50>; cdns,tsd2d-ns = <50>; cdns,tchsh-ns = <4>; cdns,tslch-ns = <4>; partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; partition@0 { label = "U-Boot"; reg = <0x0 0x80000>; }; partition@1 { label = "U-Boot Environment 1"; reg = <0x80000 0x40000>; }; partition@2 { label = "U-Boot Environment 2"; reg = <0xC0000 0x40000>; }; partition@3 { label = "Device Tree Blob 1"; reg = <0x100000 0x40000>; }; partition@4 { label = "Device Tree Blob 2"; reg = <0x140000 0x40000>; }; partition@5 { label = "Kernel zImage 1"; reg = <0x200000 0x600000>; }; partition@6 { label = "Kernel zImage 2"; reg = <0x800000 0x600000>; }; partition@7 { label = "User Data"; reg = <0xE00000 0x0300000>; }; partition@8 { label = "Rootfs 1"; reg = <0x1100000 0x1800000>; }; partition@9 { label = "Rootfs 2"; reg = <0x2900000 0x1700000>; }; }; }; }; &i2c0 { status = "disabled"; }; &i2c1 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; }; &i2c2 { pinctrl-names = "default"; pinctrl-0 = <&i2c2_pins>; status = "okay"; }; &i2c4 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c4_pins>; }; &i2c5 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c5_pins>; }; &i2s0 { status = "okay"; }; &i2s1 { status = "okay"; }; &i2s2 { status = "okay"; }; &i2s4 { pinctrl-names = "default"; pinctrl-0 = <&sru_dai1>; status = "okay"; }; &i2s5 { status = "okay"; }; &crc0 { status = "disabled"; }; &crc1 { status = "disabled"; }; &can0 { pinctrl-names = "default"; /*pinctrl-0 = <&can0_default>;*/ phy-name = "tja1055"; phy-gpios = <&gpb 8 0>, /* en PB8 */ <&gpb 2 0x1>; /* stb PB2, GPIO_ACTIVE_LOW */ status = "disabled"; }; &can1 { pinctrl-names = "default"; pinctrl-0 = <&can1_default>; phy-name = "tja1145"; phy-spibus = /bits/ 16 <0>; phy-spiclk = <1000000>; phy-spics = /bits/ 16 <44>; /* GPIO_PC12 */ status = "disabled"; }; &emac0 { snps,reset-active-low; snps,reset-delays-us = <0 200 500>; phy-handle = <&dp83867>; phy-mode = "rmii-id"; pinctrl-names = "default"; pinctrl-0 = <ð0_default>; status = "okay"; snps,mtl-rx-config = <&emac0rxconfig>; snps,mtl-tx-config = <&emac0txconfig>; emac0txconfig: tx-config { snps,tx-queues-to-use = <3>; queue0 { snps,dcb-algorithm; }; queue1 { snps,dcb-algorithm; }; queue2 { snps,dcb-algorithm; }; }; emac0rxconfig: rx-config { snps,rx-queues-to-use = <1>; queue0 { snps,dcb-algorithm; }; queue1 { snps,dcb-algorithm; }; queue2 { snps,dcb-algorithm; }; }; mdio0 { compatible = "snps,dwmac-mdio"; #address-cells = <1>; #size-cells = <0>; dp83867: ethernet-phy@0 { reg = <0>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>; ti,dp83867-rxctrl-strap-quirk; }; }; }; &emac1 { phy-handle = <&dp83848>; phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <ð1_default>; status = "disabled"; mdio1 { compatible = "snps,dwmac-mdio"; #address-cells = <1>; #size-cells = <0>; dp83848: ethernet-phy@1 { reg = <1>; }; }; }; &usb0_phy { reset-gpios = <&gpf 15 GPIO_ACTIVE_LOW>; status = "okay"; }; &usb0 { dr_mode = "host"; pinctrl-names = "default"; pinctrl-0 = <&usbc0_default>; status = "okay"; }; &icc0 { adi,tru = <&tru>; status = "okay"; }; /* &mmc0 { bus-width = <4>; pinctrl-names = "default"; pinctrl-0 = <&mmc0_8bgrp>; supports-highspeed; status = "disabled"; }; &video_decoder { pinctrl-names = "8bit", "16bit", "24bit"; pinctrl-0 = <&ppi0_8b>; pinctrl-1 = <&ppi0_16b>; pinctrl-2 = <&ppi0_24b>; status = "disabled"; }; &video_encoder { pinctrl-names = "8bit", "16bit", "24bit"; pinctrl-0 = <&ppi0_8b>; pinctrl-1 = <&ppi0_16b>; pinctrl-2 = <&ppi0_24b>; status = "disabled"; }; */ /* &lp0 { pinctrl-names = "default"; pinctrl-0 = <&lp0_default>; status = "okay"; }; &lp1 { pinctrl-names = "default"; pinctrl-0 = <&lp1_default>; status = "okay"; }; */ &sram_mmap { status = "disabled"; }; &pinctrl0 { uart0_default: uart0_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('D', 8, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('D', 9, ADI_ADSP_PINFUNC_ALT0)>; }; }; uart2_hwflow: uart2_hwflow_pins { pins { pinmux = <ADI_ADSP_PINMUX('D', 10, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('D', 11, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('D', 12, ADI_ADSP_PINFUNC_ALT1)>, <ADI_ADSP_PINMUX('D', 13, ADI_ADSP_PINFUNC_ALT1)>; }; }; spi0_default: spi0_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('A', 6, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('A', 7, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('A', 8, ADI_ADSP_PINFUNC_ALT0)>; }; }; spi2_default: spi2_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('A', 0, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('A', 1, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('A', 4, ADI_ADSP_PINFUNC_ALT0)>; }; }; spi3_default: spi3_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('G', 5, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('G', 6, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('G', 7, ADI_ADSP_PINFUNC_ALT0)>; }; }; ospi_default: ospi_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('C', 8, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 9, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 10, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 11, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 12, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 13, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 14, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 15, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('D', 0, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('D', 1, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('D', 4, ADI_ADSP_PINFUNC_ALT2)>; }; }; i2c1_pins: i2c1_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('B', 0, ADI_ADSP_PINFUNC_ALT1)>, <ADI_ADSP_PINMUX('B', 1, ADI_ADSP_PINFUNC_ALT1)>; }; }; i2c2_pins: i2c2_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('A', 14, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('A', 15, ADI_ADSP_PINFUNC_ALT0)>; }; }; i2c4_pins: i2c4_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('C', 0, ADI_ADSP_PINFUNC_ALT1)>, <ADI_ADSP_PINMUX('C', 1, ADI_ADSP_PINFUNC_ALT1)>; }; }; i2c5_pins: i2c5_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('C', 2, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('C', 3, ADI_ADSP_PINFUNC_ALT0)>; }; }; eth0_default: eth0_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('H', 3, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 4, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 5, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 6, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 7, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 8, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 9, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 10, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 11, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('H', 13, ADI_ADSP_PINFUNC_ALT0)>; }; }; eth1_default: eth1_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('E', 11, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('E', 12, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('E', 13, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('E', 14, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('E', 15, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 0, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 1, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 2, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 3, ADI_ADSP_PINFUNC_ALT0)>; }; }; mmc0_8bgrp: mmc0_8bgrp_pins { pins { pinmux = <ADI_ADSP_PINMUX('F', 2, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 3, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 4, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 5, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 6, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 7, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 8, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 9, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 10, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 11, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('F', 12, ADI_ADSP_PINFUNC_ALT0)>; }; }; usbc0_default: usbc0_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('F', 3, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 4, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 5, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 6, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 7, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 8, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 9, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 10, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 11, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 12, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 13, ADI_ADSP_PINFUNC_ALT2)>, <ADI_ADSP_PINMUX('F', 14, ADI_ADSP_PINFUNC_ALT2)>; }; }; can1_default: can1_default_pins { pins { pinmux = <ADI_ADSP_PINMUX('G', 1, ADI_ADSP_PINFUNC_ALT0)>, <ADI_ADSP_PINMUX('G', 2, ADI_ADSP_PINFUNC_ALT0)>; }; }; }; &sru_ctrl_dai0 { status = "okay"; sru_dai0: sru_dai0_mux { route { sru-routing = <DAI0_HIGH_F DAI0_PBEN01_I>, /* set DAI0_PIN01 to output */ <SPT0_AD0_O_BD DAI0_PB01_I>, /* route DAI0_PIN01 to SPT0_AD0 */ <DAI0_LOW_F DAI0_PBEN02_I>, /* set DAI0_PIN02 to input */ <DAI0_PB01_O_ABCDE SPT0_BD0_I>, /* route DAI1_PIN02 to SPT0_BD0 */ <DAI0_HIGH_F DAI0_PBEN03_I>, /* set DAI1_PIN03 to output */ <SPT0_ACLK_O_A DAI0_PB03_I>, /* route SPT0_ACLK to DAI1_PIN03 */ <SPT0_ACLK_O_A SPT0_BCLK_I>, /* route SPT0_ACLK to SPT0_BLCK */ <DAI0_HIGH_F DAI0_PBEN04_I>, /* set DAI1_PIN04 to output */ <SPT0_AFS_O_D DAI0_PB04_I>, /* route SPT0_AFS to DAI1_PIN04 */ <SPT0_AFS_O_D SPT0_BFS_I>, /* route SPT0_AFS to SPT0_BFS */ <DAI0_LOW_F DAI0_PBEN05_I>, /* set DAI0_PIN05 to intput */ <DAI0_PB05_O_ABCDE SPT1_BD0_I>, /* route DAI0_PIN5 to SPT1_BD0 */ <DAI0_HIGH_F DAI0_PBEN06_I>, /* set DAI0_PIN06 to output */ <SPT1_AD0_O_BD DAI0_PB06_I>, /* route SPT1_AD0 to DAI0_PIN6 */ <DAI0_HIGH_F DAI0_PBEN07_I>, /* set DAI1_PIN07 to output */ <SPT1_ACLK_O_A DAI0_PB07_I>, /* route SPT1_ACLK to DAI1_PIN07 */ <SPT1_ACLK_O_A SPT1_BCLK_I>, /* route SPT1_ACLK to SPT1_BLCK */ <DAI0_HIGH_F DAI0_PBEN08_I>, /* set DAI1_PIN08 to output */ <SPT1_AFS_O_D DAI0_PB04_I>, /* route SPT1_AFS to DAI1_PIN08 */ <SPT1_AFS_O_D SPT1_BFS_I>, /* route SPT1_AFS to SPT1_BFS */ <DAI0_HIGH_F DAI0_PBEN09_I>, /* set DAI0_PIN09 to output */ <SPT2_AD0_O_BD DAI0_PB09_I>, /* route SPT2_AD0 to DAI0_PIN09 */ <DAI0_HIGH_F DAI0_PBEN10_I>, /* set DAI0_PIN10 to input */ <SPT2_AD1_O_BD DAI0_PB10_I>, /* route SPT2_AD1 to DAI0_PIN10 */ <DAI0_HIGH_F DAI0_PBEN11_I>, /* set DAI0_PIN11 to output */ <SPT2_BD0_O_BD DAI0_PB11_I>, /* route SPT2_BD0 to DAI0_PIN11 */ <DAI0_HIGH_F DAI0_PBEN12_I>, /* set DAI0_PIN12 to input */ <SPT2_BD1_O_BD DAI0_PB12_I>, /* route SPT2_BD1 to DAI0_PIN12 */ <DAI0_HIGH_F DAI0_PBEN19_I>, /* set DAI0_PIN19 to output */ <SPT2_ACLK_O_A DAI0_PB19_I>, /* route SPT2_ACLK to DAI0_PIN19 */ <SPT2_ACLK_O_A SPT2_BCLK_I>, /* route SPT2_ACLK to SPT2_BLCK */ <DAI0_HIGH_F DAI0_PBEN20_I>, /* set DAI0_PIN20 to output */ <SPT2_AFS_O_D DAI0_PB20_I>, /* route SPT2_AFS to DAI0_PIN20 */ <SPT2_AFS_O_D SPT2_BFS_I>; /* route SPT2_AFS to SPT2_BFS */ }; }; }; &sru_ctrl_dai1 { status = "okay"; sru_dai1: sru_dai1_mux { route { sru-routing = <DAI1_LOW_F DAI1_PBEN01_I>, /* set DAI1_PIN0B to input */ <DAI1_PB01_O_ABCDE SPT4_BD0_I>, /* route DAI1_PIN0B to SPT4_BD0 */ <DAI1_HIGH_F DAI1_PBEN02_I>, /* set DAI1_PIN02 to output */ <SPT4_AD0_O_BD DAI1_PB02_I>, /* route SPT4_AD0 to DAI1_PIN02 */ <DAI1_LOW_F DAI1_PBEN03_I>, /* set DAI1_PIN03 to input */ <DAI1_PB03_O_ABCDE SPT4_ACLK_I>, /* route DAI1_PIN03 to SPT4_ACLK */ <DAI1_PB03_O_ABCDE SPT4_BCLK_I>, /* route DAI1_PIN03 to SPT4_BCLK */ <DAI1_LOW_F DAI1_PBEN04_I>, /* set DAI1_PIN4 to input */ <DAI1_PB04_O_ABCDE SPT4_AFS_I>, /* route DAI1_PIN4 to SPT4_AFS */ <DAI1_PB04_O_ABCDE SPT4_BFS_I>, /* route DAI1_PIN4 to SPT4_BFS */ <DAI1_LOW_F DAI1_PBEN05_I>, /* set DAI1_PIN5B to input */ <DAI1_PB05_O_ABCDE SPT5_BD0_I>, /* route DAI1_PIN5B to SPT5_BD0 */ <DAI1_HIGH_F DAI1_PBEN06_I>, /* set DAI1_PIN06 to output */ <SPT5_AD0_O_BD DAI1_PB06_I>, /* route SPT5_AD0 to DAI1_PIN06 */ <DAI1_HIGH_F DAI1_PBEN07_I>, /* set DAI1_PIN07 to output */ <SPT5_ACLK_O_D DAI1_PB07_I>, /* route DAI1_PIN07 to SPT5_ACLK */ <SPT5_ACLK_O_A SPT5_BCLK_I>, /* route DAI1_PIN07 to SPT5_BCLK */ <DAI1_HIGH_F DAI1_PBEN08_I>, /* set DAI1_PIN8 to output */ <SPT5_AFS_O_D DAI1_PB08_I>, /* route DAI1_PIN8 to SPT5_AFS */ <SPT5_AFS_O_C SPT5_BFS_I>; /* route SPT5_AFS to SPT5_BFS */ }; }; }; &tru { rpmsg_to_a55: channel@0 { adi,tru-master-id = <139>; /* trigger master SOFT3 */ adi,tru-slave-id = <160>; /* TRU0_IRQ3 */ }; rpmsg_to_sharc0: channel@1 { adi,tru-master-id = <140>; /* trigger master SOFT4 */ adi,tru-slave-id = <164>; /* TRU0_IRQ7 */ }; rpmsg_to_sharc1: channel@2 { adi,tru-master-id = <141>; /* trigger master SOFT5 */ adi,tru-slave-id = <168>; /* TRU0_IRQ11 */ }; };
/* * Device tree header for ADI sc59x processor * * Copyright 2014 - 2018 Analog Devices Inc. * * Licensed under the GPL-2 or later. * */ #include <dt-bindings/input/adi_gp_counter.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/clock/adi-sc5xx-clock.h> / { model = "ADI sc59x"; compatible = "adi,sc59x"; interrupt-parent = <&gic>; #address-cells = <1>; #size-cells = <1>; chosen { }; aliases { serial0 = &uart0; serial2 = &uart2; timer0 = &gptimer0; timer1 = &gptimer1; timer2 = &gptimer2; timer3 = &gptimer3; timer4 = &gptimer4; timer5 = &gptimer5; timer6 = &gptimer6; timer7 = &gptimer7; ethernet0 = &emac0; ethernet1 = &emac1; spi0 = &spi0; spi1 = &spi1; spi2 = &spi2; spi3 = &spi3; can0 = &can0; can1 = &can1; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; i2c4 = &i2c4; i2c5 = &i2c5; rtc0 = &rtc0; i2s0 = &i2s0; i2s1 = &i2s1; i2s2 = &i2s2; i2s3 = &i2s3; i2s4 = &i2s4; mmc0 = &mmc0; sru0 = &sru_ctrl_dai0; sru1 = &sru_ctrl_dai1; }; cpus { #size-cells = <0>; #address-cells = <1>; cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a5"; reg = <0x0>; clocks = <&clk ADSP_SC594_CLK_ARM>; }; }; pmu { compatible = "arm,cortex-a5-pmu"; interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH>; }; gic: interrupt-controller@310B2000 { compatible = "arm,cortex-a5-gic", "arm,cortex-a9-gic"; #interrupt-cells = <3>; #address-cells = <0>; interrupt-controller; reg = <0x310B2000 0x1000>, <0x310B4000 0x100>; }; L2: cache-controller@10000000 { compatible = "arm,pl310-cache"; reg = <0x10000000 0x1000>; cache-level = <2>; }; sram0: sram-icc@20000000 { /* ICC SRAM 8KB */ compatible = "mmio-sram"; #address-cells = <1>; #size-cells = <1>; reg = <0x20000000 0x2000>; ranges = <0 0x20000000 0x2000>; /* 1KB - Shared between SHARC cores*/ reserved@0{ reg = <0x0 0x400>; label = "SHARC_common"; }; /* 1KB - Reserved resource_tables for SHARC cores*/ resource_table@1000{ reg = <0x1000 0x400>; label = "SHARC_resource_tables"; }; }; sram1: sram-reserved@20100000 { compatible = "mmio-sram"; reg = <0x20100000 0x100000>; #address-cells = <1>; #size-cells = <1>; ranges = <0 0x20100000 0x100000>; }; sys_clkin0: sys-clkin0@1 { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <25000000>; clock-output-names = "sys_clkin0"; }; sys_clkin1: sys-clkin1@2 { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <25000000>; clock-output-names = "sys_clkin1"; }; clk: clocks@0x3108d000 { compatible = "adi,sc594-clocks"; reg = <0x3108d000 0x1000>, <0x3108e000 0x1000>, <0x3108f000 0x1000>; #clock-cells = <1>; clocks = <&sys_clkin0>, <&sys_clkin1>; clock-names = "sys_clkin0", "sys_clkin1"; status = "okay"; }; gptimers: gptimers@0x31018000 { compatible = "adi,sc5xx-gptimers"; reg = <0x31018000 0x200>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; status = "okay"; #address-cells = <1>; #size-cells = <0>; gptimer0: gptimer@0 { reg = <0>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0x60>; adi,is-clocksource; adi,reset-timer; }; gptimer1: gptimer@1 { reg = <1>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0x80>; adi,is-clockevent; adi,reset-timer; }; gptimer2: gptimer@2 { reg = <2>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0xa0>; }; gptimer3: gptimer@3 { reg = <3>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0xc0>; }; gptimer4: gptimer@4 { reg = <4>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0xe0>; }; gptimer5: gptimer@5 { reg = <5>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0x100>; }; gptimer6: gptimer@6 { reg = <6>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0x120>; }; gptimer7: gptimer@7 { reg = <7>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; adi,offset = <0x140>; }; }; scb { compatible = "simple-bus"; #address-cells = <1>; #size-cells = <1>; ranges; pads_system_config: adi-control@31004600 { compatible = "adi,pads-system-config"; reg = <0x31004600 0x100>; status = "okay"; }; sram-controller@31080000 { compatible = "adi,sram-controller"; reg = <0x31080000 0x100>; adi,sram = <&sram0>, <&sram1>; interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; status = "okay"; }; sram_mmap: sram-mmap@0 { /* mmap from sram1 pool*/ compatible = "adi,sram-mmap"; adi,sram = <&sram1>; status = "disabled"; }; rcu: rcu@0x3108C000 { compatible = "adi,reset-controller"; reg = <0x3108C000 0x1000>; adi,sharc-min = <1>; adi,sharc-max = <2>; status = "okay"; }; sec: sec@0x31089000 { compatible = "adi,system-event-controller"; reg = <0x31089000 0x1000>; adi,rcu = <&rcu>; adi,sharc-cores = <2>; status = "okay"; }; tru: tru@0x3108A000 { compatible = "adi,trigger-routing-unit"; reg = <0x3108A000 0x1000>; adi,max-master-id = <177>; adi,max-slave-id = <188>; status = "okay"; }; rtc0: rtc@0x310C8000 { compatible = "adi,rtc2"; reg = <0x310C8000 0x100>; /*interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>;*/ calibration = /bits/ 8 <0>; status = "disabled"; }; uart0: uart@0x31003000 { compatible = "adi,uart4"; reg = <0x31003000 0x40>; dmas = <&dma_cluster2 20>, <&dma_cluster2 21>; dma-names = "tx", "rx"; interrupt-parent = <&gic>; interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; uart1: uart@0x31003400 { compatible = "adi,uart4"; reg = <0x31003400 0x40>; dmas = <&dma_cluster2 34>, <&dma_cluster2 35>; dma-names = "tx", "rx"; interrupt-parent = <&gic>; interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; uart2: uart@0x31003800 { compatible = "adi,uart4"; reg = <0x31003800 0x40>; dmas = <&dma_cluster2 37>, <&dma_cluster2 38>; dma-names = "tx", "rx"; interrupt-parent = <&gic>; interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; can0: can@0x31000200 { compatible = "adi,can"; reg = <0x31000200 0x5FF>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; }; can1: can@0x31000a00 { compatible = "adi,can"; reg = <0x31000a00 0x5FF>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; status = "disabled"; }; i2c0: twi@0x31001400 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,twi"; reg = <0x31001400 0xFF>; interrupts = <GIC_SPI 150 IRQ_TYPE_LEVEL_HIGH>; clock-khz = <100>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; i2c1: twi@0x31001500 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,twi"; reg = <0x31001500 0xFF>; interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>; clock-khz = <100>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; i2c2: twi@0x31001600 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,twi"; reg = <0x31001600 0xFF>; interrupts = <GIC_SPI 152 IRQ_TYPE_LEVEL_HIGH>; clock-khz = <100>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; i2c4: twi@0x31001100 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,twi"; reg = <0x31001100 0xFF>; interrupts = <GIC_SPI 154 IRQ_TYPE_LEVEL_HIGH>; clock-khz = <100>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; i2c5: twi@0x31001200 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,twi"; reg = <0x31001200 0xFF>; interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>; clock-khz = <100>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk0"; status = "disabled"; }; i2s0: i2s@0 { compatible = "sc5xx,i2s-dai"; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk"; status = "disabled"; reg = <0x31002000 0x80>, <0x31002080 0x80>; sport-channel = <0>; interrupt-names = "tx_status", "rx_status"; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sport_dma_cluster 0>, <&sport_dma_cluster 1>; dma-names = "tx", "rx"; iram = <&sram1>; }; i2s1: i2s@1 { compatible = "sc5xx,i2s-dai"; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk"; status = "disabled"; reg = <0x31002100 0x80>, <0x31002180 0x80>; sport-channel = <1>; interrupt-names = "tx_status", "rx_status"; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sport_dma_cluster 2>, <&sport_dma_cluster 3>; dma-names = "tx", "rx"; iram = <&sram1>; }; i2s2: i2s@2 { compatible = "sc5xx,i2s-dai"; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk"; status = "disabled"; reg = <0x31002200 0x80>, <0x31002280 0x80>; sport-channel = <2>; interrupt-names = "tx_status", "rx_status"; interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sport_dma_cluster 4>, <&sport_dma_cluster 5>; dma-names = "tx", "rx"; iram = <&sram1>; }; i2s3: i2s@3 { compatible = "sc5xx,i2s-dai"; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk"; status = "disabled"; reg = <0x31002300 0x80>, <0x31002380 0x80>; sport-channel = <3>; interrupt-names = "tx_status", "rx_status"; interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sport_dma_cluster 6>, <&sport_dma_cluster 7>; dma-names = "tx", "rx"; iram = <&sram1>; }; i2s4: i2s@4 { compatible = "sc5xx,i2s-dai"; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk"; status = "disabled"; reg = <0x31002400 0x80>, <0x31002480 0x80>; sport-channel = <4>; interrupt-names = "tx_status", "rx_status"; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sport_dma_cluster 10>, <&sport_dma_cluster 11>; dma-names = "tx", "rx"; iram = <&sram1>; }; i2s5: i2s@5 { compatible = "sc5xx,i2s-dai"; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "sclk"; status = "disabled"; reg = <0x31002500 0x80>, <0x31002580 0x80>; sport-channel = <5>; interrupt-names = "tx_status", "rx_status"; interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; dmas = <&sport_dma_cluster 12>, <&sport_dma_cluster 13>; dma-names = "tx", "rx"; iram = <&sram1>; }; watchdog@0x31008000 { compatible = "arm,adi-watchdog"; reg = <0x31008000 0x10>; timeout-sec = <30>; clocks = <&clk ADSP_SC594_CLK_CGU0_SCLK0>; clock-names = "adi-watchdog"; }; spi0: spi@0x3102e000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,spi3"; reg = <0x3102e000 0xFF>; interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; dma-channel = <22>, <23>; clocks = <&clk ADSP_SC594_CLK_SPI>; clock-names = "spi"; status = "disabled"; }; spi1: spi@0x3102f000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,spi3"; reg = <0x3102f000 0xFF>; interrupts = <GIC_SPI 128 IRQ_TYPE_LEVEL_HIGH>; dma-channel = <24>, <25>; dmas = <&spi_cluster 24>, <&spi_cluster 25>; clocks = <&clk ADSP_SC594_CLK_SPI>; clock-names = "spi"; status = "disabled"; }; spi2: spi@0x31030000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,spi3"; reg = <0x31030000 0xFF>; interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; dmas = <&spi_cluster 26>, <&spi_cluster 27>; dma-names = "tx", "rx"; clocks = <&clk ADSP_SC594_CLK_SPI>; clock-names = "spi"; status = "disabled"; }; spi3: spi@0x31031000 { #address-cells = <1>; #size-cells = <0>; compatible = "adi,spi3"; reg = <0x31031000 0xFF>; interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>; dmas = <&spi_cluster 55>, <&spi_cluster 56>; dma-names = "tx", "rx"; clocks = <&clk ADSP_SC594_CLK_SPI>; clock-names = "spi"; status = "disabled"; }; ospi: spi@31027000 { compatible = "cdns,qspi-nor"; #address-cells = <1>; #size-cells = <0>; reg = <0x31027000 0x1000>, <0x60000000 0x10000000>; interrupts = <GIC_SPI 321 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clk ADSP_SC594_CLK_OSPI>; clock-names = "ospi"; cdns,is-decoded-cs; cdns,fifo-depth = <128>; cdns,fifo-width = <4>; cdns,trigger-address = <0x00000000>; status = "disabled"; }; emac0: ethernet@0x31040000 { compatible = "adi,dwmac", "snps,dwmac-3.710", "snps,dwmac"; reg = <0x31040000 0x2000>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "macirq"; snps,mixed-burst; snps,pbl = <8>; snps,force_sf_dma_mode; snps,perfect-filter-entries = <32>; clocks = <&clk ADSP_SC594_CLK_GIGE>; clock-names = "stmmaceth"; adi,system-config = <&pads_system_config>; status = "disabled"; }; emac1: ethernet@0x31042000 { compatible = "adi,dwmac", "snps,dwmac-3.710", "snps,dwmac"; reg = <0x31042000 0x2000>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "macirq"; snps,fixed-burst; snps,burst_len = <0x4>; /* BLEN8 */ snps,pbl = <1>; snps,force_thresh_dma_mode; clocks = <&clk ADSP_SC594_CLK_GIGE>; clock-names = "stmmaceth"; status = "disabled"; }; icc0: icc@0 { compatible = "adi,icc"; reg = <0x20000000 0x1000>; interrupt-parent = <&gic>; interrupts = <GIC_SPI 165 IRQ_TYPE_EDGE_RISING>; peerinfo = <1 140>, <2 141>; status = "disabled"; }; core_ctrl0: core_ctrl@0 { compatible = "adi,core_ctrl"; #address-cells = <1>; #size-cells = <1>; reg = <0x3108C000 0x80>; /* RCU0 control reg base */ adi,icc_mem = <&icc0>; }; crc0: crc@0x31001200 { compatible = "adi,hmac-crc"; reg = <0x31001200 0xFF>; interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; dma_channel = <8>; crypto_crc_poly = <0x5c5c5c5c>; status = "disabled"; }; crc1: crc@0x31001300 { compatible = "adi,hmac-crc"; reg = <0x31001300 0xFF>; interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; dma_channel = <18>; crypto_crc_poly = <0x5c5c5c5c>; status = "disabled"; }; pinctrl0: pinctrl@0x31004600 { compatible = "adi,adsp-pinctrl"; #address-cells = <1>; #size-cells = <1>; reg = <0x31004600 0x400>; adi,port-sizes = <16 16 16 16 16 16 16 16 7>; }; sru_ctrl_dai0: sru-ctrl-dai0@0x310C9000 { compatible = "adi,adsp-sru-ctrl"; #address-cells = <1>; #size-cells = <1>; reg = <0x310C9000 0x224>; adi,system-config = <&pads_system_config>; status = "disabled"; }; sru_ctrl_dai1: sru-ctrl-dai1@0x310CA000 { compatible = "adi,adsp-sru-ctrl"; #address-cells = <1>; #size-cells = <1>; reg = <0x310CA000 0x224>; adi,system-config = <&pads_system_config>; status = "disabled"; }; mmc0: mmc@0x31010000 { compatible = "adi,mmc"; reg = <0x31010000 0xFFF>; interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <58>; #address-cells = <1>; #size-cells = <0>; fifo-depth = <1024>; status = "disabled"; }; /* video_decoder: cap@0x31040000 { compatible = "adi,cap"; card-name = "SC58X"; type = <2>; dma-channel = <28>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; reg = <0x31040000 0xfff>; spu_securep_id = <95>; i2c_bus_id = <0>; status = "disabled"; }; */ gp_counter: cnt@0x3100B000 { compatible = "adi,gp_counter"; reg = <0x3100B000 0xFF>; interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>; #size-cells = <0>; status = "disabled"; }; /* video_encoder: disp@0x31040000 { compatible = "adi,disp"; card-name = "SC58X"; type = <2>; dma-channel = <28>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; reg = <0x31040000 0xfff>; spu_securep_id = <95>; i2c_bus_id = <0>; status = "disabled"; }; */ lp0: linkport@0 { compatible = "linkport0"; interrupt-parent = <&gic>; interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; clock-div = <1>; status = "disabled"; }; lp1: linkport@1 { compatible = "linkport1"; interrupt-parent = <&gic>; interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; clock-div = <1>; status = "disabled"; }; pint0: pint@0x31005000 { compatible = "adi,adsp-pint"; reg = <0x31005000 0xFF>; interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; }; pint1: pint@0x31005100 { compatible = "adi,adsp-pint"; reg = <0x31005100 0xFF>; interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; }; pint2: pint@0x31005200 { compatible = "adi,adsp-pint"; reg = <0x31005200 0xFF>; interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; }; pint3: pint@0x31005300 { compatible = "adi,adsp-pint"; reg = <0x31005300 0xFF>; interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; }; pint4: pint@0x31005400 { compatible = "adi,adsp-pint"; reg = <0x31005400 0xFF>; interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; }; pint5: pint@0x31005500 { compatible = "adi,adsp-pint"; reg = <0x31005500 0xFF>; interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; }; pint6: pint@0x31005600 { compatible = "adi,adsp-pint"; reg = <0x31005600 0xFF>; interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; }; pint7: pint@0x31005700 { compatible = "adi,adsp-pint"; reg = <0x31005700 0xFF>; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; }; gpa: gport@0x31004000 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004000 0x7F>; gpio-ranges = <&pinctrl0 0 0 16>; adi,pint = <&pint0 1>; adi,gpio-base = <0>; }; gpb: gport@0x31004080 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004080 0x7F>; gpio-ranges = <&pinctrl0 0 16 16>; adi,pint = <&pint0 0>; adi,gpio-base = <16>; }; gpc: gport@0x31004100 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004100 0x7F>; gpio-ranges = <&pinctrl0 0 32 16>; adi,pint = <&pint2 1>; adi,gpio-base = <32>; }; gpd: gport@0x31004180 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004180 0x7F>; gpio-ranges = <&pinctrl0 0 48 16>; adi,pint = <&pint2 0>; adi,gpio-base = <48>; }; gpe: gport@0x31004200 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004200 0x7F>; gpio-ranges = <&pinctrl0 0 64 16>; adi,pint = <&pint4 1>; adi,gpio-base = <64>; }; gpf: gport@0x31004280 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004280 0x7F>; gpio-ranges = <&pinctrl0 0 80 16>; adi,pint = <&pint4 0>; adi,gpio-base = <80>; }; gpg: gport@0x31004300 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004300 0x7F>; gpio-ranges = <&pinctrl0 0 96 16>; adi,pint = <&pint6 1>; adi,gpio-base = <96>; }; gph: gport@0x31004380 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004380 0x7F>; gpio-ranges = <&pinctrl0 0 112 16>; adi,pint = <&pint6 0>; adi,gpio-base = <112>; }; gpi: gport@0x31004400 { compatible = "adi,adsp-port-gpio"; gpio-controller; #gpio-cells = <2>; reg = <0x31004400 0x7F>; gpio-ranges = <&pinctrl0 0 128 7>; adi,pint = <&pint7 1>; adi,gpio-base = <128>; }; usb0_phy: usbphy { compatible = "usb-nop-xceiv"; #phy-cells = <0>; status = "disabled"; }; usb0: usb@310c5000 { compatible = "adi,adsp2159x-usbc", "snps,dwc2"; reg = <0x310c5000 0x4000>; interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; phys = <&usb0_phy>; phy-names = "usb2-phy"; status = "disabled"; }; /* dma0: dma@0 { compatible = "adi,dma2"; reg = <0x31022000 0x7F>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <66>; }; dma1: dma@1 { compatible = "adi,dma2"; reg = <0x31022080 0x7F>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <67>; }; dma2: dma@2 { compatible = "adi,dma2"; reg = <0x31022100 0x7F>; interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <68>; }; dma3: dma@3 { compatible = "adi,dma2"; reg = <0x31022180 0x7F>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <69>; }; dma4: dma@4 { compatible = "adi,dma2"; reg = <0x31022200 0x7F>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <70>; }; dma5: dma@5 { compatible = "adi,dma2"; reg = <0x31022280 0x7F>; interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <71>; }; dma6: dma@6 { compatible = "adi,dma2"; reg = <0x31022300 0x7F>; interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <72>; }; dma7: dma@7 { compatible = "adi,dma2"; reg = <0x31022380 0x7F>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <73>; }; dma8: dma@8 { compatible = "adi,dma2"; reg = <0x310A7000 0x7F>; interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <74>; }; dma9: dma@9 { compatible = "adi,dma2"; reg = <0x310A7080 0x7F>; interrupts = <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <75>; }; dma10: dma@10 { compatible = "adi,dma2"; reg = <0x31023000 0x7F>; interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <76>; }; dma11: dma@11 { compatible = "adi,dma2"; reg = <0x31023080 0x7F>; interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <77>; }; dma12: dma@012 { compatible = "adi,dma2"; reg = <0x31023100 0x7F>; interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <78>; }; dma13: dma@13 { compatible = "adi,dma2"; reg = <0x31023180 0x7F>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <79>; }; dma14: dma@14 { compatible = "adi,dma2"; reg = <0x31023200 0x7F>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <80>; }; dma15: dma@15 { compatible = "adi,dma2"; reg = <0x31023280 0x7F>; interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <81>; }; dma16: dma@16 { compatible = "adi,dma2"; reg = <0x31023300 0x7F>; interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <82>; }; dma17: dma@17 { compatible = "adi,dma2"; reg = <0x31023380 0x7F>; interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <83>; }; dma18: dma@18 { compatible = "adi,dma2"; reg = <0x310A7100 0x7F>; interrupts = <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <84>; }; dma19: dma@19 { compatible = "adi,dma2"; reg = <0x310A7180 0x7F>; interrupts = <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <85>; }; dma20: dma@20 { compatible = "adi,dma2"; reg = <0x31026080 0x7F>; interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <86>; }; dma21: dma@21 { compatible = "adi,dma2"; reg = <0x31026000 0x7F>; interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <87>; }; dma22: dma@22 { compatible = "adi,dma2"; reg = <0x3102D000 0x7F>; interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <88>; }; dma23: dma@23 { compatible = "adi,dma2"; reg = <0x3102D080 0x7F>; interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <89>; }; dma24: dma@24 { compatible = "adi,dma2"; reg = <0x3102D100 0x7F>; interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <90>; }; dma25: dma@25 { compatible = "adi,dma2"; reg = <0x3102D180 0x7F>; interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <91>; }; dma26: dma@26 { compatible = "adi,dma2"; reg = <0x3102D200 0x7F>; interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <92>; }; dma27: dma@27 { compatible = "adi,dma2"; reg = <0x3102D280 0x7F>; interrupts = <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <93>; }; dma28: dma@28 { compatible = "adi,dma2"; reg = <0x31026400 0x7F>; interrupts = <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <94>; }; dma29: dma@29 { compatible = "adi,dma2"; reg = <0x31026480 0x7F>; interrupts = <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <95>; }; dma30: dma@30 { compatible = "adi,dma2"; reg = <0x30FFF000 0x7F>; interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <96>; }; dma34: dma@34 { compatible = "adi,dma2"; reg = <0x31026180 0x7F>; interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <97>; }; dma35: dma@35 { compatible = "adi,dma2"; reg = <0x31026100 0x7F>; interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <98>; }; dma36: dma@36 { compatible = "adi,dma2"; reg = <0x30FFF080 0x7F>; interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <99>; }; dma37: dma@37 { compatible = "adi,dma2"; reg = <0x31026280 0x7F>; interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <100>; }; dma38: dma@38 { compatible = "adi,dma2"; reg = <0x31026200 0x7F>; interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <101>; }; dma39: dma@39 { compatible = "adi,dma2"; reg = <0x3109A000 0x7F>; interrupts = <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <102>; }; dma40: dma@40 { compatible = "adi,dma2"; reg = <0x3109A080 0x7F>; interrupts = <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <103>; }; dma43: dma@43 { compatible = "adi,dma2"; reg = <0x3109B000 0x7F>; interrupts = <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <104>; }; dma44: dma@44 { compatible = "adi,dma2"; reg = <0x3109B080 0x7F>; interrupts = <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <105>; }; dma45: dma@45 { compatible = "adi,dma2"; reg = <0x310A7200 0x7F>; interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma46: dma@46 { compatible = "adi,dma2"; reg = <0x310A7280 0x7F>; interrupts = <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma47: dma@47 { compatible = "adi,dma2"; reg = <0x310A7300 0x7F>; interrupts = <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma48: dma@48 { compatible = "adi,dma2"; reg = <0x310A7380 0x7F>; interrupts = <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma49: dma@49 { compatible = "adi,dma2"; reg = <0x310AC000 0x7F>; interrupts = <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma50: dma@50 { compatible = "adi,dma2"; reg = <0x310AC080 0x7F>; interrupts = <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma51: dma@51 { compatible = "adi,dma2"; reg = <0x3109C000 0x7F>; interrupts = <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma52: dma@52 { compatible = "adi,dma2"; reg = <0x3109C080 0x7F>; interrupts = <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma53: dma@53 { compatible = "adi,dma2"; reg = <0x31026380 0x7F>; interrupts = <GIC_SPI 147 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; dma54: dma@54 { compatible = "adi,dma2"; reg = <0x31026300 0x7F>; interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; spu_securep_id = <106>; }; */ spi_cluster: dma@0x3102D000 { compatible = "adi,dma-controller"; reg = <0x3102D000 0x1000>; status = "okay"; #dma-cells = <1>; spi0_tx: channel@22 { adi,id = <22>; interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 261 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0>; }; spi0_rx: channel@23 { adi,id = <23>; interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 262 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x80>; }; spi1_tx: channel@24 { adi,id = <24>; interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 263 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x100>; }; spi1_rx: channel@25 { adi,id = <25>; interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 264 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x180>; }; spi2_tx: channel@26 { adi,id = <26>; interrupts = <GIC_SPI 129 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 265 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x200>; }; spi2_rx: channel@27 { adi,id = <27>; interrupts = <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 266 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x280>; }; }; sport_dma_cluster: dma@0x31023000 { compatible = "adi,dma-controller"; reg = <0x31023000 0x1000>; status = "okay"; #dma-cells = <1>; sport0a: channel@0 { adi,id = <0>; adi,src-offset = <0>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 297 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport0b: channel@1 { adi,id = <1>; adi,src-offset = <0x80>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 298 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport1a: channel@2 { adi,id = <2>; adi,src-offset = <0>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 299 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport1b: channel@3 { adi,id = <3>; adi,src-offset = <0x80>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 300 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport2a: channel@4 { adi,id = <4>; adi,src-offset = <0>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 301 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport2b: channel@5 { adi,id = <5>; adi,src-offset = <0x80>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 302 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport3a: channel@6 { adi,id = <6>; adi,src-offset = <0>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 303 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport3b: channel@7 { adi,id = <7>; adi,src-offset = <0x80>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 304 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport4a: channel@10 { adi,id = <10>; adi,src-offset = <0>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 305 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport4b: channel@11 { adi,id = <11>; adi,src-offset = <0x80>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 306 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport5a: channel@12 { adi,id = <12>; adi,src-offset = <0>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 307 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; sport5b: channel@13 { adi,id = <13>; adi,src-offset = <0x80>; adi,skip-interrupts = <0>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 308 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; }; }; dma_cluster2: dma@0x31026000 { compatible = "adi,dma-controller"; reg = <0x31026000 0x1000>; status = "okay"; #dma-cells = <1>; uart0_tx: channel@20 { adi,id = <20>; interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 269 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x80>; }; uart0_rx: channel@21 { adi,id = <21>; interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 270 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0>; }; uart1_tx: channel@34 { adi,id = <34>; interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 271 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x180>; }; uart1_rx: channel@35 { adi,id = <35>; interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 272 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x100>; }; uart2_tx: channel@37 { adi,id = <37>; interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 273 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x280>; }; uart2_rx: channel@38 { adi,id = <38>; interrupts = <GIC_SPI 145 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 274 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error"; adi,src-offset = <0x200>; }; }; mdma: dma@0x3109a000 { compatible = "adi,mdma-controller"; reg = <0x3109a000 0x1000>; status = "okay"; sdma2: channel@40 { adi,id = <40>; // The destination interrupts are used for primary complete detection interrupts = <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 286 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 285 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "complete", "error", "complete2", "error2"; adi,src-offset = <0>; adi,dest-offset = <0x80>; }; }; }; };
