Wrong Image Format for bootm command
Software Version: CCES-2.10.0,Ubuntu-20.04
I followed the steps for uboot in the ADSP-SC573 using the following start guide
https://wiki.analog.com/resources/tools-software/linuxdsp/docs/quickstartguide/quickstart_sc573
When utilizing the image file (fitImage) that is utilized in the start guide, it functions effectively.
consequently, I used zImage, which is found in the source folder itself, in place of that image.
This error was triggered,
Wrong Image format for bootm command
Error: can't get kernel image
I am very curious how to proceed on that....
  • Hi Sushindren,
    bootm command is for Uimage
    As you were using zimage, you need to use bootz command.
    replace the bootm command from your bootargs to bootz and give it a try.
    Prasanth R
  • Hi Prasanth,
    I can't get you properly, Are you told to boot with sdcard boot option.
    When i am using printenv in the uboot, it shown some arguments,
    addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmaf
    autoload=no
    baudrate=115200
    bootcmd=run ramboot
    bootdelay=2
    dtbaddr=0x84000000
    dtbfile=sc573-ezkit.dtb
    ethact=dwmac.3100c000
    ethaddr=02:80:ad:20:31:e8
    fdtcontroladdr=8ffcca20
    gatewayip=192.168.0.1
    hostname=sc57x
    imagefile=zImage
    initramaddr=0x85000000
    initramfile=ramdisk.cpio.xz.u-boot
    ipaddr=192.168.0.15
    loadaddr=0x82000000
    loads_echo=1
    nc=setenv ncip ${serverip};setenv stdin nc;setenv stdout nc;setenv stderr nc
    netmask=255.255.255.0
    nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath},tcp,nf
    nfsboot=tftp ${loadaddr} ${nfsfile};run nfsargs;run addip;bootm ${loadaddr};
    nfsfile=zImage
    norboot=tftp ${loadaddr} ${ramfile};run ramargs;run addip;bootm ${loadaddr};
    ramargs=setenv bootargs root=/dev/mtdblock2 rw rootfstype=jffs2 earlyprintk=ser
    ramboot=tftp ${loadaddr} ${ramfile};tftp ${initramaddr} ${initramfile};run rama;
    ramboot_emmc=mmc rescan;mmc dev 0 0;ext2load mmc 0:1 ${loadaddr} /boot/${ramfil;
    ramfile=zImage
    rootpath=/romfs
    sdcardargs=setenv bootargs root=/dev/mmcblk0p1 rw earlyprintk=serial,uart0,1152
    sdcardboot=mmc rescan;mmc dev 0 0;ext2load mmc 0:1 ${loadaddr} /boot/${ramfile};
    serverip=192.168.0.2
    stderr=serial@0x31003000
    stdin=serial@0x31003000
    stdout=serial@0x31003000
    ubootfile=u-boot-sc573-ezkit.ldr
    update=tftp ${loadaddr} ${ubootfile};sf probe 2:1;sf erase 0 0x80000;sf write $}
    Here as you can see i loaded the zImage in the imagefile when run sdcardboot i shown same error, i dont know where i am missing,
    If i can't get your point kindly tell elaborately,
    Thankyou,
    Sushindren
  • Hi Sushindren,
    Could you share the exact complete error along with the command you were passing to the u-boot?
    Do you zImage copied under /boot/Zimage directory of the SD card?
    could you print the output of # ext2ls mmc 0:1 /boot
    Prasanth R
  • Hi Prasanth,
    Apologize for the late reply,
    As you mentioned i executed the command,
    => ext2ls mmc 0:1 /boot
    <DIR>       4096 .
    <DIR>       4096 ..
             4255384 zImage-4.19.0-yocto-standard
    <SYM>         28 zImage
               18488 sc573-ezkit.dtb
    when i run sdcard boot its showing wrong image format, i followed the same procedure which was in the link
    here i used zImage for this.
    => run sdcardboot
    switch to partitions #0, OK
    mmc0 is current device
    4255384 bytes read in 719 ms (5.6 MiB/s)
    ERROR: can't get kernel image!
    Waiting for the replay
    Sushindren
  • Hi Sushindrean,
    It seems your u-boot environment variable was modified,
    #setenv sdcardboot 'mmc rescan; mmc dev 0 0; ext2load mmc 0:1 ${loadaddr} /boot/${ramfile}; ext2load mmc 0:1 ${dtbaddr} /boot/${dtbfile}; run sdcardargs; bootz ${loadaddr} - ${dtbaddr}'
    #run sdcardboot
    Prasanth R
  • Hi Prasanth,
    Thank you for your support, now its booting partially
    In the end it can't able to load the .ldr as well as .db files.
    platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    remoteproc remoteproc0: core1-rproc is available
    cfg80211: failed to load regulatory.db
    remoteproc remoteproc1: core2-rproc is available
    remoteproc remoteproc0: Direct firmware load for adi_adsp_core1_fw.ldr failed with error -2
    ALSA device list:
      No soundcards found.
    remoteproc remoteproc0: powering up core1-rproc
    remoteproc remoteproc0: request_firmware failed: -2
    remoteproc remoteproc1: Direct firmware load for adi_adsp_core2_fw.ldr failed with error -2
    I think most of the files has loaded this one only a trouble maker for me.
    Waiting for your reply from your end.
    Thank you,
    Sushindren
  • Hi Sushindren,
    Could you reach the userspace login prompt?
    I hope that remoteproc won't be an issue.
    Prasanth R
  • Hi Prasanth,
    No i didn't get the login prompt.
    It showing like this only and also i can't able to give any commands it's giving the same symbol.
    Thank you,
    Sushindren
  • Hi Sushindren,
    This seems strange on seeing this basic boot issue,
    step 1:
    I recommend following this
    #env default -a -f
    #run sdcardboot
    If the above doesn't help
    step2:
    I recommend you to follow the below link and build the minimal image, replace the complete u-boot and boot the device with the newly created image
    Prasanth R
  • Hi Prasanth,
    Thankyou for your great support , i followed your recommendation of the steps which first step didn't worked for me.
    In the second recommendation i used the minimal and fitimage which is mentioned in the quick start guide that one worked for me
    but when i incorporate zImage and minimal image it causes and stuck in between while booting itself, i didn't get the login promt also
    I surfed regards with this issue also and i found one link and followed the same steps still i am getting the same.
    https://wiki.analog.com/resources/tools-software/linuxdsp/docs/quickstartguide/installing/installing_nfsboot
    Thank you,
    Sushindren
