we have a ADSP589-EZ-kit and i connect a pcie-to-usb converter with pci interface on ez-kit. Then I connected a u-disk to the usb interface of converter ,I can only read data from the USB flash disk, but I can't write data to it.The adapter chip is pd720202 of Renesas。
Error message about PCI in kernel boot
log:
PCI: bus0: Fast back to back transfers disabledpci 0000:00:00.0: can't enable device: BAR 0 [mem 0x00000000-0x00001fff 64bit] not claimedpci 0000:00:00.0: Can't enable PCI device, BIOS handoff failed.pci 0000:00:00.0: BAR 0: assigned [mem 0x5e000000-0x5e001fff 64bit]
Hi lululululu,
I think if you want to use the converter, there should be a driver to support this, unfortunately we do not support the pcie-to-usb converter yet. And also we do not support pcie driver…
I think if you want to use the converter, there should be a driver to support this, unfortunately we do not support the pcie-to-usb converter yet. And also we do not support pcie driver in recent release. Sorry for the convenience. If you want to read and write data from the USB disk, can you choose the USB interface?
unfortunately we are no longer supporting the PCIe device on the SC589 in the Linux software that we provide.
