Dear support,
Is it possible to install the Linux addin on a SC589 on the ARM core for the "system management" and then design the actual DSP functionality using SigmaStudio and install this on the other core(s)?
BN
Dear support,
BN
No, this sounds like a good approach especially if you want to manipulate the parameters on the SHARC at runtime.
More so if you need features like USB and ethernet as it's all there out of the box with…
Hi Leopoldo, thanks for the detailed reply. This really helps me understand your use case.
Unfortunately I am not a Sigma Studio expert (yet) so I will need to consult with some of my colleagues on the…
Yes, that should be possible. From a system point of view the SHARCs and ARM cores are isolated from each other.
When you design your system you partition the memory between the cores so that they can work independently.
Peripherals should be considered so that either the ARM core or the SHARC cores are responsible for managing them.
In terms of what runs on each core, it really is your choice.
The ARM core can run Linux, FreeRTOS, uC/OS or bare metal.
The SHARC cores can run FreeRTOS, uC/OS or bare metal.
Sigma studio produces bare metal applications so they can run fine.
If you need to communicate between the cores we have implemented MCAPI under all RTOS/Linux/Bare metal for message passing. DMA can be used for for larger/faster data transfer.
The only caveat is that Sigma studio needs to be run on a Windows host, where as the Linux development is performed on a host PC running Linux.
Dave
Thank you for the answer, looking good.
My plan would be to design "bare metal" DSP functions, that would be configurable during runtime, such as modifying crossover frequencies, channel delay settings, etc. If this could be done by talking to the linux side it would be great.
I am completely new to all this. Are there any other, more common ways to change such settings on a DSP bare metal application? I am familiar with Linux, that is it was the first choice for me. But maybe this is not the best way?
BN
More so if you need features like USB and ethernet as it's all there out of the box with Linux.
We have been putting together a demo similar to this internally. It uses Open Stage Control (https://openstagecontrol.ammd.net/) to provide a GUI for manipulating audio parameters. I will see what state the code is in and see if we can share some of this with you - note it may take a while as I will need to get the code cleared by legal.
Also note that at this point Open Stage control runs on a host PC not under the EZ-KIT Linux. But that's something we would like to have up and running eventually.
This demo would be fantastic to take a look at, thanks a lot.
I will be waiting eagerly.
BN
A supplementary question:
Now I have the hardware, and I have successfully installed the pre-built linux onto the SD-card.
All is fine except that there is no networking installed on the ARM core, so I have to communicate using the "minicom" terminal from the Ubuntu host. The prebuilt linux image seems very minimalistic. No network, not very practical. Any suggested reading for me how to get the network functional?
I have realized I need to reconfigure and build the linux from source.
However, the build is never completed due to errors.
Also, the manual "linux_add_in_user_guide_1.3.1.pdf" is not completely accurate.
E.g. there is no entry "File system images" in "make menuconfig".
I also realize that this forum may not be the proper one to resolve all this. Any suggestions?
Hello daveG , I'm currently working in a project with SC573 EZ-kit that requires integration between Linux Add-In running on ARM core, and Sigma Studio projects running in SHARC cores, as described by bnilsson .
Thank you very much!
unfortunately that demo was never completed (changing priorities etc, sorry).
At this point the best approach is to manually control interactions between the ARM running Linux and the SHARC cores.
We are currently in the process of putting out a new beta release of Linux. This will (eventually) contain a new audio framework to assist with passing the data between the cores. On the Linux side the SHARC cores will be seen as virtual Linux devices, and there will be a new dedicated low level audio framework to pass streamed audio to and from the SHARC cores.
We are hoping to have this functionality in place in a beta in the next month or so. Although SC573 may follow shortly after that.
We will post an announcement on the engineer zone forum when the functionality is available in a beta.
Hi daveG , thanks a lot for your response! I'll be looking forward to the announcement in the forum.
I have one more question on the same field. Before manually controlling the interactions between ARM Linux and SHARC, we would like to boot SHARC cores with the Sigma Studio code and params already included in the LDR file. Adding some more detail to the question:
What we want basically is that the DXE/LDR Windows CCES generated files for SHARC cores, already includes the parameters and code exported from SigmaStudio, so when booting SHARCS from Linux the schematic starts running rightaway, and we can then proceed to write our communication with the Linux for parameters tuning.
Does it make sense? Or the only way to do this is to load all code and parameters from the ARM core once we have written our communication scheme?
Thanks again for your time and quick response!
Leopoldo
Unfortunately I am not a Sigma Studio expert (yet) so I will need to consult with some of my colleagues on the SigmaStudio specific points.
A few general points that might help you in your progress:
Dave
