When I run the following command:
# /opt/analog/cces/2.8.3/ARM/openocd/bin/openocd -f interface/ice1000.cfg -f target/adspsc58x.cfg
The console output below:
Open On-Chip Debugger (Analog Devices CCES 2.8.0 OpenOCD 0.9.0-g5030ad7) 0.9.0Licensed under GNU GPL v2Report bugs to <processor.tools.support@analog.com>adapter speed: 1000 kHzInfo : transports supported by the debug adapter: "jtag", "swd"Info : auto-select transport "jtag"halt and restart using CTItrst_only separate trst_push_pullError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesInfo : ICE-1000 firmware version is 255.15.12Error: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesInfo : clock speed 1000 kHzError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesInfo : JTAG tap: adspsc58x.adjc tap/device found: 0xf21c3201 (mfg: 0x100, part: 0x21c3, ver: 0xf)Warn : JTAG tap: adspsc58x.adjc UNEXPECTED: 0xf21c3201 (mfg: 0x100, part: 0x21c3, ver: 0xf)Error: JTAG tap: adspsc58x.adjc expected 1 of 3: 0x028080cb (mfg: 0x065, part: 0x2808, ver: 0x0)Error: JTAG tap: adspsc58x.adjc expected 2 of 3: 0x128080cb (mfg: 0x065, part: 0x2808, ver: 0x1)Error: JTAG tap: adspsc58x.adjc expected 3 of 3: 0x228080cb (mfg: 0x065, part: 0x2808, ver: 0x2)Warn : Unexpected idcode after end of chain: 544 0x1fffffffWarn : Unexpected idcode after end of chain: 576 0x00000ff3Warn : Unexpected idcode after end of chain: 608 0x1de5c202Warn : Unexpected idcode after end of chain: 640 0x7de5c202Error: double-check your JTAG setup (interface, speed, ...)Error: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesError: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytesInfo : TAP adspsc58x.adjc does not have IDCODEInfo : TAP auto0.tap does not have IDCODEInfo : TAP auto1.tap does not have IDCODEInfo : TAP auto2.tap does not have IDCODEInfo : TAP auto3.tap does not have IDCODEInfo : TAP auto4.tap does not have IDCODEInfo : TAP auto5.tap does not have IDCODEInfo : TAP auto6.tap does not have IDCODEInfo : TAP auto7.tap does not have IDCODEInfo : JTAG tap: auto8.tap tap/device found: 0xfff90e15 (mfg: 0x70a, part: 0xff90, ver: 0xf)Warn : Unexpected idcode after end of chain: 553 0x09dfffffWarn : Unexpected idcode after end of chain: 585 0x01e0000cWarn : Unexpected idcode after end of chain: 617 0x01eef2e6Error: double-check your JTAG setup (interface, speed, ...)embedded:startup.tcl:21: Error:in procedure 'init'in procedure 'ocd_bouncer'in procedure 'jtag_init' called at file "../../../../openocd/src/jtag/core.c", line 1562in procedure 'init_reset' called at file "embedded:startup.tcl", line 74in procedure 'jtag' called at file "embedded:startup.tcl", line 91in procedure 'ocd_bouncer'at file "embedded:startup.tcl", line 21embedded:startup.tcl:21: Error:in procedure 'jtag_init' called at file "../../../../openocd/src/jtag/core.c", line 1562in procedure 'init_reset' called at file "embedded:startup.tcl", line 74in procedure 'jtag' called at file "embedded:startup.tcl", line 91in procedure 'ocd_bouncer'at file "embedded:startup.tcl", line 21Error: unable to write from &usb_cmd_blk to usb: wanted 12 bytes but only wrote 0 bytes
I have succesfully runned OpenOCD one time before.But when I flashed U-Boot to SPI Flash,I failed.So I have to restart from the step "Run OpenOCD",Then I meet the error above.
Thanks in advance for support,
Haoran
Hi Haoran
Could you please check the hardware and environment you are using:
1) Could you please provide the silicon revision of the SC589 you are using 1.0 or 1.2?
2) Could you please provide the verson of your Ubuntu 32-bit or 64-bit?
3) Please make sure you are not using virtual machine, we suggest that you'd better run all of your operations in a local ubuntu host not in a virtual machine as in vm there will be hardware connection problems.
Thanks
Ann
