Resetting a SHARC+ Core Through Another Core issue
    From the processor hw reference manual page 222-223 I can see 18 steps to reset the SHARC core, but when I look at the core control driver in the linux distribution it seems to use only items from 11..18. There's no handshake to send the IDLE state using the RCU_MSG.
    I'm facing few issues regarding the loadsharc_sc589 doing multiple load onto the same SHARC core. The first time it loads the LDR all goes well, but the second+ time it gets stuck wating from sharc core response. I guess once the SHARC core is running some code we are not able to reset it unil we send it to IDLE mode. Is that correct?
    From the manual: 3. The master core sets the CCRx bit in message register and raises the SOFT0 software interrupt through the
SEC to the SHARC+ core (see Programming Examples for more information). I could not find the CCR bit in the RCU_MSG, am I looking at the wrong place? There's also something kind of a type in this section once it refers to a Core Reset Request bit (CRR) also not found in RCU_MSG register.
Thanks in advance!
  • Hi, the engineer who developed this code is on vacation this week. We'll try and get a response to you as soon as we can.
    Dave
  • Hi Dave,
        As soon as you have any response, please let me know! Thanks for the attention!
    Raphael
  • Hi Dave,
    Raphael and I are working on the same project so we are both looking forward to hearing from the engineer.
    We have also tried the following:
    • Added a while(1){} right after recv_arg(&argc, &argv); so that there’s absolutely nothing configured by the Sharc processor (no DMA, hardware / memory access, etc.).
    • Commented out lines #82 to #98 in app_startup().
    • Left uncommented lines #85 to #89 in the previous app_startup() snippet.
    Also, if we load the Sharc symbols on Sharc 1 from CCES after the first loadSharc is issued from Linux we can connect to the target without any problems. However, after the second loadSharc is issued and it gets stuck at Waiting for sharc, we can no longer connect to the Sharc 1 processor from CCES without performing a hard reset of the board:
    Hope this information helps troubleshoot the issue.
    We'll be happy to provide any further detail that you might require.
    Regards.
    Manuel
  • Thanks,
    This is helpful.
    Just to confirm which versions of CCES and the Linux add-in are you using?
    And what EZ-KIT are you running the software on?
    Dave
  • Hi Dave,
    thanks for the prompt reply.
    We are using a custom board that we have designed where both a SC589 (where the issues occurs) and a SC573 live.
    This is the actual chip:
    It's a 500MHz part. The markings atop of it are:
    • ADSP-SC589-KBCZ-5B
    • 42 19500 1-1.0
    • 1819 KOREA
    The CCES version we are using is 2.8.3.
    Let me know if you need further information.
    Manuel
  • Hi Dave,
    I was wondering if you may have any news on this issue.
    Thanks!
    Manuel
  • Hi Manuel,
    Do you see your SHARC+ code looping in your while loop or in the recv_arg() function?  Do you actually pass args into your application?
    Try moving your while loop before the recv_arg() function and see if you're able to load multiple times.
    Also, maybe something in the runtime start up code is causing an issue.  You can put a loop in <sharc core 1 project> -> system -> startup_ldf -> app_startup.s file somewhere after start: label. A simple loop would be
    nop;
    jump(pc, -1);
    You can start moving this loop further down the code if multiple re-loads are successful.
    Also, is MCAPI being compiled into your sharc application?  If it is, try removing it.
    Gabby
  • Hi Gabby,
    thanks a lot for the quick reply.
    Unfortunately no luck with the suggested tests.
    McAPI is part of the project but it was removed without success.
    In all cases loadSharc hangs at the Waiting for sharc statement. This is the full Linux output:
    # loadsharc_SC589 -i ZPU_SC589_SHARC_Core1_no_mcapi.ldr -s 1 -d 3 -a "unused"
    reading ZPU_SC589_SHARC_Core1_no_mcapi.ldr
    DEBUG LVL: 3
    booting sharc core 1
    number of sections: 8
    i: 0, tgt: 000900a8, size of data: 6
    Error: unable to determine the destination of section 0!
    i: 1, tgt: 00090000, size of data: 768
    Error: unable to determine the destination of section 1!
    i: 2, tgt: 200bb004, size of data: 4
    i: 3, tgt: 0802ec00, size of data: 5
    NW section sz not div by 4: 5
    i: 4, tgt: 0802f0c0, size of data: 15
    NW section sz not div by 4: 15
    i: 5, tgt: 200bc310, size of data: 5624
    i: 6, tgt: 200bb008, size of data: 22
    i: 7, tgt: 00bbd810, size of data: 4830
    Translated target address: 200bb020
    ptrMboxSh2Arm = 200bcd80
    ptrMboxArm2Sh = 200bcd84
    Waiting for sharc
    ptrLSync2ArmByteCount = 200bcd88
    ptrLdSync2ShByteCount = 200bcd8c
    ptrBootStream         = 200bc318
    waiting for sharc to request data for block num 0
    requested bytes: 16
    waiting for sharc to request data for block num 1
    requested bytes: 16
    waiting for sharc to request data for block num 2
    *ptrMboxSh2Arm = bbbb
    requested bytes: 104
    waiting for sharc to request data for block num 3
    requested bytes: 16
    waiting for sharc to request data for block num 4
    *ptrMboxSh2Arm = 6666
    requested bytes: 16
    waiting for sharc to request data for block num 5
    requested bytes: 4
    waiting for sharc to request data for block num 6
    requested bytes: 16
    waiting for sharc to request data for block num 7
    requested bytes: 16
    waiting for sharc to request data for block num 8
    requested bytes: 4
    waiting for sharc to request data for block num 9
    requested bytes: 16
    waiting for sharc to request data for block num 10
    requested bytes: 16
    waiting for sharc to request data for block num 11
    requested bytes: 4
    waiting for sharc to request data for block num 12
    requested bytes: 16
    waiting for sharc to request data for block num 13
    requested bytes: 16
    waiting for sharc to request data for block num 14
    requested bytes: 140
    waiting for sharc to request data for block num 15
    requested bytes: 16
    waiting for sharc to request data for block num 16
    requested bytes: 16
    waiting for sharc to request data for block num 17
    requested bytes: 8
    waiting for sharc to request data for block num 18
    requested bytes: 16
    waiting for sharc to request data for block num 19
    requested bytes: 16
    waiting for sharc to request data for block num 20
    requested bytes: 8
    waiting for sharc to request data for block num 21
    requested bytes: 16
    waiting for sharc to request data for block num 22
    requested bytes: 16
    waiting for sharc to request data for block num 23
    requested bytes: 1252
    waiting for sharc to request data for block num 24
    requested bytes: 16
    waiting for sharc to request data for block num 25
    requested bytes: 16
    waiting for sharc to request data for block num 26
    requested bytes: 284
    waiting for sharc to request data for block num 27
    requested bytes: 16
    waiting for sharc to request data for block num 28
    requested bytes: 16
    waiting for sharc to request data for block num 29
    requested bytes: 64
    waiting for sharc to request data for block num 30
    requested bytes: 16
    waiting for sharc to request data for block num 31
    requested bytes: 16
    waiting for sharc to request data for block num 32
    requested bytes: 2048
    waiting for sharc to request data for block num 33
    requested bytes: 16
    waiting for sharc to request data for block num 34
    requested bytes: 176
    waiting for sharc to request data for block num 35
    requested bytes: 16
    waiting for sharc to request data for block num 36
    requested bytes: 16
    waiting for sharc to request data for block num 37
    requested bytes: 8
    waiting for sharc to request data for block num 38
    requested bytes: 16
    waiting for sharc to request data for block num 39
    requested bytes: 16
    waiting for sharc to request data for block num 40
    requested bytes: 8
    waiting for sharc to request data for block num 41
    requested bytes: 16
    waiting for sharc to request data for block num 42
    requested bytes: 16
    waiting for sharc to request data for block num 43
    requested bytes: 8
    waiting for sharc to request data for block num 44
    requested bytes: 16
    waiting for sharc to request data for block num 45
    requested bytes: 16
    waiting for sharc to request data for block num 46
    requested bytes: 1948
    waiting for sharc to request data for block num 47
    requested bytes: 16
    waiting for sharc to request data for block num 48
    requested bytes: 16
    waiting for sharc to request data for block num 49
    requested bytes: 40
    waiting for sharc to request data for block num 50
    requested bytes: 16
    waiting for sharc to request data for block num 51
    requested bytes: 16
    waiting for sharc to request data for block num 52
    waiting for sharc to request data for block num 53
    requested bytes: 16
    waiting for sharc to request data for block num 54
    requested bytes: 1068
    waiting for sharc to request data for block num 55
    requested bytes: 16
    waiting for sharc to request data for block num 56
    requested bytes: 16
    waiting for sharc to request data for block num 57
    requested bytes: 4
    waiting for sharc to request data for block num 58
    requested bytes: 16
    waiting for sharc to request data for block num 59
    requested bytes: 16
    waiting for sharc to request data for block num 60
    requested bytes: 76
    waiting for sharc to request data for block num 61
    requested bytes: 16
    waiting for sharc to request data for block num 62
    requested bytes: 16
    waiting for sharc to request data for block num 63
    requested bytes: 8
    waiting for sharc to request data for block num 64
    requested bytes: 16
    waiting for sharc to request data for block num 65
    requested bytes: 16
    waiting for sharc to request data for block num 66
    requested bytes: 8
    waiting for sharc to request data for block num 67
    requested bytes: 16
    waiting for sharc to request data for block num 68
    requested bytes: 16
    waiting for sharc to request data for block num 69
    requested bytes: 12
    waiting for sharc to request data for block num 70
    requested bytes: 16
    waiting for sharc to request data for block num 71
    requested bytes: 16
    waiting for sharc to request data for block num 72
    requested bytes: 596
    waiting for sharc to request data for block num 73
    requested bytes: 16
    waiting for sharc to request data for block num 74
    requested bytes: 16
    waiting for sharc to request data for block num 75
    requested bytes: 8
    waiting for sharc to request data for block num 76
    requested bytes: 16
    waiting for sharc to request data for block num 77
    requested bytes: 4
    waiting for sharc to request data for block num 78
    requested bytes: 16
    waiting for sharc to request data for block num 79
    requested bytes: 4
    waiting for sharc to request data for block num 80
    requested bytes: 16
    waiting for sharc to request data for block num 81
    requested bytes: 8
    waiting for sharc to request data for block num 82
    requested bytes: 16
    waiting for sharc to request data for block num 83
    requested bytes: 28
    waiting for sharc to request data for block num 84
    requested bytes: 16
    waiting for sharc to request data for block num 85
    requested bytes: 768
    waiting for sharc to request data for block num 86
    requested bytes: 16
    waiting for sharc to request data for block num 87
    requested bytes: 8
    waiting for sharc to request data for block num 88
    requested bytes: 16
    waiting for sharc to request data for block num 89
    requested bytes: 4
    waiting for sharc to request data for block num 90
    requested bytes: 16
    waiting for sharc to request data for block num 91
    requested bytes: 4
    waiting for sharc to request data for block num 92
    requested bytes: 16
    waiting for sharc to request data for block num 93
    waiting for sharc to request data for block num 94
    requested bytes: 16
    waiting for sharc to request data for block num 95
    waiting for sharc to request data for block num 96
    requested bytes: 16
    waiting for sharc to request data for block num 97
    waiting for sharc to request data for block num 98
    requested bytes: 16
    waiting for sharc to request data for block num 99
    waiting for sharc to request data for block num 100
    requested bytes: 16
    waiting for sharc to request data for block num 101
    waiting for sharc to request data for block num 102
    requested bytes: 16
    waiting for sharc to request data for block num 103
    waiting for sharc to request data for block num 104
    requested bytes: 16
    waiting for sharc to request data for block num 105
    waiting for sharc to request data for block num 106
    requested bytes: 16
    waiting for sharc to request data for block num 107
    waiting for sharc to request data for block num 108
    requested bytes: 16
    waiting for sharc to request data for block num 109
    waiting for sharc to request data for block num 110
    requested bytes: 16
    waiting for sharc to request data for block num 111
    waiting for sharc to request data for block num 112
    requested bytes: 16
    waiting for sharc to request data for block num 113
    waiting for sharc to request data for block num 114
    requested bytes: 16
    waiting for sharc to request data for block num 115
    waiting for sharc to request data for block num 116
    requested bytes: 16
    waiting for sharc to request data for block num 117
    waiting for sharc to request data for block num 118
    requested bytes: 16
    waiting for sharc to request data for block num 119
    requested bytes: 460
    waiting for sharc to request data for block num 120
    requested bytes: 16
    waiting for sharc to request data for block num 121
    requested bytes: 1044
    waiting for sharc to request data for block num 122
    requested bytes: 16
    waiting for sharc to request data for block num 123
    requested bytes: 8
    waiting for sharc to request data for block num 124
    requested bytes: 16
    waiting for sharc to request data for block num 125
    waiting for sharc to request data for block num 126
    requested bytes: 16
    waiting for sharc to request data for block num 127
    waiting for sharc to request data for block num 128
    requested bytes: 16
    waiting for sharc to request data for block num 129
    requested bytes: 1416
    waiting for sharc to request data for block num 130
    requested bytes: 16
    waiting for sharc to request data for block num 131
    waiting for sharc to request data for block num 132
    requested bytes: 16
    waiting for sharc to request data for block num 133
    waiting for sharc to request data for block num 134
    requested bytes: 16
    waiting for sharc to request data for block num 135
    waiting for sharc to request data for block num 136
    requested bytes: 16
    waiting for sharc to request data for block num 137
    waiting for sharc to request data for block num 138
    requested bytes: 16
    waiting for sharc to request data for block num 139
    waiting for sharc to request data for block num 140
    requested bytes: 16
    waiting for sharc to request data for block num 141
    waiting for sharc to request data for block num 142
    requested bytes: 16
    waiting for sharc to request data for block num 143
    waiting for sharc to request data for block num 144
    requested bytes: 16
    waiting for sharc to request data for block num 145
    waiting for sharc to request data for block num 146
    requested bytes: 16
    waiting for sharc to request data for block num 147
    waiting for sharc to request data for block num 148
    requested bytes: 16
    waiting for sharc to request data for block num 149
    waiting for sharc to request data for block num 150
    requested bytes: 16
    waiting for sharc to request data for block num 151
    waiting for sharc to request data for block num 152
    requested bytes: 16
    waiting for sharc to request data for block num 153
    waiting for sharc to request data for block num 154
    requested bytes: 16
    waiting for sharc to request data for block num 155
    waiting for sharc to request data for block num 156
    requested bytes: 16
    waiting for sharc to request data for block num 157
    waiting for sharc to request data for block num 158
    requested bytes: 16
    waiting for sharc to request data for block num 159
    waiting for sharc to request data for block num 160
    requested bytes: 16
    waiting for sharc to request data for block num 161
    waiting for sharc to request data for block num 162
    requested bytes: 16
    waiting for sharc to request data for block num 163
    waiting for sharc to request data for block num 164
    requested bytes: 16
    waiting for sharc to request data for block num 165
    waiting for sharc to request data for block num 166
    requested bytes: 16
    waiting for sharc to request data for block num 167
    waiting for sharc to request data for block num 168
    requested bytes: 16
    waiting for sharc to request data for block num 169
    waiting for sharc to request data for block num 170
    requested bytes: 16
    waiting for sharc to request data for block num 171
    waiting for sharc to request data for block num 172
    requested bytes: 16
    waiting for sharc to request data for block num 173
    waiting for sharc to request data for block num 174
    requested bytes: 16
    waiting for sharc to request data for block num 175
    waiting for sharc to request data for block num 176
    requested bytes: 16
    waiting for sharc to request data for block num 177
    waiting for sharc to request data for block num 178
    requested bytes: 16
    waiting for sharc to request data for block num 179
    waiting for sharc to request data for block num 180
    requested bytes: 16
    waiting for sharc to request data for block num 181
    waiting for sharc to request data for block num 182
    requested bytes: 16
    waiting for sharc to request data for block num 183
    waiting for sharc to request data for block num 184
    requested bytes: 16
    waiting for sharc to request data for block num 185
    waiting for sharc to request data for block num 186
    requested bytes: 16
    waiting for sharc to request data for block num 187
    waiting for sharc to request data for block num 188
    requested bytes: 16
    waiting for sharc to request data for block num 189
    waiting for sharc to request data for block num 190
    requested bytes: 16
    waiting for sharc to request data for block num 191
    waiting for sharc to request data for block num 192
    requested bytes: 16
    waiting for sharc to request data for block num 193
    waiting for sharc to request data for block num 194
    requested bytes: 16
    waiting for sharc to request data for block num 195
    waiting for sharc to request data for block num 196
    requested bytes: 16
    waiting for sharc to request data for block num 197
    waiting for sharc to request data for block num 198
    requested bytes: 16
    waiting for sharc to request data for block num 199
    waiting for sharc to request data for block num 200
    requested bytes: 16
    waiting for sharc to request data for block num 201
    waiting for sharc to request data for block num 202
    requested bytes: 16
    waiting for sharc to request data for block num 203
    waiting for sharc to request data for block num 204
    requested bytes: 16
    waiting for sharc to request data for block num 205
    waiting for sharc to request data for block num 206
    requested bytes: 16
    waiting for sharc to request data for block num 207
    waiting for sharc to request data for block num 208
    requested bytes: 16
    waiting for sharc to request data for block num 209
    waiting for sharc to request data for block num 210
    requested bytes: 16
    waiting for sharc to request data for block num 211
    waiting for sharc to request data for block num 212
    requested bytes: 16
    waiting for sharc to request data for block num 213
    waiting for sharc to request data for block num 214
    requested bytes: 16
    waiting for sharc to request data for block num 215
    waiting for sharc to request data for block num 216
    requested bytes: 16
    waiting for sharc to request data for block num 217
    waiting for sharc to request data for block num 218
    requested bytes: 16
    waiting for sharc to request data for block num 219
    waiting for sharc to request data for block num 220
    requested bytes: 16
    waiting for sharc to request data for block num 221
    waiting for sharc to request data for block num 222
    requested bytes: 16
    waiting for sharc to request data for block num 223
    waiting for sharc to request data for block num 224
    requested bytes: 16
    waiting for sharc to request data for block num 225
    waiting for sharc to request data for block num 226
    requested bytes: 16
    waiting for sharc to request data for block num 227
    waiting for sharc to request data for block num 228
    requested bytes: 16
    waiting for sharc to request data for block num 229
    waiting for sharc to request data for block num 230
    requested bytes: 16
    waiting for sharc to request data for block num 231
    waiting for sharc to request data for block num 232
    requested bytes: 16
    waiting for sharc to request data for block num 233
    waiting for sharc to request data for block num 234
    requested bytes: 16
    waiting for sharc to request data for block num 235
    requested bytes: 224
    waiting for sharc to request data for block num 236
    requested bytes: 16
    waiting for sharc to request data for block num 237
    requested bytes: 1400
    waiting for sharc to request data for block num 238
    requested bytes: 16
    waiting for sharc to request data for block num 239
    requested bytes: -1
    Sharc signaled to stop... exiting
    ptrMboxSh2Arm_l2 = 20083000
    ptrMboxArm2Sh_l2 = 20083004
    ptrDataSh2Arm_l2 = 20083008
    ptrDataArm2Sh_l2 = 2008300c
    Waiting application to start up.
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    xValues: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    Values: 0000, 0000
    time expired waiting for Sharc msg...exiting
    DEBUG LVL: 3
    Waiting for sharc
    You will see that the first load is successful (even though it keeps Waiting application to start up because the Sharc code never reaches the recv_arg() function). Then, the second attempt to loadSharc hangs at Waiting for sharc.
    When loading the version without McAPI, the PC was stuck at location 0x43 which seems to correspond to the reserved region of the L1 memory (Boot ROM maybe?):
    By the way, we are not passing any args to the Sharc application.
    Overall, what I'd like to stress out is that on the SC589 EZ-KIT, loadSharc seems to work just fine and in a repeatedly manner.
    Please let me know if you need more info from our end and I'll be more than happy to provide it.
    Thanks for your assistance so far.
    Manuel
  • Hi Gabby,
    I was wondering if you might have any news about this issue.
    Thanks.
    Manuel
  • Hi Manuel,
    In the debug statements, does it show "Arguments to be passed: Unused" on the Ezkit?
    Can you try again with MCAPI  installed?  The argument receive interface uses the memory space that MCAPI would use.
    Can you see if that debug statement also shows up on your board when MCAPI is installed?
    Have you tried to port the simple GPIO/LED toggle program that comes with the EE-Note over to your board?  Does this load and run correctly?  Can this program be loaded multiple times?
    Gabby
