Unable to list device node under /dev
Hello there,
I have been trying to list my device under /dev for but did not find any luck. I have written a small kernel loadable module ( LED_driver.ko)
After doing insmod i am able to find the module entry in sysfs.
root:/> version
kernel: Linux release 3.1.0-ADI-2012R1-pre, build #28 Wed Nov 30 18:44:08 IST 2011
toolchain: bfin-uclinux-gcc release gcc version 4.3.5 (ADI-2010R1-RC4) user-dist:
release 2010R1, build #1 Fri Nov 25 15:30:22 IST 2011
Loading the module
root:/> insmod /home/LED_driver.ko
LED driver is added with major number = 254
sysfs
root:/> ls /sys/module/LED_driver/
holders initstate refcnt sections uevent
procfs
root:/> cat /proc/devices
Character devices:
1 mem
4 /dev/vc/0
4 tty
5 /dev/tty
5 /dev/console
5 /dev/ptmx
7 vcs
10 misc
13 input
89 i2c
90 mtd
128 ptm
136 pts
204 ttyBF
254 LED_driver
Block devices: 1 ramdisk 259 blkext 31 mtdblock 43 nbd
root:/> ls /dev/
bfin-dma nbd8 tty21 tty5
bfin-otp nbd9 tty22 tty50
console network_latency tty23 tty51
cpu_dma_latency network_throughput tty24 tty52
full null tty25 tty53
i2c-0 ptmx tty26 tty54
kmsg pts tty27 tty55
mem ram0 tty28 tty56
mtd0 ram1 tty29 tty57
mtd0ro ram2 tty3 tty58
mtd1 ram3 tty30 tty59
mtd1ro ram4 tty31 tty6
mtd2 ram5 tty32 tty60
mtd2ro ram6 tty33 tty61
mtdblock0 ram7 tty34 tty62
mtdblock1 random tty35 tty63
mtdblock2 tty tty36 tty7
I have followed the below links
http://docs.blackfin.uclinux.org/doku.php?id=uclinux-dist:dev-management
http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:hotplug
http://docs.blackfin.uclinux.org/doku.php?id=uclinux-dist:mdev
root:/> echo /sbin/mdev > /proc/sys/kernel/hotplug
root:/> mdev -s
root:/> ls /dev/
Still not able see the device node under /dev
Any pointers?
Thanks in advance
Krish
  • Hi Aronwu,
    Thanks for the directions. However I am not able to insmod my module after adding class attributes.
    LED_driver: Unknown symbol _class_destroy (err 0)
    LED_driver: Unknown symbol ___class_create (err 0)
    LED_driver: Unknown symbol _class_create_file (err 0)
    insmod: can't insert '/home/LED_driver.ko': unknown symbol in module, or unknown parameter
    Suspecting  insmod utility
    root:/> version
    kernel:    Linux release 3.1.0-ADI-2012R1-pre, build #26 Tue Nov 29 16:54:56 IST  2011
    user-dist: release 2010R1, build #1 Fri Nov 25 15:30:22 IST 2011
    How to make compatible insmod for the above setup?
    Also please let me know if i did something wrong in class creation.
    + Krish
  • Hmm...
    how come i missed that...
    added  MODULE_LICENSE("GPL");
    thanks for the support.
    + Krish
  • Now i am able to see my  device "led" under /dev
    root:/dev> ls
    bfin-dma            nbd5                tty17               tty46
    bfin-otp            nbd6                tty18               tty47
    console             nbd7                tty19               tty48
    cpu_dma_latency     nbd8                tty2                tty49
    fd                  nbd9                tty20               tty5
    full                network_latency     tty21               tty50
    i2c-0               network_throughput  tty22               tty51
    kmsg                null                tty23               tty52
    led
    on Apr 29, 2019 10:35 AM
    This question has been closed by the EZ team and is assumed answered.
