GNU tools LDF file warning
I am building using the GNU toolchain for a BF518.  I have a warning message that I do not understand enough to solve.
bfin-elf-ldr.exe: count is not 4 byte aligned (0x11E6 % 4 = 2)
bfin-elf-ldr.exe: going to pad the end with zeros, but you should fix this
It seems that I have not padded a section or something like that.  Can anyone help me understand the issue better so I can resolve it.
Here is the LDF file:
/* GNU Linker File */
/* Created based on the default linker script for single core blackfin standalone executables */
MEMORY
  MEM_L1_CODE       : ORIGIN = 0xFFA00000, LENGTH = 0x7FFF
  MEM_L1_CODE_CACHE : ORIGIN = 0xFFA10000, LENGTH = 0x3FFF
  MEM_L1_SCRATCH    : ORIGIN = 0xFFB00000, LENGTH = 0xFFF
  MEM_L1_DATA_B     : ORIGIN = 0xFF900000, LENGTH = 0x7FFF
  MEM_L1_DATA_A     : ORIGIN = 0xFF800000, LENGTH = 0x7FFF
  MEM_SDRAM         : ORIGIN = 0x00000004, LENGTH = 0xFFFFEC
  MEM_L2            : ORIGIN = 0xFEB00000, LENGTH = 0x0
  default           : ORIGIN = 0x00000004, LENGTH = 0xFFFFEC
OUTPUT_FORMAT("elf32-bfin", "elf32-bfin", "elf32-bfin")
OUTPUT_ARCH(bfin)
ENTRY(__start)
SECTIONS
  /* Read-only sections, merged into text segment: */
  PROVIDE (__executable_start = 0x4); . = 0x4;
   .init           :
    KEEP (*(.init))
    *(program interrupts dmaDescriptors)
  } >MEM_L1_CODE =0
  .sdram.data :
    . = 0x10000;
    *(.sdram.data TASK_STACKS)
  } >MEM_SDRAM =0
  .l2             :
    *(.l2 .l2.*)
  } >MEM_L2 =0
  .text           :
    *(.text .text.* .l1.text .l1.text.*)
    KEEP (*(.text.*personality*))
    /* .gnu.warning sections are handled specially by elf32.em.  */
    *(.gnu.warning)
  } >MEM_SDRAM =0
  .fini           :
    KEEP (*(.fini))
  } >MEM_L1_CODE =0
  .rodata         :
    *(.rodata .rodata.*)
  } >MEM_SDRAM =0
  .data           :
    *(.data .data.* .l1.data .l1.data.*)
    KEEP (*(.*personality*))
  } >MEM_SDRAM =0
  .bss            :
   __bss_start = .;
    *(.bss .bss.*)
    *(COMMON)
    __bss_end = .;
  } >MEM_SDRAM =0
  . = ALIGN(32 / 8);
  . = ALIGN(32 / 8);
  __end = .; PROVIDE (_end = .);
  __stack_start = ORIGIN(MEM_L1_SCRATCH);
  __stack_end   = ORIGIN(MEM_L1_SCRATCH) + 0x200;
  /DISCARD/ : { *(.note.GNU-stack) }
