gdbproxy crash when debugging rtems sample with gnice+
Hi everone,
I use eclipse Helios under windows 7
Eclipse has RTEMS plug-in and blackfin Plug-in installed
I have GNU toolchains 2010R1, 2011R1 and 2014R1_45 installed
when I connect my gniCE+, and run: ">bfin-gdbproxy bfin" on windows cmd, only 2010R1 gets to work, and the other two versions give the error: cable initialization failed
with 2010R1 I get this:
Found USB cable: gnICE+
Connected to libftdi driver.
IR length: 5
Chain length: 1
Device Id: 00100010011111100000000011001011 (0x227E00CB)
  Manufacturer: Analog Devices, Inc. (0x0CB)
  Part(0):      BF527 (0x27E0)
  Stepping:     2
  Filename:     c:\program files (x86)\analog devices\gnu toolchain\2014r1_45\el
f\bin\../share/urjtag/analog/bf527/bf527
warning:   bfin: no board selected, BF527 is detected
notice:    bfin: jc: waiting on TCP port 2001
notice:    bfin: jc:  (you must connect GDB before using jtag console)
notice:    bfin-gdbproxy: waiting on TCP port 2000
I suppose everything is fine so far, but when I click debug in eclipse, the gdbproxy crashes and I get this:
info:  [0] emulator not ready: DBGSTAT [0x000A]
info:  Resetting ...
Assertion failed: emuready, file /usr/src/packages/BUILD/blackfin-toolchain-2010
R1/urjtag/src/bfin/bfin.c, line 577
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
the application I try to debug is Hello-World sample program for RTEMS that builds just fine without errors
after gdbproxy crashes, eclipse console shows this ..
No symbol "new" in current context.
set remotetimeout 300
load
Loading section .init, size 0x7c lma 0x100
Remote communication error: Bad file descriptor.
tbreak main
Function "main" not defined.
continue
putpkt: write failed: No error.
0x00000000 in ?? ()
kill
Parents
  • this is everything gdbproxy outputs to the cmd :
    Remote proxy for GDB, v0.7.2, Copyright (C) 1999 Quality Quorum Inc.
    MSP430 adaption Copyright (C) 2002 Chris Liechti and Steve Underwood
    Blackfin adaption Copyright (C) 2008 Analog Devices, Inc.
    GDBproxy comes with ABSOLUTELY NO WARRANTY; for details
    use `--warranty' option. This is Open Source software. You are
    welcome to redistribute it under certain conditions. Use the
    '--copying' option for details.
    IR length: 5
    Chain length: 1
      Stepping:     2
    notice:    bfin-gdbproxy: connected
Reply
    IR length: 5
    Chain length: 1
      Stepping:     2
Children
No Data
