Unable to boot from NAND
I have a custome board with nand,sdram,spi,bf532,etc.
Steps:
Transfer the uclinux image via serial
bfin> loady
## Ready for binary (ymodem) download to 0x01000000 at 115200 bps...
Cm - CRC mode, 35312(SOH)/0(STX)/0(CAN) packets, 3 retries
## Total Size = 0x0044f68d = 4519565 Bytes
Erase and write the nand flash
bfin> nand erase clean
NAND erase: device 0 whole chip
Skipping bad block at 0x0b580000
Erasing at 0xffe0000 -- 100% complete. Cleanmarker written at 0xffe0000.
OK
bfin> nand write.jffs2 0x01000000 0x0 0x00450000
NAND write: device 0 offset 0x0, size 0x450000
4521984 bytes written: OK
Boot kernel image from nand
bfin> nboot 0x2000000 0x0
Loading from NAND 256MiB 3,3V 8-bit, offset 0x0
Image Name: Linux Kernel and ext2
Image Type: Blackfin Linux Kernel Image (gzip compressed)
Data Size: 4519501 Bytes = 4.3 MiB
Load Address: 00001000
Entry Point:002fcc3c
bfin>
Why booting is not done after Entry Point:00fcc3c ? Please guide.
  • Submitted By: Mike Frysinger (vapier)
    automatic booting is only done if you set "autostart=yes" in your env. if you dont have that, then nboot is acting as designed.
  • I have the same problem. I'm using the bf548 EZ-KIT Lite
    I've even set autoboot to yes, but it doesn't work. See below.
    bfin> tftp uImage
    smc911x: detected LAN9218 controller
    smc911x: phy initialized
    smc911x: MAC 00:e0:22:fe:c2:8b
    Using smc911x-0 device
    TFTP from server 192.168.0.2; our IP address is 192.168.0.15
    Filename 'uImage'.
    Load address: 0x1000000
    Loading: #################################################################
    done
    Bytes transferred = 12830251 (c3c62b hex)
    bfin> nand erase.chip clean
    NAND erase.chip: device 0 whole chip
    Skipping bad block at  0x0b080000
    OK
    bfin> nand write.jffs2 0x1000000 0x0 0xC40000
    NAND write: device 0 offset 0x0, size 0xc40000
    12845056 bytes written: OK
    bfin> setenv autoload yes
    bfin> printenv
    addip=set bootargs $(bootargs) ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname):eth0:off
    autoload=yes
       Image Name:   bf548-2.6.34.7-ADI-2010R1
       Created:      2012-08-31   4:56:10 UTC
       Data Size:    12830187 Bytes = 12.2 MiB
       Entry Point:  002a28b4
    bfin>
    So why doesn't it boot automatically? If it can't start automatically, how do you boot it manually?
  • Could you start new thread instead of the replying on the ancient  ones? and if the discussion of this ancient answered issue will help you?
    on Apr 29, 2019 10:34 AM over 1 year ago
    This question has been closed by the EZ team and is assumed answered.
