PBX AS ROUTER CRASH
Our product have two 8139 netcards, some customers use it as router. After about one hour the product will crash when playing video. There is no output in the serial port. After i turn on the option CONFIG_DEBUG_BFIN_HWTRACE_EXPAND,
the product is very stable, but the performance is very bad. Can you tell me how to trace the crash problem for no output?
The kernel version is:
uname -a
Linux  2.6.34.7-ADI-2010R1 #18 Fri Aug 5 07:37:12 UTC 2016 blackfin GNU/Linux
  • Hi Yijun, do you mean it hangs after playing video for 1 hour, or it woks as PBX device for 1 hour, then play video and hangs? Is it possible that:
    1) Do "cat /proc/meminfo" after a long time working before crash and share the output?
    2) Reproduce this issue in someway on the ADI ezkit so we can try on our side too?
    Assume this product is based on BF609?
  • Hi Aaronwu,
           Thanks for your reply, it hangs after playing video for 1 hour, the data traffic is PC<--->LAN PORT<--->WAN PORT<--->INTERNET. it is based on bf533, the part of boot message see the following:
       Image Name:   bf533-2.6.34.7-ADI-2010R1
       Image Type:   Blackfin Linux Kernel Image (gzip compressed)
       Data Size:    6819105 Bytes = 6.5 MiB
       Load Address: 00001000
       Entry Point:  00233cf0
       Verifying Checksum ... OK
       Uncompressing Kernel Image ... OK
      Starting Kernel at = 00233cf0
       Linux version 2.6.34.7-ADI-2010R1 (root@ubuntu) (gcc version 4.3.5 (ADI) ) #18 Fri Aug 5 07:37:12 UTC 2016
      register early platform devices
      Board Memory: 128MB
      Kernel Managed Memory: 128MB
           During the test, i had been watching the changes of the system information by top command,  both memory and cpu usage
    are normal. I don't know why no any exception information output?
    cat /proc/meminfo
    MemTotal:         126680 kB
    MemFree:           70744 kB
    Buffers:               0 kB
    Cached:            17776 kB
    SwapCached:            0 kB
    Active:             6360 kB
    Inactive:          11424 kB
    Active(anon):          0 kB
    Inactive(anon):        0 kB
    Active(file):       6360 kB
    Inactive(file):    11424 kB
    Unevictable:           0 kB
    Mlocked:               0 kB
    MmapCopy:          33304 kB
    SwapTotal:             0 kB
    SwapFree:              0 kB
    Dirty:                 0 kB
    Writeback:             0 kB
    AnonPages:             0 kB
    Mapped:                0 kB
    Shmem:                 0 kB
    Slab:               4228 kB
    SReclaimable:        708 kB
    SUnreclaim:         3520 kB
    KernelStack:         512 kB
    PageTables:            0 kB
    NFS_Unstable:          0 kB
    Bounce:                0 kB
    WritebackTmp:          0 kB
    CommitLimit:       63340 kB
    Committed_AS:          0 kB
    VmallocTotal:          0 kB
    VmallocUsed:           0 kB
    VmallocChunk:          0 kB
