error attempting to build the 2012R2-RC2 ToolChain
Problem:
Got and error attempting to build the ToolChain, after 1.5 hrs.
This had built successfully, previously, when I did not include
the u-boot build (-u ~/blackfin-sources/u-boot \).
Components:
Host:             Ubuntu
Toolchain:      blackfin-toolchain-2012R2-RC2.src.tar.bz2
uclinux-dist:   blackfin-linux-dist-2011R1-RC3.tar.bz2
u-boot:           u-boot-2011.11-2011R1-RC5
Command line to Build the toolchain:
~/blackfin-sources/toolchain/buildscript/BuildToolChain \
  -b ~/blackfin-sources/build \
  -k ~/blackfin-sources/uclinux-dist/linux-2.6.x \
  -s ~/blackfin-sources/toolchain \
  -S qemu
The file build/logs/config.logs.tbz2 is attached.
The following are the final lines from the log file in build/logs:
bfin-uclinux: uClibc: cleaning
make V=1 distclean
  CLEAN include
  CLEAN ldso/ldso
  CLEAN ldso/libdl
  CLEAN libcrypt
  CLEAN libintl
  CLEAN libm
  CLEAN libnsl
  CLEAN libresolv
  CLEAN libutil
  CLEAN libpthread/linuxthreads.old
  CLEAN libpthread/linuxthreads.old_db
  CLEAN librt
  CLEAN libubacktrace
  CLEAN extra/locale
  CLEAN libc/sysdeps/linux/bfin
  CLEAN libc/sysdeps/linux/common
  CLEAN libc/misc/assert
  CLEAN libc/misc/ctype
  CLEAN libc/misc/dirent
  CLEAN libc/misc/error
  CLEAN libc/misc/elf
  CLEAN libc/misc/file
  CLEAN libc/misc/fnmatch
  CLEAN libc/misc/ftw
  CLEAN libc/misc/fts
  CLEAN libc/misc/glob
  CLEAN libc/misc/gnu
  CLEAN libc/misc/internals
  CLEAN libc/misc/locale
  CLEAN libc/misc/mntent
  CLEAN libc/misc/pthread
  CLEAN libc/misc/regex
  CLEAN libc/misc/search
  CLEAN libc/misc/statfs
  CLEAN libc/misc/syslog
  CLEAN libc/misc/sysvipc
  CLEAN libc/misc/time
  CLEAN libc/misc/ttyent
  CLEAN libc/misc/utmp
  CLEAN libc/misc/wchar
  CLEAN libc/misc/wctype
  CLEAN libc/misc/wordexp
  CLEAN libc/pwd_grp
  CLEAN libc/stdio
  CLEAN libc/string
  CLEAN libc/termios
  CLEAN libc/inet/rpc
  CLEAN libc/inet
  CLEAN libc/signal
  CLEAN libc/stdlib/malloc
  CLEAN libc/stdlib/malloc-simple
  CLEAN libc/stdlib/malloc-standard
  CLEAN libc/stdlib
  CLEAN libc/unistd
  CLEAN libc
  CLEAN include (libpthread/linuxthreads.old)
  CLEAN include (libpthread/linuxthreads.old_db)
  CLEAN include (libc/sysdeps/linux/bfin)
  CLEAN include (common)
find: ./include/dl-osinfo.h: No such file or directory
find: ./include/semaphore.h: No such file or directory
find: ./include/hp-timing.h: No such file or directory
find: ./include/bfin_fixed_code.h: No such file or directory
find: ./include/bfin_l1layout.h: No such file or directory
find: ./include/thread_db.h: No such file or directory
make: *** [include_clean] Error 1
make: *** Waiting for unfinished jobs....
ShutEyeThinkin
config.logs.tbz2.zip
    Are you sure it's u-boot that's the only difference?  You're trying to build the 2012R2 toolchain using the 2011R1 kernel headers, which I think is probably the problem.  The kernel headers used to build the toolchain (from the 2012R2 buildroot release) are actually bundled with the toolchain sources, in the kbuild_output directory.
    If you really want to use the 2011R1 uclinux release, then you should use the 2011R1 toolchain.  Otherwise, i would recommend moving forward to the 2012R2 buildroot linux release.
    I'm doing a test build of the release sources just now to see if I can reproduce the failure.
    Stu
  • First of all, are you sure you need to rebuild the toolchain?  You might be better off using the pre-built binaries available on the blackfin.uclinux.org website if you don't plan to change any of the default build options?
    If you do think you need to build them, then all you need to do (after unpackaging all the tarballs), is:
    cd ~/blackfin-sources
    ./buildscript/BuildToolChain -K ~/blackfin-sources/kbuild_output
    Everything else should be set automatically (the u-boot sources should already be there).
    There's some notes on packages you might need on the host here:
    http://docs.blackfin.uclinux.org/doku.php?id=installing_linux
    Let me know if you hit any problems (i'm on vacation next week, miles from phone coverage, but i'll try and check in when I can).
    As for building buildroot, could you create a new thread on the buildroot forum for that?  They know much more about this than I do.
    Stu
  • After some thought, I am going to go ahead and heed your advice, and am now downloading the 2012R2 buildroot release, blackfin-buildroot-2012R2-RC5.tar.bz2. It will require some additional time to update the kernel mods and configuration mods, and other, but it is probably the prudent thing to do.
  • I will need guidance on building the buildroot, etc.  I have looked at the page 'Configure and build buildroot distribution', but it is very different from what I've been used to, and I'm confused.
    I have downloaded blackfin-buildroot-2012R2-RC5.tar.bz2, and extracted it into ~/blackfin-sources.
    I have downloaded the toolchain, blackfin-toolchain-2012R2-RC2.src.tar.bz2. I extracted the .src folder, and then extracted each .tar.bz2 file in it, then copied that entire folder into ~/blackfin-sources.
    Should I also extract and place u-boot-2011.11-2011R1-RC5 into ~/blackfin-sources?
    At this point, can/should I use something similar to the following? And if so, how should I modify it?
    Command line to Build the buildroot/toolchain:
      -S qemu
    Thanks
    ShutEyeThinkin
  • OK, and thanks.  Enjoy your vacation and come back all relaxed. :>)
