is it possible to disable just specific interrups in the portENTER_CRITICAL of FreeRTOS.
For example to not disable the System event controller interrupt, to ensure System Interrupts are not touched by the RTOS.
Regards
Bernhard
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
ADSP-21569
Recommended for New Designs
Reaching speeds of up to 1 GHz, the ADSP-2156x processors are members of the SHARC® family of products. The ADSP-2156x processor is based on the SHARC...
Datasheet
ADSP-21569 on Analog.com
Regards
Bernhard
Divya.P - Moved from ADSP-SC5xx/ADSP-215xx to FreeRTOS. Post date updated from Friday, October 24, 2025 11:13 AM UTC to Monday, October 27, 2025 4:25 AM UTC to reflect the move.
Hi Bernhard,
Thank you for your inquiry.
We are looking into this query now. We will get back to you soon.
Best Regards,
Santhakumari.V
Hi Bernhard,
In FreeRTOS, the portENTER_CRITICAL function clears the IRPTEN bit in the Mode Control 1 Register, which disables global interrupts. We do not recommend modifying the OS source files, as it might create untested conflicts and affect system stability.
Best Regards,
Santhakumari.V
