ADSP-21569
Recommended for New Designs
Reaching speeds of up to 1 GHz, the ADSP-2156x processors are members of the SHARC® family of products. The ADSP-2156x processor is based on the SHARC...
Datasheet
ADSP-21569 on Analog.com
Copyright(c) 2020 Analog Devices, Inc. All Rights Reserved.
This software is proprietary and confidential. By using this software you agree
to the terms of the associated Analog Devices License Agreement.
* SPI_MemoryMappedMode.c
#include <stdio.h>
#include <sys/platform.h>
#include <drivers/spi/adi_spi.h>
#include "adi_initialize.h"
#include "SPI_MemoryMappedMode.h"
ADI_SPI_HANDLE hSpi;
uint8_t SpiMemory[ADI_SPI_BIDIR_MEMORY_SIZE];
uint8_t ReadBuffer[BUFFER_SIZE]={0};
/* prototype */
void ConfigSoftSwitches_EV_21569_SOM(void);
void ConfigSoftSwitches_EV_SOMCRR_EZKIT(void);
static void CheckResult(ADI_SPI_RESULT Result) {
if (Result != ADI_SPI_SUCCESS) {
printf("Failed with error code 0x%08X\n", Result);
int main()
uint32_t Result,gpioMaxCallbacks;
ADI_SPI_RESULT eResult;
ADI_SPI_MMRDH_PARAM Mmrdh;
uint32_t *pSPI_MEM ;
adi_initComponents();
ConfigSoftSwitches_EV_21569_SOM();
ConfigSoftSwitches_EV_SOMCRR_EZKIT();
/* open SPI */
eResult = adi_spi_Open(SPI_DEVICE_NUM, ADI_SPI_DIR_BIDIRECTION, SpiMemory, ADI_SPI_BIDIR_MEMORY_SIZE, &hSpi);
CheckResult(eResult);
/* Set the MMRDH parameters
* struct ADI_SPI_MMRDH_PARAM available in adi_spi_2156x.h has detailed description of
* the below mentioned fields */
Mmrdh.bCmdSkip = false;
Mmrdh.bCmdPins = false;
Mmrdh.bAddrPin = false;
Mmrdh.bMergeEnable = false;
Mmrdh.bWrapEnable = false;
Mmrdh.nOpcode = CMD_SINGLE_MODE_READ;
Mmrdh.nModeField = 0x00u;
// Mmrdh.nAddrSize = ADI_SPI_MMRDH_ADRSIZE_3BYTE;
Mmrdh.nAddrSize = ADI_SPI_MMRDH_ADRSIZE_4BYTE;
Mmrdh.nDummybytes = ADI_SPI_MMRDH_0_DUMMY_BYTE;
Mmrdh.nTristateTiming = ADI_SPI_MMRDH_NEVER_TRISTATE;
eResult = adi_spi_SetSlaveSelectDelay(hSpi,true,true,3ul);
eResult = adi_spi_SetWordSize(hSpi,ADI_SPI_WORDSIZE_32BIT);
eResult = adi_spi_SetHWSlaveSelect(hSpi,true);
eResult = adi_spi_SetSlaveSelect(hSpi,ADI_SPI_SSEL_ENABLE1);
eResult = adi_spi_Enable_MemMappedMode(hSpi,Mmrdh,NULL);
/* Read the contents of the SPI Flash memory which should be verified with
* the data written into by the flash programmer */
uint32_t sectorAddress = SECTOR_OFFSET;
pSPI_MEM = (uint32_t *)0x60000000;
int32_t pIntBuffer[COUNT];
int32_t *tmp;
uint32_t currentAddress;
for(uint32_t i=0; i<COUNT; i++)
// ReadBuffer[LoopVar]= *pSPI_MEM++;
//currentAddress = (uint32_t)(pSPI_MEM + sectorAddress + (i * sizeof(int32_t)));
currentAddress = (uint32_t)(pSPI_MEM + SECTOR_OFFSET + i );
// printf("Reading from address: 0x%08X\n", currentAddress);
pIntBuffer[i] = *(int32_t *)currentAddress;
eResult = adi_spi_Disable_MemMappedMode(hSpi);
/* Close the SPI driver */
eResult = adi_spi_Close(hSpi);
/* open SPI */
eResult = adi_spi_SetSlaveSelect(hSpi, SPI_SELECT_NUM);
eResult = adi_spi_SetWordSize(hSpi, ADI_SPI_WORDSIZE_32BIT);
/* Read the contents of the SPI Flash memory */
int32_t intBuffer[COUNT];
int32_t pReadData[COUNT];
ADI_SPI_TRANSCEIVER_PARAM transceiver;
for (uint32_t i = 0; i < COUNT; i++) {
//currentAddress = (uint32_t)(pSPI_MEM + SECTOR_OFFSET + i );
currentAddress = (uint32_t)( pSPI_MEM+SECTOR_OFFSET + i);
// Setup the transceiver for read operation
uint8_t command[4] = {0x03, (currentAddress >> 16) & 0xFF, (currentAddress >> 8) & 0xFF, (currentAddress >> 0) & 0xFF};
// uint8_t command[5] = {0x13,(currentAddress >> 24) & 0xFF, (currentAddress >> 16) & 0xFF, (currentAddress >> 8) & 0xFF, currentAddress & 0xFF}; // 0x0B is the opcode for 32-bit address read
transceiver.pTransmitter = command; //
transceiver.pReceiver = & intBuffer[i];
transceiver.TxBytes = sizeof(command);
transceiver.RxBytes = sizeof(command); // Size of data to read
eResult = adi_spi_CoreTransceiver(hSpi, &transceiver);
uint8_t seqReadWrite[4];
seqReadWrite[0] = 0x03;
seqReadWrite[1] = (currentAddress >> 16) & 0xFF;
seqReadWrite[2] = (currentAddress >> 8) & 0xFF;
seqReadWrite[3] = (currentAddress >> 0) & 0xFF;
eResult = adi_spi_CoreWrite(hSpi,seqReadWrite,4);
eResult = adi_spi_CoreRead(hSpi,&pReadData,COUNT,ADI_OSAL_TIMEOUT_FOREVER);
uint8_t seqReadWrite2[5];
seqReadWrite2[0] = 0x13;
seqReadWrite2[1] = (currentAddress >> 24) & 0xFF;
seqReadWrite2[2] = (currentAddress >> 16) & 0xFF;
seqReadWrite2[3] = (currentAddress >> 8) & 0xFF;
seqReadWrite2[4] = (currentAddress >> 0) & 0xFF;
eResult = adi_spi_CoreWrite(hSpi,seqReadWrite2,5);
return 0;
I am using an adsp-21569 development board with an IS25LP512M on the SOM. I plan to read data through the SPI interface, starting from the address 0x60000000. The reference routine reads data using the memory-map method without any issues. However, I have not been successful using either adi_spi_CoreRead or adi_spi_CoreTransceiver. Could you please help me troubleshoot the problem?
Thank you for your inquiry.
In SPI, Memory-MappedMode directly reads content from the SPI Flash memory, so the "adi_spi_CoreRead" and "adi_spi_CoreTransceiver" APIs are not required in this mode. If you want to use these APIs, you need to disable the Memory-MappedMode.
You can also refer the below linked FAQ "SPI Flash readback in MemMapped Mode(MDMA)"
For more information about Memory-Mapped Mode, please refer the topic "Memory-Mapped Mode (SPI2 only)" in below linked HRM:
https://www.analog.com/media/en/dsp-documentation/processor-manuals/adsp-2156x_hwr.pdf#unique_603
Hope this helps.
Nishanthi.V
