Is there an easy way to set up a launch configuration within CrossCore Embedded Studio?
Colin.
Parents
  • Hi Colin,
    CrossCore Embedded Studio has a feature called a "launch shortcut" that helps pre-fill some of the items in the launch configuration dialog. To use this feature, do the following:
    • Build your project
    • Right click on your project and then click on “Debug As: CrossCore Application”. This brings up the launch configuration dialog, and launches the ‘Session Wizard’ dialog.
    • The processor type is already selected for you; it was determined from the project's processor type.
    • Now go through the rest of the session wizard and click ‘Finish’.
    • The application DXE to load is now pre-filled as well.
    • Click ‘Debug’.
    David.
Reply
  • Hi Colin,
    • Click ‘Debug’.
    David.
Children
No Data
