ICE-2000 with VDSP works in Win10 but not in Win11
Product Number: ADZS-ICE-2000
Hello, I have two ICE-2000 which work fine in VDSP++ on a Win10 PC but not on a Win11 PC. Both use VDSP++ 5.1.2
Does anyone have a similar problem and a possible solution?
Thank you so much!
-Joerg
Thread Notes
  • Hi Joerg,
    Thank you for your inquiry.
    1. Unfortunately, we are not aware of any similar issues reported by other customers. In order to isolate your issue, could you please share the below point. This will help us to assist you further on this:
    2. Does the emulator detected by the PC? Check whether the emulator is listed under 'Crosscore Tools'. If listed, double-click on the emulator to show the driver properties and ensure there are no issues listed. If there, please share the screenshot of the device manager by clicking the emulator > properties > Driver.
    3. Does the ICE Test utility run successfully or does it fail at any point? If the Test fails, please provide us with a screenshot showing the ICE Test results
    4. Do you receive any error messages while debugging? If so, please send in details of these errors and if possible screenshots of them.
    5. Do you have any other emulators of the same type or different one (ICE-1000), which operates correctly with the same PC?
    6. If you have access to different Win11 machines, please confirm whether you are facing the same behavior when trying on other PC's too.
    7. Is this your first time you are facing the issue with ICE-2000 emulator on a Win11 PC, or were you able to successfully use the same emulator previously?
    8. Did you buy this emulator direct from Analog devices or a distributor?
    Please go through our Emulator Troubleshooting Guide and let us know the results of the troubleshooting steps it advises.
    http://www.analog.com/ee175
    Waiting for your reply.
    Best Regards,
    Santhakumari.V
