EV-SC598-EZKIT-Audio-Starter 2.0.0 build failure with CCES 3.1.0
The user encountered build errors with the EV-SC598-EZKIT-Audio-Starter project (release 2.0.0) in CCES 3.1.0. The final answer confirms that CCES 3.1.0 is not supported, and recommends using CCES 3.0.3 instead. The errors are due to changes in _GLOBAL_REENT and adi_rtl_get_tls_ptr() in CCES 3.1.0. The user can download CCES 3.0.2 from the provided link for legacy versions.
I'm trying to build the official EV-SC598-EZKIT-Audio-Starter project from GitHub:
github.com/.../EV-SC598-EZKIT-Audio-Starter (branch/tag: 2.0.0-Github).
My hardware setup is:
  • EV-SOMCRR-EZKIT
  • EV-SC598-SOM
  • ADZS-AD2428MINI
  • EVAL-AD2428WC4BZ
I installed CrossCore Embedded Studio 3.1.0 and followed the README instructions on the repository to build the code, but I'm getting the following error:
Questions:
  1. Is the EV-SC598-EZKIT-Audio-Starter release 2.0.0 officially supported with CCES 3.1.0?
  2. Has the runtime API for _GLOBAL_REENT and/or adi_rtl_get_tls_ptr() changed between CCES 3.0.2 and 3.1.0?
  3. Is there a patch, updated branch, or recommended workaround for building this project with CCES 3.1.x?
  4. If CCES 3.0.2 is required, where can I obtain the installer? I was unable to find an archive download.
Any guidance would be appreciated.
Francesco
