[CCES v3.0.4] Error 1310 (Access Denied) during installation for EV-SC598-SOM / EV-SOMCRR-EZKIT
The user is experiencing Error 1310 during CCES v3.0.4 installation on Windows, preventing the creation of .xd linker script files. The final answer suggests verifying free disk space (11 GB required), temporarily disabling antivirus software, and checking the installer file size (1.29 GB). Relevant products: EV-SC598-SOM, EV-SOMCRR-EZKIT.
Product Number: EV-SC598-SOM
Software Version: CCES v3.0.4
I am experiencing an installation issue with CrossCore® Embedded Studio (CCES) v3.0.4 on Windows while setting up development tools for EV-SC598-SOM and EV-SOMCRR-EZKIT.
1. Issue Description: Following the official instructions by executing adi_crosscoreembeddedstudio-rel3.0.4.exe directly, the installer consistently terminates with the following error:
Error 1310. Error writing to file: [Install_Path]\ARM\aarch64-none-elf\aarch64-none-elf\lib\ldscripts\aarch64elf.xd. Verify that you have access to that directory. (System error 0)
2. System Environment & Troubleshooting Steps Taken:
  • User Identity & Privilege: My Windows account has full local Administrator privileges, and the installer was explicitly executed via "Run as administrator".
  • Installation Path: Changed the installation directory from the default system drive (C:) to a non-system drive (D:\CCES_App) with confirmed full write access.
  • Administrative Install Test: Attempted manual extraction using msiexec /a cces_3.0.4.msi /qb TARGETDIR="D:\CCES_App", but the same Error 1310 occurred when writing the .xd linker script files.
  • Corporate Endpoint Constraint: The machine is managed under a corporate Symantec Endpoint Protection (SEP) policy. Attempts to modify registry keys under HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\... to enable Windows Installer (msiserver) in Windows Safe Mode resulted in "Access Denied" due to policy restrictions.
3. Request for Assistance:
  • Are there alternative official standalone binaries/archives (e.g., .zip format) for CCES v3.0.4 that bypass the Windows Installer (msiserver) service?
  • Could you clarify why the standard installer specifically triggers write-access rejections on .xd / .xce files, and provide the exact file signatures/paths required for an IT endpoint protection exclusion request?
I have attached the installation verbose log (/L*V) for your reference. Any insights would be appreciated.
install.log
    Could you please confirm whether your system has sufficient free disk space? To install CrossCore® Embedded Studio v3.0.4, at least 11 GB of available disk space is required.
    Also, please try temporarily disabling any antivirus software running in your PC, as security programs can sometimes block MSI execution.
    Verify that the downloaded installer file size is 1.29 GB (13,53,351 KB) to ensure the package is complete and not corrupted.
    If you are still facing issues, please let us know which windows OS you are attempting to install CCES.
    Santhakumari.V
  • Hi Santhakumari,
    Thank you for your response.
    I would like to confirm that the installation of CCES v3.0.4 has now been successfully completed.
    Here are the details and the final resolution regarding the issue:
    1. Root Cause & Solution:
    • The issue was resolved after our corporate IT team temporarily disabled the active endpoint security protection (Windows Defender / Symantec Endpoint Protection).
    • Experimental Observation during Installation: While the installation was in progress, our IT personnel experimentally re-enabled Windows Defender. The exact same Error 1310 (writing .xd file) popped up immediately. After disabling the security protection again and clicking "Retry", the installer resumed and finished the installation successfully.
    2. System Information:
    • OS Edition: Windows 11 Pro
    • Version: 25H2
    • OS Build: 26200.8875
    • Experience: Windows Feature Experience Pack 1000.26100.334.0
    • Disk Space & File Integrity: Checked prior to installation; available space (>11 GB) and the installer file size (1.29 GB / 1,353,351 KB) were both correct.
    It appears that endpoint security programs specifically flag and block the msiexec process from writing .xd linker script files during the CCES deployment.
    Thank you again for your support.
    Cindy
