Extending analog inputs for ADZS-SC584-EZLITE
we're working with ADZS-SC584-EZLITE for prototyping algorithms. I'm looking for an easy way to add more analog inputs to the evaluation board. I found the ADZS-SHAUDIO-EZEXT with12 additional input channels, but this is only available for the expansion interface II. The eval board ADZS-SC584-EZLITE has an expansion interface III already. Is this still compatible? Or is there any other extension board to use?
Thanks!
mss
  • Hello,
    Please note that, The SHARC Audio EZ-Extender is designed as an extender board to the ADSP-214xx EZ-Board evaluation systems.
    You can use EI3 SDP Breakout Board (ADZS-BRKOUT-EX3)to connect with ADSP-SC584 EZ-KIT Lite.
    Please refer the below linked FAQ, which might be helpful to you
    FAQ: Can we connect EI3 SDP Breakout Board and New DSP EZ-KITs ?
    ez.analog.com/.../faq-can-we-connect-ei3-sdp-breakout-board-and-new-dsp-ez-kits
    The breakout board allows signals travelling between SDP controller boards and compatible daughter boards to be monitored by the insertion of the breakout board between the SDP controller board and the daughter board.
    EI3 SDP Breakout Board is an expansion board that exposes each of the 120 pins of the EI3 connector, allowing users to monitor signals between the controlling board and the attached daughter evaluation board.
    The Expansion Interface III (EI3) implemented on the ADSP-SC584 EZ-Board consists of three connectors: P1A, P1B and P1C.
    For more information on the EI3 SDP Breakout Board, please refer below linked user guide :
    www.analog.com/.../UG-282.pdf
    You can purchase the EI3 SDP Breakout Board using below link.
    www.analog.com/.../sdp-breakout-board.html
    In that page, select your country and click view inventory. Then select the order and buy it.
    For more details on purchasing, pricing and discount, please contact your local ADI sales office or distributor. You can get the sales office and distributors details by selecting your continent and then select country from the below link.
    www.analog.com/.../continent.asp
    Best Regards,
    Santhakumari.K
  • Hello Santhakumari,
    thanks for quickly answering!
    My current understanding is I only need the EI3 SDP Breakout Board to connect my SC584 Eval Board to a SDP daughter board, that is also Expansion Interface 3 compatible. So I would now need a fitting daughter board. I found the EVAL-BFAUDIO-EZEXT (EVAL-BFAUDIO-EZEXT Evaluation Board | Analog Devices), but this is only specified for blackfin boards. But as it is compatible with the expansion interface 3, it should also work here, correct?
    Sadly it only adds 8 inputs, but I would need 12 to 16 additional analog microphone inputs with RCA connectors. Is it correct, that I would be able to connect 3 EI3 SDP Breakout Boards + Daughter Boards to the SC584 eval board - one each for the connectors 1A, 2A and 3A at the SC584 Eval board? I would just need the I2S / SPORT connection between the SC584 and the daughter board and there are 2 SPORT connection on each of the 3 connectors.
    Thanks!
    mss
  • Hi Santhakumari,
    Anything on my further questions?
    Our sincere apologies for the delayed response. Here is an update from our Internal team.
    The EI3-HDMIAUDIO requires an HDMI license to order it and gain access to the documentation.
    We don’t offer any other boards with additional audio input/outputs for the EI3 interface.
    Hope this helps.
    Best Regards,
    Santhakumari.K
