GPIO Problem
I'm trying to configure my tactile switches to send a LOW to the GPIO pins D0, D1, D2, D6(PPI) in PORTB. I started the project in the TalkThrough_BF706Mini project because I wanted to test putting a stereo signal through first and the audio part of the program worked. I have since started adding functionality to the project with a protoboard and adding my own code, have marked my code for your convenience. I have included the schematic and a picture of my protoboard. PLEASE ignore the incorrect data pin assignments on the schematic for the switches. I can assure you the switches are connected to P4 NOT the UNO compatibility headers. Also, I am using the default state of EPPI0_CLK(P4, PIN 11) to supply 3.3V to the switches.  I am not using an Arduino Uno either just a protoboard and the ADSP-BF706 EZ Kit MINI.
The problem is:
-When I press switches that are connected to D0, D1 and D2 I get a hex value of 0x0000F980.
-When I press the switch connected to D6 I get a value of 0x0000F900.
-When nothing is pressed I get a value of 0x0000F9E2
Each individual switch press should return a different hex value because the bits would be low in the register! However, this is not the case.
Any help is appreciated thank you!
Also If I could get some help initializing the SPI display afterward as well that would be greatly appreciated!
Here is my code.
Copyright(c) 2015 Analog Devices, Inc. All Rights Reserved.
This software is proprietary and confidential. By using this software you agree
to the terms of the associated Analog Devices License Agreement.
* This example demonstrates how to use the ADAU1761 codec driver to receive audio
* samples from the Line Input and transmit those audio samples to the headphone
* output (talkthrough).
 * On the ADSP-BF706 EZ-KIT MiniTm:
* Connect an audio source to the LINE IN jack (J1)
* Connect headphones to the HP jack (J2).
#include <drivers/codec/adau1761/adi_adau1761.h>
#include <services/pwr/adi_pwr.h>
#include <stdio.h>
#include <string.h>
#include <services/gpio/adi_gpio.h>
#include <services/tmr/adi_ctmr.h>
/* SigmaStudio exported file */
#include "SigmaStudio\export\export_IC_1.h"
#include "TalkThrough_BF706Mini.h"
/* ADI initialization header */
#include "system/adi_initialize.h"
/* User Macro - select sample rate */
#define SAMPLE_RATE (ADI_ADAU1761_SAMPLE_RATE_48KHZ)
/* User Macro - select the number of audio samples (stereo) for each buffer */
#define NUM_AUDIO_SAMPLES 64u /* 32 left + 32 right */
/* 32-bits per sample (24-bit audio) */
#define BUFFER_SIZE (NUM_AUDIO_SAMPLES*sizeof(uint32_t))
/* used for exit timeout */
#define MAXCOUNT (500000u)
* SPORT device memory
#pragma align(4)
static uint8_t sportRxMem[ADI_SPORT_DMA_MEMORY_SIZE];
#pragma align(4)
static uint8_t sportTxMem[ADI_SPORT_DMA_MEMORY_SIZE];
* Audio buffers
#pragma align(4)
static uint32_t RxBuffer1[NUM_AUDIO_SAMPLES];
#pragma align(4)
static uint32_t RxBuffer2[NUM_AUDIO_SAMPLES];
#pragma align(4)
static uint32_t TxBuffer1[NUM_AUDIO_SAMPLES];
#pragma align(4)
static uint32_t TxBuffer2[NUM_AUDIO_SAMPLES];
/* audio buffer pointers */
static uint32_t *pRxAudioBuffer;
static uint32_t *pTxAudioBuffer;
/* SPORT info struct */
static ADI_ADAU1761_SPORT_INFO sportRxInfo;
static ADI_ADAU1761_SPORT_INFO sportTxInfo;
typedef enum
NONE,
START_TALKTHROUGH,
TALKTHROUGH,
STOP_TALKTHROUGH
} MODE;
static MODE eMode = NONE;
/* Memory required for codec driver - must add PROGRAM_SIZE_IC_1 size for data transfer to codec */
static uint8_t codecMem[ADI_ADAU1761_MEMORY_SIZE + PROGRAM_SIZE_IC_1];
/* adau1761 device handle */
static ADI_ADAU1761_HANDLE hADAU1761;
static bool bError;
static volatile uint32_t count;
/* error check */
static void CheckResult(ADI_ADAU1761_RESULT result)
if (result != ADI_ADAU1761_SUCCESS) {
printf("Codec failure\n");
bError = true;
/* codec record mixer */
static void MixerEnable(bool bEnable)
ADI_ADAU1761_RESULT result;
uint8_t value;
if (bEnable)
/* enable the record mixer (left) */
result = adi_adau1761_SetRegister (hADAU1761, REC_MIX_LEFT_REG, 0x0B); /* LINP mute, LINN 0 dB */
CheckResult(result);
/* enable the record mixer (right) */
result = adi_adau1761_SetRegister (hADAU1761, REC_MIX_RIGHT_REG, 0x0B); /* RINP mute, RINN 0 dB */
else
/* disable the record mixer (left) */
result = adi_adau1761_GetRegister (hADAU1761, REC_MIX_LEFT_REG, &value);
result = adi_adau1761_SetRegister (hADAU1761, REC_MIX_LEFT_REG, value & 0xFE);
/* disable the record mixer (right) */
result = adi_adau1761_GetRegister (hADAU1761, REC_MIX_RIGHT_REG, &value);
result = adi_adau1761_SetRegister (hADAU1761, REC_MIX_RIGHT_REG, value & 0xFE);
/* codec driver configuration */
static void CodecSetup(void)
/* Open the codec driver */
result = adi_adau1761_Open(ADAU1761_DEV_NUM,
codecMem,
sizeof(codecMem),
ADI_ADAU1761_COMM_DEV_TWI,
&hADAU1761);
/* Configure TWI - BF706 EZ-Kit MINI version 1.0 uses TWI */
result = adi_adau1761_ConfigTWI(hADAU1761, TWI_DEV_NUM, ADI_ADAU1761_TWI_ADDR0);
/* load Sigma Studio program exported from *_IC_1.h */
result = adi_adau1761_SigmaStudioLoad(hADAU1761, default_download_IC_1);
/* config SPORT for Rx data transfer */
sportRxInfo.nDeviceNum = SPORT_RX_DEVICE;
sportRxInfo.eChannel = ADI_HALF_SPORT_B;
sportRxInfo.eMode = ADI_ADAU1761_SPORT_I2S;
sportRxInfo.hDevice = NULL;
sportRxInfo.pMemory = sportRxMem;
sportRxInfo.bEnableDMA = true;
sportRxInfo.eDataLen = ADI_ADAU1761_SPORT_DATA_24;
sportRxInfo.bEnableStreaming = true;
result = adi_adau1761_ConfigSPORT (hADAU1761,
ADI_ADAU1761_SPORT_INPUT, &sportRxInfo);
/* config SPORT for Tx data transfer */
sportTxInfo.nDeviceNum = SPORT_TX_DEVICE;
sportTxInfo.eChannel = ADI_HALF_SPORT_A;
sportTxInfo.eMode = ADI_ADAU1761_SPORT_I2S;
sportTxInfo.hDevice = NULL;
sportTxInfo.pMemory = sportTxMem;
sportTxInfo.bEnableDMA = true;
sportTxInfo.eDataLen = ADI_ADAU1761_SPORT_DATA_24;
sportTxInfo.bEnableStreaming = true;
ADI_ADAU1761_SPORT_OUTPUT, &sportTxInfo);
result = adi_adau1761_SelectInputSource(hADAU1761, ADI_ADAU1761_INPUT_ADC);
/* disable mixer */
MixerEnable(false);
result = adi_adau1761_SetVolume (hADAU1761,
ADI_ADAU1761_VOL_HEADPHONE,
ADI_ADAU1761_VOL_CHAN_BOTH,
true,
57); /* 0 dB */
result = adi_adau1761_SetSampleRate (hADAU1761, SAMPLE_RATE);
/***********************************************************MY CODE****************************************************************************************************************************/
/*GPIO Definitions and Variables*/
uint32_t pin_dir;
uint32_t pin_read;
int main(void)
bool bExit;
bool bRxAvailable;
bool bTxAvailable;
ADI_PWR_RESULT pwrResult;
bExit = false;
/* setup processor mode and frequency */
pwrResult = adi_pwr_Init(0, CLKIN);
pwrResult = adi_pwr_SetPowerMode(0, ADI_PWR_MODE_FULL_ON);
pwrResult = adi_pwr_SetClkControlRegister(0, ADI_PWR_CLK_CTL_MSEL, MSEL);
pwrResult = adi_pwr_SetClkDivideRegister(0, ADI_PWR_CLK_DIV_CSEL, CSEL);
pwrResult = adi_pwr_SetClkDivideRegister(0, ADI_PWR_CLK_DIV_SYSSEL, SYSSEL);
adi_initComponents(); /* auto-generated code */
/* configure the codec driver */
CodecSetup();
count = 0u;
eMode = START_TALKTHROUGH;
/************************************************MY CODE*************************************************************************************************************************/
adi_gpio_SetDirection(ADI_GPIO_PORT_B, ADI_GPIO_PIN_1|ADI_GPIO_PIN_2|ADI_GPIO_PIN_3|ADI_GPIO_PIN_4|ADI_GPIO_PIN_5|ADI_GPIO_PIN_6|ADI_GPIO_PIN_7|ADI_GPIO_PIN_8|ADI_GPIO_PIN_9|ADI_GPIO_PIN_10|ADI_GPIO_PIN_11|ADI_GPIO_PIN_12|ADI_GPIO_PIN_13|ADI_GPIO_PIN_14|ADI_GPIO_PIN_15, ADI_GPIO_DIRECTION_INPUT);
//adi_gpio_Clear(ADI_GPIO_PORT_B, ADI_GPIO_PIN_1|ADI_GPIO_PIN_2|ADI_GPIO_PIN_3|ADI_GPIO_PIN_4|ADI_GPIO_PIN_5|ADI_GPIO_PIN_6|ADI_GPIO_PIN_7|ADI_GPIO_PIN_8|ADI_GPIO_PIN_9|ADI_GPIO_PIN_10|ADI_GPIO_PIN_11|ADI_GPIO_PIN_12|ADI_GPIO_PIN_13|ADI_GPIO_PIN_14|ADI_GPIO_PIN_15);
/*to read pin logic state*/
while(1)
adi_gpio_GetData(ADI_GPIO_PORT_B, &pin_read);
while(!bExit && !bError)
switch(eMode)
case START_TALKTHROUGH:
/* stop current input */
result = adi_adau1761_EnableInput (hADAU1761, false);
/* stop current output */
result = adi_adau1761_EnableOutput (hADAU1761, false);
/* submit Rx buffer1 */
result = adi_adau1761_SubmitRxBuffer(hADAU1761, RxBuffer1, BUFFER_SIZE);
/* submit Rx buffer2 */
result = adi_adau1761_SubmitRxBuffer(hADAU1761, RxBuffer2, BUFFER_SIZE);
/* submit Tx buffer1 */
result = adi_adau1761_SubmitTxBuffer(hADAU1761, TxBuffer1, BUFFER_SIZE);
/* submit Tx buffer2 */
result = adi_adau1761_SubmitTxBuffer(hADAU1761, TxBuffer2, BUFFER_SIZE);
result = adi_adau1761_EnableInput (hADAU1761, true);
result = adi_adau1761_EnableOutput (hADAU1761, true);
/* enable record mixer */
MixerEnable(true);
eMode = TALKTHROUGH;
break;
case TALKTHROUGH:
result = adi_adau1761_GetRxBuffer (hADAU1761, (void**)&pRxAudioBuffer);
if (pRxAudioBuffer != NULL)
/* re-submit buffer */
result = adi_adau1761_SubmitRxBuffer(hADAU1761, pRxAudioBuffer, BUFFER_SIZE);
/* get an available Tx buffer */
result = adi_adau1761_GetTxBuffer (hADAU1761, (void**)&pTxAudioBuffer);
if (pTxAudioBuffer != NULL)
* Insert audio algorithm here
/* talkthrough - copy the audio data from Rx to Tx */
memcpy(&pTxAudioBuffer[0], &pRxAudioBuffer[0], BUFFER_SIZE);
* End audio algorithm
result = adi_adau1761_SubmitTxBuffer(hADAU1761, pTxAudioBuffer, BUFFER_SIZE);
break;
case STOP_TALKTHROUGH:
eMode = NONE;
bExit = true;
break;
default:
break;
/* exit the loop after a while */
if (count > MAXCOUNT)
eMode = STOP_TALKTHROUGH;
count++;
result = adi_adau1761_Close(hADAU1761);
if (!bError) {
printf("All done\n");
} else {
printf("Audio error\n");
return 0;
